Panel on C-130 vertical stab question
Old September 18th 03, 11:20 PM
B2431
Default Panel on C-130 vertical stab question
On C-130s painted in camoflauge they used to leave a panel bare on each side of
the vertical stab. There was a circle in the middle that was painted. What was
the purpose of doing this?
Dan, U. S. Air Force, retired
Old September 19th 03, 02:35 AM
B2431
That circle in the middle isn't paint, it's - for lack of a better term -
glue.
Actually, a combination of adhesive and waterproofing. There is a longwire
VHF
antenna that runs from there to the spine just behind the flight deck.
TSg Bill
Most of the C-130s I worked on were the bubble top HC-130P and HC-130N and I
seem to recall the long wires went to the leading edge of the vertical stab.
Come to think of it the bare panel seems to have disappeared on the ones I
worked on long before we went to gray. Maybe it was a change on ours.
Many thanks.
Old September 19th 03, 10:32 PM
Andrew Chaplin
"Gord Beaman" wrote in message
Much more likely it's an HF (High Frequency) antenna.
VHF doesn't use 'long wire antennas'
You can operate on long wire antennae with VHF if you cut them right
(centre-fed droppy V-dipole, etc.) but there's no need to on an aircraft.
Andrew Chaplin
SIT MIHI GLADIUS SICUT SANCTO MARTINO
(If you're going to e-mail me, you'll have to get "yourfinger." out.)
Old September 19th 03, 10:59 PM
Tarver Engineering
"Andrew Chaplin" wrote in message
The c-130 is identical to what Gord wrote. In fact, my friends in Mojave
are seeking an STC to eliminate these wirs and put the antenna in the
vertical stab. (ie L139)
Old September 20th 03, 01:13 AM
B2431
C-130s are not STCed. To change it requires a class B mod or TCTO.
Old September 20th 03, 05:49 PM
Tarver Engineering
"B2431" wrote in message
That is why I wrote L139, dumbass. Do you ever get anything right, Dan?
Panel Lights - Need Help Barnyard BOb - Home Built 2 May 29th 04 08:51 PM
Question for Fellow CFII's regarding Partial Panel Training Brad Z Instrument Flight Rules 16 May 27th 04 12:25 AM
Air Force Academy Review Panel Sets Public Meeting Otis Willie Military Aviation 0 September 3rd 03 10:56 PM
Air Force Museum forms review panel Otis Willie Military Aviation 2 August 29th 03 05:41 PM
Air Force Academy Review Panel Sets Second Public Meeting Otis Willie Military Aviation 0 July 10th 03 03:39 AM
