The ethanol scam
Old July 20th 07, 11:28 PM posted to rec.aviation.piloting
Bertie the Bunyip's more macho brother via AviationKB.com
Default The ethanol scam
Bertie the Bunyip wrote:
Bwahwahawhawhawhawhahwhahwhahhwhahwhhahwhahhwhah ¬
Bertie
Hey....
call mom
Message posted via http://www.aviationkb.com
  #82
Old July 21st 07, 12:31 AM posted to rec.aviation.piloting
Bertie the Bunyip[_19_]
"Bertie the Bunyip's more macho brother via AviationKB.com" u33403@uwe
wrote in news:7579783508db1@uwe:
Bertie
Hey....
call mom
Did already, she's fine.
Bertie
  #83
Old July 21st 07, 12:32 AM posted to alt.global-warming,rec.aviation.piloting
Roger (K8RI)
On Fri, 20 Jul 2007 17:12:30 -0900, Whata Fool wrote:
On Fri, 20 Jul 2007 00:14:08 -0500, "Maxwell" wrote:
"Whata Fool" wrote in message
Regardless, ethanol production is needed, and the more the
better.
What do you consider to be the "pros" of ethanol?
For the US, it reduces oil imports, billions of gallons per
year.
First, when compared to gas none of my statements are negative against
alcohol.
It might, not does and even pushing the implementation to the limits
predictions are it will only be able to take care of the increased
demand for fuels over time.
It will provide the means to do away with farm subsidies,
if only congress has the brains to make it happen.
It might
It is much cleaner burning, and with the engine tuned for it,
it has more power, check Indy 500 for details.
Cleaner burning, yes. More power, not a chance. Alcohol only contains
60 of the energy of gas. In Indy they get more power by burning more.
A lot more and under more pressure. They are also running very
expensive engines at very high RPM and expected to last for one race.
It is carbon neutral, as is all animal and human emissions of
CO2.
It could be if the growing chain also used it rather than fossil
fuels.
The Indy use alcohol because of gasoline fire, but check that
out too.
When oil becomes too expensive and in short supply, ethanol
is one of the biofuels that is easy to make.
And expensive although the price is currently hidden in subsidies
rather than showing up at the pump.
There is nothing bad about ethanol, although because it has
an oxygen atom in the molecule, it needs less air, so a bigger tank may
be needed for the same miles per tank.
(Miles Per Gallon is not a criteria for different fuels,
Miles Per Dollar is the important factor).
Time we get done alcohol will be at least as expensive as the highest
price we've seen for gas so far.
  #84
Old July 21st 07, 12:34 AM posted to rec.aviation.piloting
Roger (K8RI)
On Fri, 20 Jul 2007 15:14:06 -0700, C J Campbell
On 2007-07-19 08:31:40 -0700, Jay Honeck said:
As gas -- and corn -- prices creep ever higher, everyone in my great
State of Iowa is all ablush with talk of riches pouring in, thanks to
ethanol production. They can barely contain their glee at this
remarkable turn of economic fortune. (Remember, just a few years ago
farmers here had one foot in the grave, and the other on a banana
peel...)
There have already been riots in Mexico because of the corn shortage.
But you will have about as much luck fighting "Big Corn" as you did
"Big Oil."
What a revelation:-)) The game's the same, only the faces change.
  #85
Old July 21st 07, 12:47 AM posted to alt.global-warming,rec.aviation.piloting
Eeyore[_2_]
Whata Fool wrote:
it [ethanol] has more power
Sorry to disappoint you , that simply isn't true.
An engine optimally designed to burn ethanol (usually with a turbo) can indeed
produce more horsepower on ethanol than it does running on gasoline but it does
that at the expense of burning more gallons of the ethanol.
What it does mean is that for a given power output the engine can be smaller if
you use ethanol as a fuel instead of gasoline. And that's why racers like it
since smaller = lighter = faster (or simply more horsepower from the same engine
size).
Graham
  #86
Old July 21st 07, 12:48 AM posted to alt.global-warming,rec.aviation.piloting
Eeyore[_2_]
Dan Luke wrote:
That does not mean that there is any considerable doubt in the scientific
community that ACC is real.
You have to be joking.
It's rapidly and rightly becoming the most disputed lie ever.
Graham
  #87
Old July 21st 07, 12:50 AM posted to alt.global-warming,rec.aviation.piloting
Eeyore[_2_]
And also because an engine runs more efficiently on ethanol if designed properly
to use it.
Ethanol may only have 60% of the thermal energy of gasoline but but the extra
efficiency makes up for about half of that difference.
Graham
  #88
Old July 21st 07, 12:52 AM posted to alt.global-warming,rec.aviation.piloting
Eeyore[_2_]
I'm sure it'll never be any cheaper ! That's not what it's about.
Graham
  #89
Old July 21st 07, 12:56 AM posted to rec.aviation.piloting
Eeyore wrote in
it,
more. A lot more and under more pressure.
designed properly to use it.
the extra efficiency makes up for about half of that difference.
Good grief. what a fjukwit.
Graham
  #90
Old July 21st 07, 12:58 AM posted to rec.aviation.piloting
Eeyore wrote in
can indeed produce more horsepower on ethanol than it does running on
gasoline but it does that at the expense of burning more gallons of
the ethanol.
smaller if you use ethanol as a fuel instead of gasoline. And that's
why racers like it since smaller = lighter = faster (or simply more
horsepower from the same engine size).
Whoosh.
Bertie
Graham
buy your sailplane scam? [email protected] Soaring 23 December 13th 05 06:13 PM
SCAM [email protected] Soaring 0 August 26th 05 12:26 AM
web scam ? Chip Fitzpatrick Soaring 0 August 10th 04 11:54 AM
Scam Y/N ? Stuart King Instrument Flight Rules 6 November 13th 03 10:52 PM
