The other day I shot the VOR approach into SMO for the first time in
low actual. I've often looked at that approach as one of the most difficult I've seen published so it was interesting to actually try it. The weather was 008OVC with something like 3sm HZ. I touched down about 3/4 down the runway and was able to stop without a problem. However, while taxiing back, I noticed a Gulf Stream land right on the numbers. There is no way you can tell me he properly flew the approach and was able to touch on the numbers. The approach is published as a circle to land (I assume because of the extreme nature of the decent) but they certainly were not offering to allow anyone to circle. In fact there was a steady line of jets coming in, it would probably have been unlikely to get a circle approved. Last night I departed. AWOS was reporting 005OVC. I took off right around 21:10. There was a large Citation right behind me picking up his clearance. I didn't ever hear him depart on approach frequency so I'm assuming he missed his curfew and his execs got stranded. -Robert |
"Robert M. Gary" wrote:
The other day I shot the VOR approach into SMO for the first time in low actual. I've often looked at that approach as one of the most difficult I've seen published Why do you think this is difficult? The only thing I see that's tricky about it is that you need to keep up a steep descent (360 ft/nm from DARTS to the threshold, and about 500 ft/nm from CULVE to the threshold, by my calculations), but that's just a matter of energy management. However, while taxiing back, I noticed a Gulf Stream land right on the numbers. There is no way you can tell me he properly flew the approach and was able to touch on the numbers. Why not? Follow the descent profile until you can see the runway, then fly the rest visually. The only thing is you need to realize ahead of time that this is a steep descent profile and you'll need to reduce power and/or add drag to stay on the descent profile without picking up too much speed. In a spam can, I would certainly be flying this with the first notch of flaps in from DARTS or FAC intercept if on vectors. |
On Jul 23, 10:58 am, Roy Smith wrote:
"Robert M. Gary" wrote: The other day I shot the VOR approach into SMO for the first time in low actual. I've often looked at that approach as one of the most difficult I've seen published Why do you think this is difficult? Landing from 1100 feet when less than 2 miles from the runway. Notice the VOR is on the OTHER side of the runway. -Robert |
Roy Smith wrote:
"Robert M. Gary" wrote: The other day I shot the VOR approach into SMO for the first time in low actual. I've often looked at that approach as one of the most difficult I've seen published Why do you think this is difficult? The only thing I see that's tricky about it is that you need to keep up a steep descent (360 ft/nm from DARTS to the threshold, and about 500 ft/nm from CULVE to the threshold, by my calculations), but that's just a matter of energy management. The gradient from CULVE to the threshold is all that matters and that is well over 600 feet per mile. You need to have the Jepp airport diagram to figure that out. |
I see no problem with the weather 800/3 as you point out. Inside BEVEY drive
down to 680 outside CULVE, and have 3 miles to descend 505 feet. Any jet will do that all day long. Karl "Curator" N185KG "Robert M. Gary" wrote in message ups.com... The other day I shot the VOR approach into SMO for the first time in low actual. I've often looked at that approach as one of the most difficult I've seen published so it was interesting to actually try it. The weather was 008OVC with something like 3sm HZ. I touched down about 3/4 down the runway and was able to stop without a problem. However, while taxiing back, I noticed a Gulf Stream land right on the numbers. There is no way you can tell me he properly flew the approach and was able to touch on the numbers. The approach is published as a circle to land (I assume because of the extreme nature of the decent) but they certainly were not offering to allow anyone to circle. In fact there was a steady line of jets coming in, it would probably have been unlikely to get a circle approved. Last night I departed. AWOS was reporting 005OVC. I took off right around 21:10. There was a large Citation right behind me picking up his clearance. I didn't ever hear him depart on approach frequency so I'm assuming he missed his curfew and his execs got stranded. -Robert |
karl gruber wrote:
I see no problem with the weather 800/3 as you point out. Inside BEVEY drive down to 680 outside CULVE, and have 3 miles to descend 505 feet. Any jet will do that all day long. Karl "Curator" N185KG So, now you're past the runway and landing on the VOR shack. It is 1.54 miles from CULVE to the beginning of the runway. |
karl gruber wrote:
I see no problem with the weather 800/3 as you point out. Inside BEVEY drive down to 680 outside CULVE, and have 3 miles to descend 505 feet. Any jet will do that all day long. Karl "Curator" N185KG 1120 at CULVE. 175 feet airport elevation. Difference 945 feet. Distance from CULVE to runway 1.54 miles. |
Where are you digging up such erroneous thoughts?
With 800/3 you'll be way outside CULVE when you see the runway. That's the difference between the pros that were landing without any fan fair and you, without a clue. Karl "B" wrote in message ... karl gruber wrote: I see no problem with the weather 800/3 as you point out. Inside BEVEY drive down to 680 outside CULVE, and have 3 miles to descend 505 feet. Any jet will do that all day long. Karl "Curator" N185KG So, now you're past the runway and landing on the VOR shack. It is 1.54 miles from CULVE to the beginning of the runway. |
Not with DME, or do you think that a Gulfstream wouldn't have DME??
Read the plate! Karl "B" wrote in message ... karl gruber wrote: I see no problem with the weather 800/3 as you point out. Inside BEVEY drive down to 680 outside CULVE, and have 3 miles to descend 505 feet. Any jet will do that all day long. Karl "Curator" N185KG 1120 at CULVE. 175 feet airport elevation. Difference 945 feet. Distance from CULVE to runway 1.54 miles. |
On Jul 23, 1:18 pm, "karl gruber" wrote:
Where are you digging up such erroneous thoughts? No, he's right. The VOR (and therefor the DME readings) are on the *OTHER* side of the runway. So the distance from CULVE to the threshold is pretty short, and creates a pretty wild let down from 1000 feet. -Robert |
| SDF Approach? | A Guy Called Tyketto | Piloting | 9 | April 18th 07 02:32 AM |
| First LPV approach | Viperdoc[_4_] | Instrument Flight Rules | 0 | March 5th 07 04:23 AM |
| ILS or LOC approach? | Dan Wegman | Instrument Flight Rules | 17 | May 10th 05 12:41 AM |
| No FAF on an ILS approach...? | John Harper | Instrument Flight Rules | 7 | December 24th 03 04:54 AM |
| Completing the Non-precision approach as a Visual Approach | John Clonts | Instrument Flight Rules | 45 | November 20th 03 06:20 AM |
