On Jul 11, 11:37 am, Eric Greenwell wrote:
Ideas from people that have never done this are also welcome, as I doubt there are many "stripe replacement" experts, and they might not be reading RAS. Never done it but if I had to I'd try it this way. Rivet both ends of the warm filler strip. Insert lower edge in channel. Run a tool between the channel and the top edge of the strip while pressing the strip inwards. Imagine it's the inverse of installing a car windshield seal filler strip (for those that remember before windshields were all bonded). Andy |
In general, avoid red plastics for outdoor (uv exposed) use. Ever since
cadmium was banned as an additive in the late seventies (?), noone has found a replacement that will make red last. Lars Peder Using, yes, blue on the Cobra "Jack" wrote in message t... wrote: I also noted from looking at a lot of trailers that the red strips weathered much faster than the blue so I changed mine to blue. Red does that. Mine are 2001 vintage and there is no color left. Too much FL sun, I suppose. I was going to paint them with something rather than replace them. It seems cheaper, and perhaps easier. I'm sticking with red because of the red logos on the glider. Comments? Jack |
On Jul 11, 2:37 pm, Eric Greenwell wrote:
My 12 year old blue stripes turned brown several years ago, so I'm now trying to install the new ones. It's not going well. The factory instructions call for hot soapy water on the trailer and stripe, then the end is pulled by one person while another feeds/pushes it into the aluminum extrusions. This works until about 8 feet is on the trailer, then it gets hard to go any farther. With 22 feet of trailer left, I don't think we'll make it! They do mention using an additional 1 or 2 people in the middle to help push the stripe along, but we didn't have more people. Does anyone have experience with this, and how did you get the stripe in place? Ideas from people that have never done this are also welcome, as I doubt there are many "stripe replacement" experts, and they might not be reading RAS. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * "Transponders in Sailplanes"http://tinyurl.com/y739x4 * "A Guide to Self-launching Sailplane Operation" atwww.motorglider.org You guys have *way* too much time on your hands. Don't you have blowholes to clean or something ? See ya, Dave PS: No, my glider does not have blowholes... |
On Jul 12, 2:20 pm, Eric Greenwell wrote:
wrote: On Jul 11, 2:37 pm, Eric Greenwell wrote: My 12 year old blue stripes turned brown several years ago, so I'm now trying to install the new ones. It's not going well. ... Does anyone have experience with this, and how did you get the stripe in place? Ideas from people that have never done this are also welcome, as I doubt there are many "stripe replacement" experts, and they might not be reading RAS. You guys have *way* too much time on your hands. When you have a 12 year old trailer with 120,000 miles on it, what are you going to do? I've replaced 3 sets of tires, one set of brakes, one tongue, both taillights (with LED units), glued and re-glued the carpet pieces, and a new axle is on it's way. That leaves the stripes! Maybe I should've done the stripes at Albert Lea, where I definitely had *way* too much time on my hands. Don't you have blowholes to clean or something ? Already did that in March (not sure which year, though). -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * "Transponders in Sailplanes"http://tinyurl.com/y739x4 * "A Guide to Self-launching Sailplane Operation" atwww.motorglider.org Well anyway, pass my condolences to Jan... Best Regards, Dave PS: Great to see you at Albert Lea if only in the rain... |
My 12 year old blue stripes turned brown several years ago, so I'm now trying to install the new ones. It's not going well. Since I had an abundance of soapy water and high temperatures (102 F), I used that method to replace the right stripe. I did it out in the sun, so the stripe was extra hot. The sun also made my wife extra hot, but in a sweaty, "can't we do this any faster", kind of way. The first 22 feet slide on before I couldn't pull it any farther. I had to remove 8 feet of the stripe from the channel at the end I was pulling on, then pull the rest of the stripe on. The 8 feet was then pushed on the channel 1/4" at time with a screwdriver, so it was slow and tedious, but at least I could do it in the garage in the shade. Total time was about 1.5 hours. The left stripe was installed using Pam cooking spray (basically, canola oil in a spray can) sprayed on the stripe and the channel on the trailer. That was lot easier - I was able to install the stripe by myself in 30 minutes in the garage in only 90 F heat, except for the last 5 feet. Putting the trailer in sunlight warmed the stripe up enough to easily pull the last 5 feet into the channel. The canola oil seemed slicker than the spray olive oil we had, but I'm sure there is something even better than Pam. That would make it easy to do at lower temperatures. A trailer for 15 meter gliders would be easier than my 30 foot long trailer box (34 feet with the tongue) for an 18 M glider. I noticed the new vinyl stripe is almost twice as thick as the 12 year old stripe, so someone that's replaced a stripe years ago might be surprised by the (likely) extra effort required to replace a stripe now. The trailer looks almost good as new now, with the new fenders (replaced because one was destroyed by a tire tread) and stripes. Just wait until it gets it's new axle and wheels! -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * "Transponders in Sailplanes" http://tinyurl.com/y739x4 * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
While the Pam (spray canola cooking oil) worked well, there was an
unexpected after-effect: the oil seeped out of the channel and ran down the side of the trailer, which combined with the road dust to produce a truly ugly sight! After a few days, when the seepage stopped, 5 minutes with a foam brush at a car wash cleaned it all off. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * "Transponders in Sailplanes" http://tinyurl.com/y739x4 * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
| Cobra Trailer | [email protected] | Soaring | 22 | December 8th 06 12:38 AM |
| Replacing Cobra trailer 13 inch tires with larger? | Andy Blackburn | Soaring | 6 | August 19th 04 04:15 AM |
| Replacing Cobra trailer wheels | samcgiltner | Soaring | 8 | August 12th 04 08:46 PM |
| Cobra Trailer | Soaring | 1 | September 28th 03 02:14 PM | |
| FS: Cobra Trailer | Ed Byars | Soaring | 0 | September 22nd 03 05:47 PM |
