Cessna's new LSA: "Skycatcher"
Old July 24th 07, 03:33 PM posted to rec.aviation.piloting,rec.aviation.owning
Phil
Default Cessna's new LSA: "Skycatcher"
On Jul 23, 7:13 pm, "Morgans" wrote:
"Scott Skylane" wrote
Don't knock the O-200 quite so fast. The 162 is getting the "D" model engine,
the Type Spec of which hasn't even been issued, yet. I would be surprised if
Continental doesn't incorporate some improvements to the cylinder design. As
a rugged, easy-to-maintain light aircraft powerplant, I personally think they
made a good choice.
I agree, most completely!
The fact that it has the O-200 would make me buy it, rather than the Rotax
powered LSA's.
Anyone know what a weight comparison would be for a firewall forward
installation of a 200 vs. a 912?
Jim in NC
I don't know what the firewall-forward weights would be, but the basic
dry weight of the Rotax is 132 lbs versus 170 lbs for the Continental.
  #44
Old July 24th 07, 05:23 PM posted to rec.aviation.piloting,rec.aviation.owning
In rec.aviation.owning Larry Dighera wrote:
: On Tue, 24 Jul 2007 13:28:00 +0000 (UTC),
: wrote in
: I applaud the Rotax design, although I agree that it's a bit
: too high-strung for using in high-volume certified aircraft.
: Thank you for your informative analysis of the differences between air
: and liquid cooled aircraft engines, but I'm having a little difficulty
: inferring your meaning in your sentence quoted above.
: In your opinion, what causes you to characterize the Rotax 912 liquid
: engine as being "too high-strung?" Is it a lack of design robustness;
: is the Rotax engine more fragile than the Cont. O-200? Does it
: require more frequent maintenance?
It's a *very* small displacement to generate the kind of power that it is... 1.35 liters, 5800
RPM, 10.5:1 CR to me is "high-strung."
http://www.kodiakbs.com/engines/912ULS.htm
I'm thinking something of a bit larger displacement, a little less RPM, with a bigger discrepency
between max power and continuous power... in other words, a bit more derated. I realize that this would
come with a weight penalty which is a bigger deal for the max-gross limited LSA. That should allow for a
longer TBO.
-Cory
* Cory Papenfuss, Ph.D., PPSEL-IA *
* Electrical Engineering *
  #45
Old July 24th 07, 06:35 PM posted to rec.aviation.piloting,rec.aviation.owning
Al G[_2_]
"karl gruber" wrote in message
I see the very light jet market, it replaces King Airs even high end
piston twins...I dont see the LSA NEW Market.
Have I missed something here?
Robert
The VLJ competes with a King Air but can never replace it. Even the oldest
KA 90 from 1965 will carry 9 passengers and all their bags.
karl
And be able to stop and taxi on an icy runway/taxiway. I could land
and taxi into
places where I couldn't walk away from the airplane.
Al G
  #47
Old July 24th 07, 06:50 PM posted to rec.aviation.piloting,rec.aviation.owning
Jim Stewart
C J Campbell wrote:
On 2007-07-23 07:31:11 -0700, Phil said:
On Jul 23, 4:00 am, Thomas Borchert
Phil,
I'm sorry, but SkyCatcher?? I think they should have just stuck with
Cessna 162 and left it at that.
You seem to forget that the other Cessnas all have silly names, too.
Thomas Borchert (EDDH)
No, I knew that. But in silliness, this one goes to eleven. It
sounds like a name an eight year old would pick for the airplane he
just made out of scrap wood.
I don't think it is as bad as 'Stationair.' Sounds like something slow
and ugly, which it is, but they didn't need to call it that . :-)
You could argue that any technical field that
uses terms like flapperon, gascolator, stabilator
and elevon shouldn't have an issue with a marginal
aircraft name (:
  #49
Old July 24th 07, 07:04 PM posted to rec.aviation.piloting,rec.aviation.owning
Jim Stewart
engine, the Type Spec of which hasn't even been issued, yet. I would
be surprised if Continental doesn't incorporate some improvements to
the cylinder design. As a rugged, easy-to-maintain light aircraft
powerplant, I personally think they made a good choice.
Rotax powered LSA's.
And can anyone tell us what the maintenance
schedule for the O-200 is?
For the 912, I inspect every 25 hours and do
a plug and oil change every 50 hours. Plugs
are $3 each x 8, oil filter is about $17 and
oil is $10/quart x 3.
Dealer inspection at 100 hour intervals mostly
for the gearbox.
Cessna's new LSA: "Skycatcher" Jim Logajan Piloting 107 September 23rd 07 01:18 AM
Old polish aircraft TS-8 "Bies" ("Bogy") - for sale >pk Aviation Marketplace 0 October 16th 06 07:48 AM
More on Cessna's new "Cirrus Killer" [email protected] Piloting 49 November 13th 05 02:29 PM
