air conditioning- nice, required, or silly?
Old July 8th 07, 02:28 AM posted to rec.aviation.owning
john smith
Default air conditioning- nice, required, or silly?
Followup question for those of you who have one installed:
What are the associated maintenance and repair costs for the A/C and its
related components?
The Turbo-arrow IV I fly had A/C originally installed, but it was
removed more than 10 years ago.)
Old July 8th 07, 03:11 AM posted to rec.aviation.owning
Bob Noel
related components?
I had one on my cherokee 140 (until I removed it). It was in-op (no freon)
and I didn't have a problem with the alternator belts breaking, so the
associated maintenance and repair costs were zero.
Bob Noel
(goodness, please trim replies!!!)
Old July 8th 07, 10:23 AM posted to rec.aviation.owning
Thomas Borchert
I think the power/useful load/cost trade-off doesn't make sense for
most situations, including NOrtheeastern summers and single-engine
pistons. Also, many of the planes that offer AC as an option can be and
are flown high, so heat isn't an issue for long anyway. But, as always,
it's a question of what your mission is.
Thomas Borchert (EDDH)
Thomas Borchert
B,
You can always turn it off. G
which doesn't reduce weight much, though.
Old July 8th 07, 12:17 PM posted to rec.aviation.owning
B A R R Y
On Sun, 08 Jul 2007 11:23:57 +0200, Thomas Borchert
B,
True.
Old July 8th 07, 12:41 PM posted to rec.aviation.owning
Mike Spera
Anybody have any experience with air conditioning in their plane-Nice
to have? Silly accessory? Don't leave home without it? 80% Summer
flying in Northeast.
Thanks for your opinion.
Andy
As others have stated, you cannot use if for takeoff. So, you use it on
the ground and then turn it on again in the climb. 4 minutes into the
climb, you are usually into cooler air anyway and shut it off.
Google A/C and see the persistent problems with these units.
They are R-12 systems in most planes. If you think it is expensive to
get a car charged with R-12, wait till you see what it will cost to get
an A&P to do it - if you can find one. Likely you will have to talk an
auto tech into bringing his equipment out to the airport for the A&P to
watch him charge the system. Then, you get to pay 2 folks for one
operation. R-134? Many techs will not do a conversion because they can
screw up some systems irreparably. Even though many have converted
Pipers, the local auto tech has no experience and likely will not want
to "experiment" with a very expensive airplane.
The hoses are now 20-30+ years old. They leaked like crazy when new and
have not gotten any better with age. If an auto tech charges the plane,
they will likely give you the speech about how they are required to
investigate why the system needed a charge and fix it. Or, they may
refuse to charge it at all UNTIL the leak is found and fixed.
As others have said, they rob you of 70 odd pounds in the Pipers. For a
140 that is 10% of its useful load and precludes any thoughts of a third
person.
The alternator belts and pulleys are the biggest pain. After 1000 hours,
the pulleys wear due to the high tension required on the skinny
alternator belt. Once worn, you can throw belts in as little as 2 hours.
Ironically, the compressor belt usually never breaks. Which would you
choose to go South unpredictably?
We removed ours and got back 43 pounds. We left the drop door and
condenser in because of the hassle of removing it. The cost to "convert"
back to stock can be staggering and the parts are NOT easy to identify
and find.
Opinions vary, but in many Midwest/Northern parts of the country, it is
not worth the hassle.
Good Luck,
Mike
Old July 8th 07, 02:10 PM posted to rec.aviation.owning
Matt Whiting
The problem is that many northeast airports are very busy and have long
taxi times. I've spent 30 minutes on the taxiway at Philly, Washington
National (pre 9/11 obviously), and Boston. On a 95 F day, this is
extremely unpleasant, even with the windows open (one nice 182 advantage).
Matt
Old July 8th 07, 02:52 PM posted to rec.aviation.owning
B A R R Y
On Sun, 08 Jul 2007 13:10:44 GMT, Matt Whiting
Philly, Wash, Boston? No need to go there!
I've spent 30 minutes on the ground at Martha's Vineyard, New Bedford,
and Danbury.
Old July 8th 07, 03:21 PM posted to rec.aviation.owning
150flivver
On Jul 8, 6:41 am, Mike Spera wrote:
They are R-12 systems in most planes...R-134? Many techs will not do a conversion because they can
to "experiment" with a very expensive airplane...
Mike
I can't imagine that converting an R-12 system to R-134 wouldn't
require an STC.
Silly L/D stats Andy[_1_] Soaring 1 April 9th 07 05:14 AM
Silly controller Robert M. Gary Instrument Flight Rules 123 August 30th 06 01:56 AM
Saab 340 air conditioning? John Clonts Piloting 1 July 14th 06 05:00 PM
ELT Required for all SSA sanctioned contests starting 2006 ELT Required for all SSA sanctione Steve Leonard Soaring 2 September 14th 05 03:49 AM
Air Conditioning System for Homebuilts? JPAviation Home Built 18 February 6th 04 03:24 AM
