Air Traffic/Pilot Terminology
Old July 23rd 07, 01:45 AM posted to rec.aviation.piloting
Peter R.
Default Air Traffic/Pilot Terminology
On 7/22/2007 1:31:09 PM, " wrote:
I was recently on a flight where I was able to listen to the Pilots
speak to Air Traffic control. It was quite fascinating but I
understood very little of what they were saying.
If you desire to listen to more ATC lingo, click your way over to
http://www.liveatc.net where there are over 150 live audio streams from ATC
facilities in the US and around the world.
Peter
Old July 23rd 07, 01:47 AM posted to rec.aviation.piloting
Tom L.
Both FAA links below are obsolete. Go he
http://www.faa.gov/airports_airtraff.../publications/
and follow the links to Aeronautical Information Manual and
Pilot/Controller Glossary.
On Sun, 22 Jul 2007 21:57:59 +0200, Thomas Borchert
The AIM previously mentioned is available he
http://www.faa.gov/atpubs/AIM/AIM.pdf
The Pilot/Controller Glossary, also helpful, is he
http://www.faa.gov/atpubs/PCG/PCG.pdf
If you are really interested, the book "Say Again" published by ASA
(www.asa2fly.com) and written by Bob Gardner who also frequents this
forum, is invaluable.
As for the slang mentioned by kontiki, it shouldn't happen.
Communications should be strictly standard as defined in the
publications above. But there are humans involved...
Old July 23rd 07, 02:10 AM posted to rec.aviation.piloting
Marty Shapiro
Newps wrote in
Tina wrote:
Aren't "heavy's" allowed to go faster under 10,000 feet as well?
No.
Isn't the limit 250 in CBAS regardless of altitude?
Marty Shapiro
Silicon Rallye Inc.
(remove SPAMNOT to email me)
Old July 23rd 07, 02:55 AM posted to rec.aviation.piloting
Newps
Marty Shapiro wrote:
Newps wrote in
No.
No.
Old July 23rd 07, 02:57 AM posted to rec.aviation.piloting
Just wanted to thank everyone for their responses. Quite fascinating
stuff here. Thanks again.
Also, I was watching United 93 and they kept using the term "squawk".
I looked it up in a few resources mentioned but since I have no
aviation experience couldn't quite grasp the meaning. What exactly is
a squawk and what is it's function?
And you can listen to this online!!??? Awesome. anyone know of some of
the better sites?
T
Old July 23rd 07, 03:06 AM posted to rec.aviation.piloting
Peter R.
the better sites?
I posted the best resource for online ATC streaming. Did you miss that post
or is there something in my post's headers that results in them being
filtered?
Peter
Old July 23rd 07, 03:19 AM posted to rec.aviation.piloting
filtered?
Peter,
I didn't miss your post. It said there were over a 150 options. I was
wondering if you could recommend a few. Or are they all the same.
Thank you for posting that information!
Zan
Old July 23rd 07, 04:07 AM posted to rec.aviation.piloting
Judah
" wrote in
ps.com:
the better sites?
If it were me, I would pick one of the "Top 30" from an airport near a
place I am familiar with - near where I live or where I've been in the
past. There are lots of good options - New York's JFK, Boston's Logan, and
Orlando (everybody's been to Disney, right?) Being from New York, KJFK is
an easy pick for me, but there are plenty of cities up there that might
work better for you.
"Sqauwk" refers to the transponder code assigned to an aircraft. Most
airplanes have a transponder in them that communicates with Air Traffic
Control (ATC) Radar. Certain areas of the country require a plane to have a
transponder for entry, but less populated areas do not require it.
Most modern transponders can communicate both position and altitude back to
the radar system. Some of the new ones even have two-way communication
where other traffic and weather information is "beamed" back to the
airplane's system.
In order to identify a specific airplane, ATC will assign a "sqauwk code"
for the pilot to enter into his transponder to uniquely identify that plane
to the system. The code is typically a four digit number. Even
"uncontrolled" airplanes with transponders squawk a specific code (1200)
and appear on the ATC radar screen, even if they are not talking to ATC.
This allows ATC (and other planes with anti-collision systems) to "see"
them and ensure that they don't fly too close to them. There are also a few
"special codes" that pilots can enter into their transponder to alert ATC
to certain types of emergencies (like a radio failure or hijacking, when
telling ATC about it may be impossible).
Enjoy!
Old July 23rd 07, 06:17 AM posted to rec.aviation.piloting
Marty Shapiro
Newps wrote in news:boWdnW0rZd3klznbnZ2dnUVZ_o-
No.
Ok. I must have missed the change to 91.117. Do you know when it was
changed?
This is the version of 91.117 I'm familiar with:
§ 91.117 Aircraft speed.
(a) Unless otherwise authorized by the Administrator, no person may operate
an aircraft below 10,000 feet MSL at an indicated airspeed of more than 250
knots (288 m.p.h.).
(b) Unless otherwise authorized or required by ATC, no person may operate
an aircraft at or below 2,500 feet above the surface within 4 nautical
miles of the primary airport of a Class C or Class D airspace area at an
indicated airspeed of more than 200 knots (230 mph.). This paragraph (b)
does not apply to any operations within a Class B airspace area. Such
operations shall comply with paragraph (a) of this section.
(c) No person may operate an aircraft in the airspace underlying a Class B
airspace area designated for an airport or in a VFR corridor designated
through such a Class B airspace area, at an indicated airspeed of more than
200 knots (230 mph).
(d) If the minimum safe airspeed for any particular operation is greater
than the maximum speed prescribed in this section, the aircraft may be
operated at that minimum speed.
[Doc. No. 18334, 54 FR 34292, Aug. 18, 1989, as amended by Amdt. 91–219, 55
FR 34708, Aug. 24, 1990; Amdt. 91–227, 56 FR 65657, Dec. 17, 1991; Amdt.
91–233, 58 FR 43554, Aug. 17, 1993]
Marty Shapiro
Silicon Rallye Inc.
VFR terminology in Class B Matt Piloting 17 February 27th 07 03:55 PM
Pressure Altitude and Terminology Icebound Piloting 0 November 27th 04 09:14 PM
Traffic 2004 vs Ultimate Traffic Tlewis95 Simulators 3 August 13th 04 05:39 AM
New Aviation Terminology DeltaDeltaDelta Piloting 45 December 4th 03 08:31 AM
Humour: CO DATA PAGE TERMINOLOGY CAT:BTN SUB:DES PGE:TRM Dave Kearton Military Aviation 0 September 24th 03 10:38 AM
