Whats best? Manual E6B or Electronic?
Old July 28th 07, 07:37 AM posted to rec.aviation.piloting
Fly-For-Fun
Default Whats best? Manual E6B or Electronic?
"Cubdriver" usenet AT danford DOT net wrote in message
I haven't used an E6B since I took delivery on my Garmin 296. I'm sure
that proves me terribly lacking in something or other, but there it
is!
I haven't used one since I had a LORAN installed in my aircraft.
Old July 29th 07, 01:03 PM posted to rec.aviation.piloting
Blueskies
"Airbus" wrote in message ...
If you really want to hone your skills, try using mental calculations. In
much of Europe the E6-B's are little known or used, but student pilots are
encouraged to learn simple mental calculations to solve
speed/distance/time and wind correction problems.
Here's a French link:
http://reseau.xplane.free.fr/formules/formules.html
Other contributors here certainly know English language links to the same
stuff. No need to be a math whiz - memorizing a few formulae will allow
you to do this stuff quickly in your head.
European instructors will tell you that using a calculator, mechanical or
electronic, is too much of a head-down exercise for VFR flight, and
represents a danger. . .
Google:
http://translate.google.com/translat...005-02,GGLD:en
http://tinyurl.com/3y5d79
Old July 29th 07, 07:15 PM posted to rec.aviation.piloting
Big John
Nigel
E6B doesn't run out of batteries )
My E6B is over 35 years old and I work it like I did years ago.
Have an electronic one my wife bought me and never use.
Besides E6B will keep you busy while your dad flies.
Big John
**********************************************88
On Fri, 27 Jul 2007 00:56:10 -0700, "
Hi all
Whats best for simplicity and price? The Metal/Plastic E6B or the
electronic one?
I'm the navigator on my dad's flights
Thanks
Nigel Reeves
Old July 29th 07, 07:23 PM posted to rec.aviation.piloting
Blueskies
Here is an English sentence :
Four score and seven years ago, our Fathers set forth on this continent a new
nation, conceived in liberty, and dedicated to the proposition that all men are
created equal.
Translated to German via AltaVista BabelFish:
Vor vier Kerbe und sieben Jahren, unsere Väter legen auf diesem Kontinent eine
neue Nation fest, begriffen in der Freiheit, und der Angelegenheit eingeweiht,
daß alle Männer verursachtes Gleichgestelltes sind.
And back to English :
Before four notch and seven years, our fathers specify a new nation on this
continent, understood in the liberty, and the affair inaugurated that all men
are caused on an equal footing.
And this is a simple example, using English and German - which are similar
languages! When you go further - English and Korean, for example, you get this
It sleeps equally all men create and before 87 years, our father in this
continent is thought inside freedom, that, it gives it departs in proposition
and the new nation.
So much for Internet translations . . .
Still fun though, and most can get the gist of it. Certainly better than 10 years ago...
And also, most do not go from a known language, to unknown, and back to known.
Old July 29th 07, 08:38 PM posted to rec.aviation.piloting
Airbus
Old July 30th 07, 01:48 AM posted to rec.aviation.piloting
Airbus
created equal.
and the new nation.
Old July 30th 07, 03:30 AM posted to rec.aviation.piloting
Mxsmanic
" wrote:
Hi all
electronic one?
I have an E6B emulator that I run on my computer. It is not a digital E6B
calculator, but rather a computer program that displays the various rings
and numbers that I can then use a mouse to rotate. I have used it to
navigate around the world.
Old July 30th 07, 03:35 PM posted to rec.aviation.piloting
Mark T. Dame
Robert M. Gary wrote:
On Jul 27, 6:59 am, "Mark T. Dame" wrote:
The electronic version is much easier to use, but the metal one always
works. It's unlikely it will ever break and it's batteries will never
run down. Additionally, for some problems, you get a better idea of
what's going on with a mechanical version.
I still carry my paper one (although my GPS actually has one built in
as well). Its interesting that you point out that the electronic ones
are easier to use. I've not found that to be the case. In fact, when a
student arrives for flight training with me and they pull out the
electronic E6B, I cring a bit. I have yet to see any student who can
pull out their electronic E6B in flight, after I've given them a
diversion or something, and do anything other than just fiddle with
it.
OK, to clarify, once you learn how to use it, the electronic one is
easier to use. Bear in mind that I learned on a mechanical one and
didn't get an electronic version until I started working on my
commercial ticket. By then, I well understood what was going on "under
the hood". As I pointed out, for some problems, the mechanical version
is easier to understand.
-m
## Mark T. Dame
## CP-ASEL-IA, CFI-A, AGI
## insert tail number here
## KHAO, KISZ
"And that's all I have to say about that."
-- Forrest Gump
Electronic copy of manual for Nimbus-3DT [email protected] Soaring 3 January 26th 20 12:38 PM
Electronic Flight Manual Christopher H Thorpe Soaring 0 January 12th 06 12:12 PM
Whats for Lunch? culverflyer Soaring 16 January 9th 05 10:31 PM
Whats an RT-24/APX-2 ? Tasp Military Aviation 1 September 15th 04 12:47 PM
Whats up with Avid Deckard Home Built 1 November 24th 03 10:08 AM
