Control surface design question
Old July 13th 07, 05:18 AM posted to rec.aviation.homebuilt
Chris W
Default Control surface design question
I'm sure everyone here is familiar with the combination of the
horizontal stabilizer and elevator to make a stabilator. I think I have
even heard of the concept being used for a ruder. My question is has
anyone ever made a plane taking the concept all the way and made a
"wingeron"? My guess is no one has, seems to me it would be difficult
to do and maintain the required strength with out adding a lot of weight.
It's probably not practical for a real plane but I thought it might be
an interesting experiment to try on an RC plane.
Chris W
KE5GIX
"Protect your digital freedom and privacy, eliminate DRM,
learn more at http://www.defectivebydesign.org/what_is_drm"
Gift Giving Made Easy
Get the gifts you want &
give the gifts they want
One stop wish list for any gift,
from anywhere, for any occasion!
http://thewishzone.com
Old July 13th 07, 09:25 AM posted to rec.aviation.homebuilt
Peter Dohm
"Richard Riley" wrote in message
The vertical stabs on many of the newer fighters are all flying -
F-18, F-22, F-35.
As did the Folker Triplane.
Old July 13th 07, 02:36 PM posted to rec.aviation.homebuilt
Gig 601XL Builder
F-18, F-22, F-35.
You don't have to get NEAR that advanced. The vertical stabilizer on the
601XL I'm building is the rudder.
Old July 13th 07, 03:00 PM posted to rec.aviation.homebuilt
Nauga[_2_]
"Chris W" wrote in message
My question is has anyone ever made a plane taking the concept
all the way and made a "wingeron"?
I have a radio control 'pitcheron' slope glider and bits of several more.
There are two schools of thought: 1) use differential wing pivoting to get
roll control and use a separate elevator on the tail ('wingeron') and 2) use
differential pivot for roll and summetric for pitch with a fixed tail
('pitcheron'). Typically both types roll like crazy. Pitcherons have a
reputation for being a bit sluggish in pitch. Find an R/C site and search
for names like 'Orca', 'Ultron', 'Shrike', 'Pica', or just pitcheron and
wingeron. I have a Pica and most of an Orca.
By the way, the F/A-18 (all models) has separate rudders/verticals.
All-moving rudders have been used as far back as the A-5 ('Vigilante'),
which had NO 'conventional' (for the time) control surfaces. Stabilator for
pitch, all-moving rudder for yaw, and spoilers for roll. The Volksplane
has/had an all-moving vertical, if you want something similar.
Dave 'control allocation' Hyde
Old July 13th 07, 03:47 PM posted to rec.aviation.homebuilt
My Jodel has an all-moving vertical surface. Has awesome
authority in spite of its small size.
The all-moving wing has been done. The Spratt ControlWing
was a homebuilt flying boat built by a number of folks in the 60s-80s
and there might be a few still going together. The tail was a V-shaped
affair that had no movement whatever, with a pusher propeller mounted
between the two surfaces driven by a long shaft from the converted
outboard engine mounted in the hull. The wings pivoted at the spar
attach and strut fittings on the wings, and were controlled bu a
couple of push-pull tubes at their trailing edges. Roll control was
differential wing movement, "pitch" was by moving the wings together
via a lever like a helicopter collective. The tail surfaces just kefp
the thing pointing into the relative wind.
I tried to get some pics but Goggle is acting up this morning.
Dan
Old July 13th 07, 04:30 PM posted to rec.aviation.homebuilt
Richard Isakson
"Chris W" wrote ...
The A-7 had variable incidence wings though not for roll control. I believe
this was to change the angle of the fuselage for carrier landings.
Many missiles have full flying "wings". With no takeoff or landing
requirements these lifting surfaces are tiny. While very maneuverable, they
have such small wings that many airplanes can turn inside an attacking
missiles and thus escape it's lock.
Rich
Old July 13th 07, 04:54 PM posted to rec.aviation.homebuilt
Nauga
Richard Isakson wrote...
believe
The F-8 (pre-A-7) had variable incidence wing, but (like you said) it wasn't
for control - it was two position only and was implemented so that the nose
was lower on approach for improved feld of view.
A lot of these missiles don't bank to turn either. They're axisymmetric,
they just pitch or yaw to get the angles and lift or sideforce they need to
turn.
Dave 'rolleron' Hyde
Old July 13th 07, 06:32 PM posted to rec.aviation.homebuilt
Montblack
http://www.flyingflea.org/docs/SprattControlwing.htm
Here's some pics
Paul-Mont
Old July 13th 07, 06:47 PM posted to rec.aviation.homebuilt
Montblack
("Richard Riley" wrote
The Wright Bros had warping wings, and the Freewing airplanes move
thevwings together, in relationship to the body. There's a lot of research
into changing the shape of wings to provide differential lift. I don't
think anyone's actually rotated wings separately for roll controll - it
would be difficult. The smallest change in
relative angle of attack would give you huge rolling moments. I think
controlling it would be a non-trivial problem.
http://www.flyingflea.org/movies/freewing.mov
FreeWing movie ...super interesting! (Watch it ...Fun)
http://www.flyingflea.org/docs/videos.htm
More movies...
From this site
Over ten years ago now, I saw a Discovery Channel show where a guy put a PVC
type pipe on top of a small high wing planes' fuselage. He attached two
wings to the pipe - the pipe was sticking out each side of the fuselage. The
wings were free to rock and roll, independent of each other.
The reporter went up and pronounced the ride - smooth as silk. Also, the
plane now had super-STOL abilities. I think it was a story out of OZ.
Paul-Mont
Old July 13th 07, 07:51 PM posted to rec.aviation.homebuilt
wright1902glider
On Jul 13, 11:47 am, "Montblack" Y4_NOT!...
Wilbur's original idea for roll control was to mount the wings and a
differential type gear (think of a car axle) and have them rotate
opposite one another for control when the pinion gear was turned by
the pilot. Of course, Orville convinced him that there was no way to
make such a device light enough to be lifted and strong enough to
support a man with the available materials and power systems of 1899.
The Eureka moment with the inner-tube box came months later.
You might argue that the idea is even older. Check out Chanute's
multiple surface machine (the katydid). It had an airframe which
allowed small independantly pivoting wings to be added or subtracted
depending on the experiment. Certainly Spratt knew of this design
since he was working with Chanute from time to time in that era.
Harry Frey
Wright Brothers Enterprises
Labelle control surface weights Martin Eiler Soaring 1 April 28th 07 12:32 AM
Control surface repair legal? Part II [email protected] Owning 8 October 10th 06 04:31 AM
Control surface repair legal? [email protected] Owning 10 September 25th 06 07:51 AM
Control surface alignment [email protected] Home Built 10 July 4th 05 10:06 PM
PIK20D Control surface hinge moments PIK20D Soaring 3 November 19th 04 03:06 PM
