Mustang Collision Oshkosh
Old July 29th 07, 07:56 PM posted to rec.aviation.piloting
Big John
Default Mustang Collision Oshkosh
Blueskies
Tnx for clip.
From what I could see, #1 was flat and made a wheel landing.
#2 was high and you could see the prop blades turning which meant he
was at idle or very close to it tryig to slow down and lose the excess
altitude.
From what I then saw, #2 overran #1 and at the last minute he tried to
go around and put power on and pulled the nose up. About that time his
right wing underan the left stablizer of #1 and that threw #2 into a
steep right bank with up elevator and high power.
From that point it was preordained and the crash resulted.
This may be wrong but is as I saw it in the clip.
On Sun, 29 Jul 2007 14:13:31 -0400, "Blueskies"
"Big John" wrote in message ...
Dudleyt
Had been on the site and before and didn't this time either find a clp
of base, final of either or both A/C?
Can you point me a little closer? They may have taken it down and only
NZTSB has it now?
Big John
Try this:
http://www.aero-tv.net/index.cfm?vid...b-6f3b0f149c4d
  #32
Old July 29th 07, 08:05 PM posted to rec.aviation.piloting
Blueskies
Blueskies
Tnx for clip.
altitude.
#2 right wing under the left stab also explains #1 pitching down...
It is good to be able to examine this sort of accident with this level of detail...may save someone some day...
Dan D.
  #33
Old July 29th 07, 08:15 PM posted to rec.aviation.piloting
Mxsmanic
Big John wrote:
mxsmanic
Probably should have used a better set of words.
You are correct. I should not have called them "losers", I should have
called them "idiots". Landing a P-51 in formation is extremely easy. They
should not have been even allowed to fly aircraft that rare if they
couldn't fly any better than that. I could have done that landing in my
sleep. In fact, I frequently *do*.
  #34
Old July 29th 07, 09:17 PM posted to rec.aviation.piloting
Orval Fairbairn
Mxsmanic wrote:
Big John wrote:
mxsmanic
This from someone whose only "flight experience" is in a Microsoft
Flight Sim Mk I!
  #35
Old July 29th 07, 09:39 PM posted to rec.aviation.piloting
flypaper
Orval Fairbairn wrote:
Mxsmanic wrote:
Big John wrote:
mxsmanic
have called them "idiots". Landing a P-51 in formation is extremely
easy. They should not have been even allowed to fly aircraft that
rare if they couldn't fly any better than that. I could have done
that landing in my sleep. In fact, I frequently *do*.
Flight Sim Mk I!
Me thinks this is from an imposter - one Mx is bad enough.
Just like in several other posts you can tell the "real troll", from the
"fake troll", especially if sex is mentioned since Mx distains the the mere
thought of sex by his own admission.
  #36
Old July 29th 07, 10:44 PM posted to rec.aviation.piloting
Big John
Blueskies
If you look close at clip, you will see the main gear hit and then
bounced off runway. Immediately after the main gear hit the tail wheel
went rapidally down and hit the runway. The tail going down so fast is
further indication that the pilot put in up elevator to go around and
the power then pulled the nose to the high attitude that we all could
see.
I can see from clip that elevator was in an up position as nose
started up.
Then the overrun and the wing tip and elevator hitting lead to the
rest of the accident sequence.
If anyone can shoot me down have at it. I'm just looking at what I can
see and making my personal opinion from lots of accident investigation
experience with heavy iron.
Dudley
Come on in and give us your opinion now afer running the clip multiple
times.
I asked MX a series of technical questions and he let them slide.
Guess he is one of the trolls active here ( I'll put him on the
list.
Big John
On Sun, 29 Jul 2007 15:05:02 -0400, "Blueskies"
Blueskies
Tnx for clip.
altitude.
Dan D.
  #37
Old July 30th 07, 12:27 AM posted to rec.aviation.piloting
Dudley Henriques[_2_]
Big John wrote:
Dudley
times.
list.
Big John
John;
I think I'm seeing basically the same thing as you are. I believe Beck
instinctively applied hard back pressure just before impact, catching
the stabilizer on the way up. The one thing that is a bit strange is the
violent roll to the right. Had he hit the throttle hard as he pulled
back, that roll should have been to the left. The only explanation I can
see that explains the direction of the roll is his right wingtip
catching the stabilizer as he pulled back on the stick. Doinf that hard
enough might very well have caused exactly what happened.
Just guessing here of course, but I think there's at least a good chance
that Beck might have misjudged the drag on a 51 touching down with 50
degrees of barn doors hanging off the trailing edge of the wings. I
would also be interested to know if Beck was landing with the same flap
setting as the D in front of him.
Judging from how close they were, Beck might have lost the D as it's
drag after touchdown started it back toward him under his nose, or at
least partially under his nose as he started to flare the A.. I honestly
believe this is what must have happened. The visual cues as I'm sure you
remember, are changing during the flare in a Mustang. You can see fairly
well over the nose on final but as you begin the flare transition, the
eye naturally goes to the lower corners of the windshield where you look
to keep the airplane aligned on the runway. Beck was landing on the left
side so his corner visuals were skewed from what he normally would be
looking for; equal parts of the runway showing on each side in the lower
corners of the windshield. What he would be getting flaring left side
would be the grass expanse with no direct reference line on his left
side and the runway showing wide on the right side with perhaps a piece
of Odegard's 51 showing in his immediate visual cues. As his nose came
up, the drag slowing the D and his own excess airspeed into the flare
would have ganged up on him. I believe we saw the results of all this.
I'm of course not certain, but from what I saw, this would be a
reasonable scenario were I giving a safety lecture on what I was seeing
on the film.
Dudley Henriques
  #38
Old July 30th 07, 01:21 AM posted to rec.aviation.piloting
Big John
Dudley
We're saying almost the same thing. Maybe the same just using slightly
different words.
As you say, I'm almost sure Bech lost sight of #1 as he had full wing
over lap with initial contact. If he could have seen #1 then he could
easily have slid out to left and probably cleard lead.
People keep talking about formation landing. There is no evidence of
that. #2 had normal but close spacing on #1 and after not controling
his airspeed closed to the impact point.
Probably need to put this to bed and wait for NTSB results.
Bottom line of course is it's a bloody shame. As the Brits would say.
Big John
On Sun, 29 Jul 2007 19:27:35 -0400, Dudley Henriques
Big John wrote:
Dudley
times.
list.
Big John
John;
on the film.
Dudley Henriques
  #39
Old July 30th 07, 01:41 AM posted to rec.aviation.piloting
Big John wrote:
Dudley
different words.
Big John
The one thing you don't want to lose sight of with all this John is that
the recommendation considered standard for civilians flying Mustangs as
that advice would relate to a section landing gives MUCH more
longitudinal separation room required between the landing P51's....as
much as 3000 feet actually then was the case at Oshkosh. Even with a
high degree of experience, a civilian landing a P51 would be well
advised by any of the powers that be, not to mention myself, to adhere
to this long separation when landing 2 P51's out of a formation pattern.
Usually this would be done from a 360 overhead with spacing on the pitch
out to allow for this 3000 foot minimum longitudinal separation on the
active runway.
Dudley Henriques
  #40
Old July 30th 07, 01:47 AM posted to rec.aviation.piloting
active runway.
Dudley Henriques
...addendum;
I would only add to this that as far as I am aware, section landings as
the military has used them in the past, with 2 aircraft landing
staggered on each side of the runway with CLOSE IN SPACING, is NOT...and
I repeat...NOT a recommended procedure by any standard I know of in
present use by associations and organizations dealing with formation
flight safety with direct relationship to the P51 Mustang.
Dudley Henriques
Today in Oshkosh [9/9] - "09 Another Mustang (wasn't this Dazzling Donna).JPG" yEnc (1/1) Just Plane Noise[_2_] Aviation Photos 4 July 28th 07 11:09 PM
Today in Oshkosh [7/9] - "07 Reno Mustang.jpg" yEnc (1/1) Just Plane Noise[_2_] Aviation Photos 0 July 27th 07 01:49 AM
Today at Oshkosh [26/34] - "25 Eagle shadows Mustang (Heritage flight).JPG" yEnc (1/1) Just Plane Noise Aviation Photos 0 July 25th 07 04:32 AM
Post-accident photos of RV/TBM Avenger Oshkosh taxi collision Jim Logajan Piloting 39 August 28th 06 03:49 PM
Post-accident photos of RV/TBM Avenger Oshkosh taxi collision Jim Logajan Home Built 49 August 28th 06 03:49 PM
