Rejex
Old July 15th 07, 07:34 PM posted to rec.aviation.owning
Dan Luke[_2_]
Default Rejex
Been using this stuff for a month now on the new airplane. So far, Iike it.
It goes on like any liquid car wax. You let it dry for 20 minutes, then wipe
it off. It wipes off a bit more easily than regular wax haze.
The instructions say to apply it when temp. is below 85 F. and let it cure 12
hours out of the elements, and I've been careful to follow them.
Rejex produces a nice shine, but the best thing about it is that it makes bug
removal easy. Since I am on a personal campaign to kill all the bugs in
Alabama by smashing them with my airplane, I need all the help I can get in
removing the corpses. With a coat of Rejex on the leading edges, struts,
etc., this job is a snap: a few passes with a damp cloth and you're done.
The mfr. claims it will last 4-6 months between applications; we'll see.
Right now, I'm a satisfied customer.
Dan
T-182T at BFM
Old July 16th 07, 03:33 PM posted to rec.aviation.owning
Paul kgyy
Default Rejex
You can use it on the windscreen, too - makes bugs very easy to
remove, and rain beads off easily.
Old July 16th 07, 10:09 PM posted to rec.aviation.owning
pgbnh
Default Rejex
Where does one purchase Rejex? How much is required for an avarage single?
"Dan Luke" wrote in message
it.
wipe it off. It wipes off a bit more easily than regular wax haze.
12 hours out of the elements, and I've been careful to follow them.
bug removal easy. Since I am on a personal campaign to kill all the bugs
in Alabama by smashing them with my airplane, I need all the help I can
get in removing the corpses. With a coat of Rejex on the leading edges,
struts, etc., this job is a snap: a few passes with a damp cloth and
you're done.
Dan
T-182T at BFM
Old July 17th 07, 12:19 AM posted to rec.aviation.owning
Dan Luke[_2_]
Default Rejex
Lots of places on the web:
http://www.e-tackle.com/rejeX.htm
The 16-oz bottle should be enough if you don't over-apply it.
Dan
T-182T at BFM
Old July 17th 07, 01:32 AM posted to rec.aviation.owning
karl gruber[_1_]
Default Rejex
http://tinyurl.com/2axlwp
"pgbnh" wrote in message
it.
cure 12 hours out of the elements, and I've been careful to follow them.
you're done.
Dan
T-182T at BFM
Old July 17th 07, 06:01 AM posted to rec.aviation.owning
Mike Noel
Default Rejex
....and if you use it on the windshield, hopefully it doesn't cause you to go
IFR by producing tiny beads of moisture when exposed to air close to the dew
point.
Best Regards,
Mike
http://photoshow.comcast.net/mikenoel
It is not work that kills men; it is worry. Worry is rust upon the blade.
"Paul kgyy" wrote in message
Old July 17th 07, 12:08 PM posted to rec.aviation.owning
Dan Luke[_2_]
Default Rejex
point.
Why would it do that?
Dan
T-182T at BFM
Old July 17th 07, 03:58 PM posted to rec.aviation.owning
Mike Noel
Default Rejex
I've seen it happen on the ground after using a Plexiglas wax. Rolling the
airplane out of the hangar on a chilly, damp morning, dew quickly formed on
the windshield and the tiny beads of moisture made it impossible to see out
until the defroster has worked on the windshield for a few minutes. Others
have reported it happening in flight. Wax on the windshield seems to
aggravate this type of problem.
Best Regards,
Mike
go IFR by producing tiny beads of moisture when exposed to air close to
the dew point.
Dan
T-182T at BFM
Old July 17th 07, 06:39 PM posted to rec.aviation.owning
karl gruber[_1_]
Default Rejex
No.................not to worry. That would NEVER happen.
"Mike Noel" wrote in message
the dew point.
Best Regards,
Mike
Old July 17th 07, 06:40 PM posted to rec.aviation.owning
karl gruber[_1_]
Default Rejex
BS
the airplane out of the hangar on a chilly, damp morning, dew quickly
formed on the windshield and the tiny beads of moisture made it
impossible to see out until the defroster has worked on the windshield for
a few minutes. Others have reported it happening in flight. Wax on the
windshield seems to aggravate this type of problem.
Best Regards,
Mike
to go IFR by producing tiny beads of moisture when exposed to air close
to the dew point.
Dan
T-182T at BFM
Rejex Hankal Aviation Marketplace 2 July 8th 04 09:23 PM
