#31
What you advocate is a violation of the FARs, but I guess that is the
way it is with Cessna Curators. So, what is your minimums busting scheme when the weather is right at minimums; i.e., 600 and 1? karl gruber wrote: Where are you digging up such erroneous thoughts? With 800/3 you'll be way outside CULVE when you see the runway. That's the difference between the pros that were landing without any fan fair and you, without a clue. Karl "B" wrote in message ... karl gruber wrote: I see no problem with the weather 800/3 as you point out. Inside BEVEY drive down to 680 outside CULVE, and have 3 miles to descend 505 feet. Any jet will do that all day long. Karl "Curator" N185KG So, now you're past the runway and landing on the VOR shack. It is 1.54 miles from CULVE to the beginning of the runway. |
#32
Man, you are an accident looking for a place to happen. There are
buildings over 800 feet high inside your minimums-busting 6.7 miles. karl gruber wrote: No, the VIS is 3. It doesn't matter where the VOR is. You can be at 680 6.7 miles out. When you are 3 miles from the AIRPORT, it will be in sight. Karl |
#33
Do you have an instrument rating?
Help me understand how DME permits you to descent to 680 "far before CULVE." karl gruber wrote: Not with DME, you'll be at 680 far before CULVE. Karl "Robert M. Gary" wrote in message ups.com... On Jul 23, 1:18 pm, "karl gruber" wrote: Where are you digging up such erroneous thoughts? With 800/3 you'll be way outside CULVE when you see the runway. No, with 800 foot ceiling you will be at 1120 when at CULVE, making it hard to see the runway through the clouds. -Robert |
#34
I am reading the plate. Apparently, you are not.
karl gruber wrote: Not with DME, or do you think that a Gulfstream wouldn't have DME?? Read the plate! Karl "B" wrote in message ... karl gruber wrote: I see no problem with the weather 800/3 as you point out. Inside BEVEY drive down to 680 outside CULVE, and have 3 miles to descend 505 feet. Any jet will do that all day long. Karl "Curator" N185KG 1120 at CULVE. 175 feet airport elevation. Difference 945 feet. Distance from CULVE to runway 1.54 miles. |
#35
Roy Smith wrote:
You're not thick, the Curator is. In article , "karl gruber" wrote: No. You can be 6.7 miles out at 680/DME. Maybe I'm just thick, but that's not how I read the chart. After DARTS, you can descend to 2600. After BEVEY, you can descend to 1120. What happens after that depends on whether you can identify CULVE or not. If you can identify CULVE, once you reach it, you can descend to 680. Without CULVE, you have to stay at 1120 until you have the runway in sight. Look at the plan view. There's a 863 tower at what looks like about 1/2 mile right of the FAC. I'm sure that's the controlling terrain for the 1120 MDA between BEVEY and CULVE. Actually, it is several very tall building in Century City. At 680 feet out there you die. To identify CULVE, you need one of two things: either DME in the aircraft, or the tower has to be open AND you have to be in radar contact. It doesn't explicitly say so on the chart, but I assume the tower has a BRITE scope in the cab with CULVE marked on it and will call it for you on tower frequency. CULVE is 1.6 nm from the threshold. If you cross it at 1120, you're 945 feet AGL (referenced to the runway surface). So, to hit the numbers, you need to keep a 590 ft/nm descent gradient from CULVE to the runway. Looking at it another way, at 90 kts and no wind, you need an 885 ft/min descent rate. That's fast, but not outrageously so. It's about twice as steep as an ILS. It's certainly the kind of approach you need to brief ahead of time and know what you're going to need to do before you get there. |
#36
pgbnh wrote:
I think all but one of the posters have missed the fact that the MDA is not 1120 but 680. If indeed the vis was 3 miles, then the runway should have been in sight from the MDA of 680 feet about a mile OUTSIDE of Culve. (Remember what you can do once you have the runway in sight????) At which point it's not a particularly big deal to lose 500 feet to land on the numbers. Maybe even crossing Culve at 3-400 feet agl. "Hamish Reid" wrote in message ... The MDA is 1120 unless you have DME. If you have DME then the MDA is 680 once you pass CULVE. You cannot descend below 1120 prior to CULVE even if you see the runway unless you either cancel, get a contact approach, or a visual approach. Having said that, when the weather is good, folks who know the airport descend out of 1120 on the 4 degree PAPI. But, sometimes it is 600 and 1 around there. |
#37
karl gruber wrote:
Correct. That's why there's a little * next to the 1120*. And, that little "*" (black ball number 1 on Jepp chart) means you can descend to 680 ONCE PASSING CULVE. Karl "Doug Semler" wrote in message oups.com... On Jul 23, 5:28 pm, "karl gruber" wrote: You can cross CULVE at 680 because the chart says "CULVE DME/RADAR MINIMA* 680-1" You can descend to 680 past BEVEY. Look at the chart...........that's how it's read. So, iff you have DME and RADAR, the _1120_ in profile view changes to _680_, right? That is a *bit* confusing. |
#38
On Jul 23, 5:41 pm, "pgbnh" wrote:
Note this is a VOR or GPS approach. Sorry if I just assumed that there would be on-board EITHER a DME or an IFR certified GPS that would provide the distance-measuring requirements of the DME/Radar minima. Pretty good chance the jet in question had both. And maybe you understand this, but youir reference to Radar implies that maybe you do not. The 'Radar' reference is NOT referring to whether the plane is radar equipped, but rather whether there is radar coverage from the ground. Which in fact should allow an aircraft WITHOUT DME to descend to 680 (if receiving advisories from the tower/approach) No I completely understand what RADAR means. I know it means radar contact from ATC. I mistyped an "and" instead of "or" in a previous post about whether the different crossing restrictions were allowed if and only if there was DME on board or radar guidance from ATC. shrug It seems inconsistent with other uses of "/" (e.g. VOR/DME) meaningthat both are required. |
#39
They can call BEVEY, too, workload permitting.
karl gruber wrote: Exactly, you don't need DME or GPS. ATC can tell you where CULVE is........with THEIR Radar. |
#40
Right, dive to 1120 and drive to CULVE, then dive to 680.
karl gruber wrote: Once inside BEVEY you're good for 680. There is no glideslope and it's "Dive and Drive." That's why the pros make it in with no trouble, they can read charts. Karl |
VOR approach SMO | Robert M. Gary | Piloting | 124 | August 3rd 07 02:17 AM |
first approach in IMC | G. Sylvester | Instrument Flight Rules | 10 | July 12th 05 02:14 AM |
No FAF on an ILS approach...? | John Harper | Instrument Flight Rules | 7 | December 24th 03 03:54 AM |
Completing the Non-precision approach as a Visual Approach | John Clonts | Instrument Flight Rules | 45 | November 20th 03 05:20 AM |
Brief an approach | Ditch | Instrument Flight Rules | 11 | October 14th 03 12:10 AM |
