Slick mags when mine are good?
Old July 27th 07, 01:41 PM posted to rec.aviation.piloting
Denny
Default Slick mags when mine are good?
The OP's original mechanic is a manipulative weasel who was determined
to make a profit off selling a new set of mags...
I made the opposite decision on my twin... I remained with Bendix and
traded the 4 mags off on a remanufactured set... They are properly
timed and the carbs are right and I have a good battery... No Lycoming
with magnetos starts better than my pair - hot or cold...
If I have a problem at a distant airport, any airplane mechanic worth
the name will have the common Bendix parts on hand - and usually some
donor mags for the less common parts... With Slick I will be down
while they order a new mag and wait for delivery...
denny
Old July 27th 07, 04:09 PM posted to rec.aviation.piloting
FlyWithTwo
Hi Steven,
I once owned a T207 that had Slicks on a TSIO520. During one annual,
my mechanic suggested that I upgrade to newer ones, as the ones on
there were "very old". I was a new owner and took his suggestion. I
don't recall problems prior to this. In any event, I had trusted his
judgement. I also had a Mooney M20C with the Lycoming O360 and Bendix
mags. I had no mag probems in 400 hours of flying when I owned the
plane, and the engine ran beyond its 1800 hour TBO. Current plane is
a C310 and have Bendix mags on the IO470s. I've had it for 7 years
and the engines just made it to TBO for the second time - they are the
original engines. Mag drops are always consistent, the engines are
eager to start. I plan on exchanging the Bendix mags for overhauled
units of the same type when I have the engines overhauled in 2008. I
bought the magneto overhaul kits from Aircraft Spruce and carry them
with a few other spare parts in the plane, just in case. That's
proven to be good insurance, as I haven't needed to use them yet. The
equipment on there is what's worked on the plane and I'm inclined to
stick with it. That's my 2 cents worth.
Brian
Old July 27th 07, 10:45 PM posted to rec.aviation.piloting
SteveN1660J via AviationKB.com
I think your two cents are worth about a million bucks. Thanks for the info
Brian. I do the same and carry the box of mag parts in the plane. My O320
starts on the first half a prop spin now that the engine and mags are right.
This of course is one of the reasons I bought the plane.
FlyWithTwo wrote:
Hi Steven,
Brian
Message posted via AviationKB.com
http://www.aviationkb.com/Uwe/Forums...ation/200707/1
Old July 27th 07, 10:51 PM posted to rec.aviation.piloting
Thanks Denny, thats why I wrote here. I was thinking about calling the FAA
when this ordeal with getting my money back from the first AP. I truely hate
when someone tries to run a scam, unfortunately I only look like an idiot I
guess. Thats ok, I'll get em. I will remain with my perfect running Bendix.
My log books confirm that the mags are not yet ready for overhaul.
denny
Old July 28th 07, 06:19 AM posted to rec.aviation.piloting
Morgans[_2_]
"SteveN wrote
My O320
You do realize that it starting easy like that is butter. (smooth)
The bread is having it continuing to run without stopping - until you command it
to do so ! ! ! VBG
Jim in NC
Old July 28th 07, 08:17 AM posted to rec.aviation.piloting
My bread and butter is not going to the first mechanic again.
Morgans wrote:
"SteveN wrote
My O320
to do so ! ! ! VBG
Message posted via http://www.aviationkb.com
A coworker of mine........... Mark and Kim Smith Military Aviation 13 June 25th 14 07:57 PM
I'll have mine well done pic32050.jpg [1/4] Andrew-S Aviation Photos 0 June 1st 07 05:56 AM
Lyc O-235 How much room needed between mags and firewall to remove mags DonMorrisey Home Built 5 October 29th 06 05:01 AM
VW1834 and Slick 4001 Mags M J Veary Home Built 4 March 5th 05 12:23 AM
FA: Slick Mags (used) 600 series with harness BFC Aviation Marketplace 0 June 24th 04 05:21 PM
