Gear up takeoff
Old July 17th 07, 09:04 PM posted to rec.aviation.piloting
john smith[_2_]
Default Gear up takeoff
DESCRIPTION
AIRCRAFT ON TAKEOFF, SANK DOWN ONTO RUNWAY WITH GEAR RETRACTED, FORT
LAUDERDALE, FL
Is this an example of putting the gear lever up before advancing the
throttle for takeoff?
Old July 17th 07, 09:11 PM posted to rec.aviation.piloting
Ross
john smith wrote:
DESCRIPTION
LAUDERDALE, FL
My father was an B-25 instructor in CA during WWII. He said some of the
cadets would do this and the CO would be real mad when the B-25 settled
back to earth.
Regards, Ross
C-172F 180HP
KSWI
Old July 17th 07, 10:04 PM posted to rec.aviation.piloting
gpaleo
Ο "john smith" έγραψε στο μήνυμα
DESCRIPTION
LAUDERDALE, FL
No, that's ignoring the little check-list item "...positive rate of climb,
gear up, ....."
Old July 17th 07, 10:06 PM posted to rec.aviation.piloting
Montblack
("Ross" wrote)
back to earth.
B-25 ....BOMBER!
I'm with the CO on this one. :-)
Paul-Mont
Old July 17th 07, 10:10 PM posted to rec.aviation.piloting
Roy Smith
"Montblack" wrote:
("Ross" wrote)
back to earth.
B-25 ....BOMBER!
Paul-Mont
Bombers have an advantage over other types on these types of takeoffs.
When you feel the aircraft starting to settle, you can just hit the button
and drop your load. The sudden decrease in aircraft weight will give you
the extra performance boost you need to start climbing.
Old July 17th 07, 11:09 PM posted to rec.aviation.piloting
flynrider via AviationKB.com
john smith wrote:
DESCRIPTION
LAUDERDALE, FL
It could be. On some aircraft, as soon as pressure on the squat switch is
relieved, the gear will start coming up if the gear handle is in the "up"
position. On the other hand, this could be a case of the pilot pulling the
gear up prematurely on the takeoff run.
Message posted via http://www.aviationkb.com
Old July 17th 07, 11:38 PM posted to rec.aviation.piloting
Roy Smith
In article 755395d04533f@uwe,
position.
Are there any aircraft for which that is NOT the case?
Old July 17th 07, 11:41 PM posted to rec.aviation.piloting
Gatt
"Ross" wrote in message
back to earth.
Some/all B-17s will do that too. When Evergreen turned me loose in their
bird (flipped on the battery and open the bomb bay for some visiting WWII
vets) I was specifically briefed NOT to bump the landing gear lever or it
would be a very bad day at the hangar. I've had more than one nightmare of
doing just that since.
When I started flying retractables, it really spooked me out all over again
for a bit.
-c
Old July 17th 07, 11:42 PM posted to rec.aviation.piloting
Gatt
"Roy Smith" wrote in message
Paul-Mont
I'm sure that's very comforting to the folks aft of the bomb bay. :
-c
Old July 18th 07, 12:16 AM posted to rec.aviation.piloting
Ron Natalie
position.
There's no squat switch on the gear on the Navion. There's no
electrical components in the retraction/extension system at
all. It's 100% hydraulic. The only thing that keeps the main
retracting is the airplane is too heavy for the actuators. The
nose will come up with the amount of pressure from the engine
driven hydraulic pump being turned by the starter.
Johnson-bar mooneys are similar.
Gear Up, pt 4 - Crashed He 111 with balloon cable cutting gear - July 1940.jpg (1/1) Mitchell Holman Aviation Photos 0 April 13th 07 01:50 PM
Crashing on takeoff... how odd [email protected] Piloting 165 August 31st 06 04:30 AM
seaplane takeoff Lets Fly Owning 1 December 5th 05 10:18 PM
Takeoff with a problem? Rocky Piloting 14 January 23rd 04 02:26 PM
Jet takeoff performance karl gruber Piloting 6 November 21st 03 05:59 PM
