Investigators Say Student Pilots Should Be Flagged
Old July 18th 07, 01:38 AM posted to rec.aviation.piloting
Travis Marlatte
Default Investigators Say Student Pilots Should Be Flagged
"Travis Marlatte" wrote in message
et...
"Peter Dohm" wrote in message
news
"Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net wrote in message
Not IMHO a bad idea really. When I was training and flew to controlled
airspace for XC flights it was suggested that I mention I was a student
and
they did seem to slow things down a little.
I can see how a uniform way of doing this might be helpful both in
controlled and uncontrolled airspace. Example, "Bumfigle Tower, Cessna
Student 1234A, ...."
From AVWeb
Britain's Air Accidents Investigation Branch (AAIB) is recommending that
student pilots on solo flights be identified by a radio call-sign prefix
so
air traffic controllers can take into account their limited experience
and
knowledge. The recommendation came from the investigation of a crash on
July
19, 2006, that killed a 16-year-old student who had logged 15 hours and
was
on his second solo flight. Just before he touched down at Southend
Airport,
a controller ordered him to turn left and climb to pattern height so an
overtaking Piper Meridian could land. It's believed he did not
reconfigure
the aircraft and apply enough power for the unorthodox go-around and the
Cessna he was flying stalled and crashed a short time later. The
four-person
investigation team concluded pilot Sam Cross was put "in a situation for
which his training and experience had not prepared him" after being
"instructed to carry out an unfamiliar and nonstandard manoeuvre," the
AAIB
report said. Adding to the mix was the fact that Cross was returning to
field after just eight minutes in the air because haze was reducing
visibility. His instructor was watching from the ground as the order to
deviate from the runway heading was complied with and he noted the
nose-up
attitude of the Cessna before it stalled and spiralled into a park.
Investigators determined the flaps were at 20 degrees, the carb heat was
on
and the engine was turning at 900 rpm at the time of the crash. Cross
was
the youngest pilot ever to be killed in a plane crash in Britain.
In may very well be a good idea and, as several contributors have pointed
out, it is commonly done by both civil and military flight schools.
However, in my none too humble opinion, it has nothing whatsoever to do
with
the cited accident--in which the student pilot's status was presumably
well
known. And, of course, it is phrased as though someone would like to see
it
become a regulation.
(rant temporarily witheld)
Well, that wasn't a very useful post, was it?
What I meant to say was that "judgement" training should start early.
Starting out, I added "student pilot" to my call sign. Once I stopped doing
that, I can remember a time when I responded to an odd request with "Unable,
student pilot."
Travis
Lake N3094P
PWK
Old July 18th 07, 12:11 PM posted to rec.aviation.piloting
Stealth Pilot[_2_]
On Tue, 17 Jul 2007 11:23:16 -0500, "Gig 601XL Builder"
airspace for XC flights it was suggested that I mention I was a student and
From AVWeb
student pilots on solo flights be identified by a radio call-sign prefix so
air traffic controllers can take into account their limited experience and
knowledge. The recommendation came from the investigation of a crash on July
19, 2006, that killed a 16-year-old student who had logged 15 hours and was
on his second solo flight. Just before he touched down at Southend Airport,
overtaking Piper Meridian could land. It's believed he did not reconfigure
Cessna he was flying stalled and crashed a short time later. The four-person
"instructed to carry out an unfamiliar and nonstandard manoeuvre," the AAIB
report said. Adding to the mix was the fact that Cross was returning to the
deviate from the runway heading was complied with and he noted the nose-up
Investigators determined the flaps were at 20 degrees, the carb heat was on
and the engine was turning at 900 rpm at the time of the crash. Cross was
I hope that someone takes the air traffic controller and the ****** in
the meridian out and beats them senseless.
the kid had the right of way and neither had the right to do what they
did.
it is called a go around folks and every meridian can do one.
the pair of ******* just killed a pilot through combined negligence.
dont let them get away with it.
Stealth Pilot
Old July 18th 07, 01:13 PM posted to rec.aviation.piloting
Mxsmanic
Gig 601XL Builder writes:
knowledge.
Will this also apply to inexperienced air traffic controllers?
Student pilots are advised to tell ATC that they are student pilots; I don't
see any reason why they must be "flagged." They are not trying to keep it a
secret.
Old July 18th 07, 01:59 PM posted to rec.aviation.piloting
El Maximo
"Stealth Pilot" wrote in message
I looked at this thread very early in the morning (before my coffee) and
read:
"Investigators Say Student Pilots Should Be Flogged"
Maybe the controller should be flogged.
Old July 18th 07, 03:25 PM posted to rec.aviation.piloting
Peter Dohm
"Andy Hawkins" wrote in message
Hi,
I'm not too sure of this. If you read the full report, I think it's said
that there was a change of ATC personnel between the time the student took
off, and when he landed.
I could be mis-remembering of course.
Andy
My point, which Judah phrased much better, was simply that "stuff happens"
and it makes no sense to add more regulations and complexity every time an
accident or incident indicates a possible gap in the rules--or to try to
find or enact a crime that might fit every situation. All of us will die;
but, if we expend less effort fretting about unusual causes, most of us
would live more complete and enjoyable lives before our death.
However, I did only scan the report on line, which never results in my best
performance; so I have now printed it. I have a rather long gap in my
schedule later today, and will read it in its entirety.
Peter
Old July 18th 07, 03:36 PM posted to rec.aviation.piloting
Peter Dohm
doing
"Unable,
student pilot."
Travis
Lake N3094P
PWK
I think that all instructors attempt to do that, with varying results; and I
agree that "unable" needs to be part of every pilot's vocabulary. It seems
to be the real-life version of a "pause button" and excessive use indicates
a need for additional training; but it can help in avoiding dangerous
conditions.
Peter
Old July 18th 07, 04:12 PM posted to rec.aviation.piloting
JGalban via AviationKB.com
did.
What exactly did the pilot of the Meridian do that has upset you so?
Message posted via http://www.aviationkb.com
Old July 18th 07, 09:11 PM posted to rec.aviation.piloting
Andy Hawkins
Hi,
While that's true, and adding more and more 'rules' isn't necessarily going
to help, it can't be harmful to have a standardised method for inexperienced
(not just student) pilots to identify themselves as such to ATC and other
pilots.
'Heathrow Tower, Tyro G-ANDY base' isn't much more to say, and can convey
this inexperience without too much extra effort.
Military fields already have a mechanism for doing this (the 'Tyro' above is
the military term). Extending this to civilian air traffic seems as good a
way as any to me.
I do agree though, there appear to have been a lot of small isolated factors
in this accident that just all came together to make its consequences so
bad.
Andy
Old July 18th 07, 09:18 PM posted to rec.aviation.piloting
Doug Semler
On Jul 17, 12:23 pm, "Gig 601XL Builder"
I had a side thought that is somewhat similar; I was watching/
listening to a recording of a mayday flight in (I believe) Britain,
and the communications initiated from the pilot of the emergency craft
prefixed his callsign with Mayday (e.g. Mayday Company 1234 is turning
to heading 120 requesting runway 5R). I don't remember the exact
details, but it was a bird strike on takeoff (i think the vid is on
youtube).
Anyway, I bring it up because of a previous discussion regarding the
ATC handling of the American flight that ended up "accepting" a runway
assignment that was somewhat inappropriate for their situation. From
what I remember, some of the ATC transcripts involved an initial
landline comm between approach and tower, with approach requesting the
tailwind runway, but not telling tower that the pilot had declared an
emergency. If the AA pilot was prefixing his callsign with the
"mayday" tag, the first communcation between him and twr would have
alerted the tower controller that the runway request was not
"ordinary". (of course, IIRC, the initial controller told the pilot
to squawk 7700 as well which would be yet another reminder). It seems
(to me at least) that it could also help with the following:
New pilots on frequency would be immediately aware of the emergency
situation being handled on the frequency,
Controllers would be reminded of the priority of the flight's
handling,
On initial callup on a handoff by the emergency craft, the new
controller would be immediately reminded of the mayday sit.
Old July 18th 07, 09:42 PM posted to rec.aviation.piloting
Ken Finney
Hi,
happens"
an
die;
going
inexperienced
pilots.
is
way as any to me.
factors
bad.
How about squawking "1201" for student pilots?
Options After Items Flagged as Unairworthy (was TBO and Airworthiness) JB Owning 19 April 19th 07 10:22 PM
New York tries to ground student pilots, again Gig 601XL Builder Piloting 4 February 23rd 07 10:06 PM
NY State wants to fingerprint student pilots Roy Smith General Aviation 7 July 15th 06 02:07 PM
KLN94 "Flagged" When Database Out of Date AMW Instrument Flight Rules 12 September 14th 04 05:20 PM
