Off Topic - Application to save daily web data??
Old July 28th 07, 02:12 PM posted to rec.aviation.soaring
Gary Emerson
Default Off Topic - Application to save daily web data??
Greetings,
While off topic, my application is soaring related.
Does anyone know of an application that would automatically load and
store web data.
What I'd like to have is the daily unysis data saved so that I could go
back and review any date's forecast.
http://weather.unisys.com/gfs/6panel...es_6panel.html
For example, I go fly on Saturday and it's just awesome. I want to
better predict what the conditions that lead up to this were. So I go
back to the forecast images from the preceding week that were
automatically stored so that I can review and then be better prepared in
the future to anticipate great soaring weather.
To do this, it would be great to have an application that would load
URLs automatically at a pre-set interval that would save each day's data
in a logical format.
Anyone know of something like this?
Thanks,
Gary
Old July 28th 07, 04:24 PM posted to rec.aviation.soaring
Martin Gregorie[_1_]
Gary Emerson wrote:
Greetings,
store web data.
How about wget?
http://en.wikipedia.org/wiki/Wget
http://www.gnu.org/software/wget/
The first link describes wget. The second is its home website and says
where to find downloads for various operating systems.
It is a command line utility, so its easy to write a script (BAT file in
WindowSpeak) that automates your task. If your computer is on 24/7 you
can use the job scheduler to automatically run the script once a day.
Use 'at' or 'cron' for Linux and OS/X or the job scheduler for Windows.
HTH
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old July 28th 07, 11:19 PM posted to rec.aviation.soaring
Gary Emerson
Martin Gregorie wrote:
Gary Emerson wrote:
Greetings,
store web data.
go back and review any date's forecast.
in the future to anticipate great soaring weather.
data in a logical format.
How about wget?
HTH
Anything more geared for the less programming inclined by chance?
Old July 29th 07, 01:17 PM posted to rec.aviation.soaring
Gary Emerson wrote:
Greetings,
store web data.
go back to the forecast images from the preceding week that were
How about wget?
in WindowSpeak) that automates your task. If your computer is on 24/7
you can use the job scheduler to automatically run the script once a
day. Use 'at' or 'cron' for Linux and OS/X or the job scheduler for
Windows.
HTH
Not that I know of.
FTP might be a possibility, but that would probably need permission from
the server owner and is much harder to automate. After that you're into
real programming in C or Java.
If you use wget you only have to figure out how to do the job once. If
you write that down you can just retype it whenever you want, but making
a script is better. You simply save the command line in a file (a BAT
file for Windows), and then run that as a sort of shorthand.
wget is very powerful and is tackling a complex task, which is why its
manual is daunting. For instance, you can tell it what to do if a later
run downloads a file with the same name as one you already have.
However, if you're just downloading straightforward data files from a
single directory and the filenames include the date they were made, then
its pretty straightforward to use. Here's an example:
wget -r --random-wait --no-host-directories -P gliding_copy
http://www.gregorie.org/gliding/omarama
That command should be written as a single line, but you'll probably see
it as two lines because your newsreader will line wrap.
Try running it. It copies a story and pictures about a visit to Omarama
from my website, putting it in the gliding_copy/gliding/omarama
directory. This story links to another story about a visit to Boulder,
so that gets copied into gliding_copy/freeflight/october_2001
The parameters on the command line a
-r recursively follow links from copied pages.
If you're just grabbing a set of images you
don't use this.
--random-wait is being kind to the web server by using a
small random wait between each file fetched.
You can also use --wait=n where n is the
number of seconds to wait.
Normally wget would put the stuff in a directory
with the same name as the host (in this case
www.gregorie.org) --no_host_directories tells
it not to do this.
-P gliding_copy
causes the downloaded stuff to be put in a
directory called 'gliding_copy'.
This is where the stuff to be downloaded is found
on the net.
You can contact me directly if you need more advice about wget.
org |
Daily Airbus News john smith Piloting 2 October 21st 06 06:57 PM
Daily Airbus News john smith Owning 0 October 20th 06 10:00 PM
2006 WGC daily write ups [email protected] Soaring 4 June 4th 06 02:07 AM
Landsat (15m or 30m) and Modis (1km twice daily) [email protected] Soaring 7 May 11th 05 09:54 PM
homebuilder websites updated daily? Joa Home Built 6 December 28th 03 07:30 PM
