More long-range Spitfires and daylight Bomber Command raids, with added nationalistic abuse (was: #1 Jet of World War II)
Old September 24th 03, 08:27 PM
Guy Alcala
Peter Stickney wrote:
(The Revolution Will Not Be Televised) writes:
snip
Whatever happened, the tanks were going to be jettisoned before
initiating combat, so I don't think the 90 gallon tanks - which should
be substantially emptied and consequently lighter before the aircraft
got to the prospective combat area anyway - would in those
circumstances impose as much of a performance restriction as we might
suppose.
True - I was thinking in terms of a way to add 90 gallons to a Mk V's
fuel capacity (Which would be about 50% of total fuel anyway) withoug
the stability and drag penalties that the 90 gallon tanks imposed.
(It's not much good being an escort fighter if you cruise slower than
the bombers that you're escorting.) To my ming, 29-30 gallons
internal, with another 60 or so external would about do it, especially
if the 60 gallon tank has no restrictions.
Pete, the drag penalty of the 90 gallon tank wasn't all that much. It knocked about 20
mph off the Spit XIV's top and max. cruise speeds, and less than 18 mph (337.5 vice 354)
off the top speed of a Mk. VC Trop, AB 320, that A&AEE tested; go here for the full report
on level and climb performance with and without the tank:
http://www.fourthfightergroup.com/eagles/ab320.html
A Mk. VIII/IX would presumably take a speed hit in between the two, given that it's faster
than the Mk. V and slower than the Mk. XIV. In short, not significant, and there's
absolutely no danger of cruising "slower than the bombers that you're escorting." WITH
the tank, the Spit XIV was still faster than the Me-109 or FW-190A. The Mk. IX wouldn't
be, but would still be able to cruise at 300TAS or higher at the heights of interest with
no problem.
Remember, I'm not asserting that any of this was an optimal solution
for long-range escorting, or could have competed with aircraft that
were better suited to expanding their internal fuel capacity. I'm
trying to work along the lines that would be dictated by operational
neccessity and addressed with existing equipment and experience in
certain circumstances.
Well, in htat case, gin up a 60 gallon tank, and add teh 2 13-gallon
leadig edge tanks. The 80 gallon tank would give you about 40% of teh
total fuel, allowing it to be empty before the target area is reached,
and the 13 gallon tanks can be swapped in as a Deport-level job. They
fit in the leading edge outboard of the 20mm gun bays. but inboard of
the .303s, and slotted in between a pair of ribs. That sort of
sheet-metal work would be well within what they could do withoug a
need fr a factory-level rebuild.
Again, I'll raise a practical objection to installing tanks outboard of the guns (any
guns): where are you going to route the tank piping? You can't route it through a gun bay
(well, you could, if you didn't mind the constant danger of broken fuel pipes owing to
vibration loads when shooting, not to mention the danger of fires -- I can't see even the
most clueless RAF type signing off on this), and there's really not a whole lot of room in
the wing aft of the cannon bay (but forward of the flaps/ailerons and their actuators) to
pass them, even assuming that you're willing to make a couple of 90 degree or so bends in
the piping to do so. This is an interim mod until the RAF's Mustangs become available, so
it needs to be something that's already been done, and that's the Mk. VIII tank
installation, with maybe an aft tank added if the Cg is okay for combat (and the max.
gross weight isn't exceeded when also carrying a 90 gal. or larger drop tank).
Guy
  #162
Old September 25th 03, 07:35 AM
Guy Alcala
The Revolution Will Not Be Televised wrote:
On Wed, 24 Sep 2003 09:16:49 GMT, Guy Alcala
The Stirling III and Halifax III still seem to have a major
differential in terms of operational ceiling, which I can only put
down to structure weight and the wing.
snip
A better operational ceiling comparison would be between the Stirling III
and Halifax II, as the latter has the original 98(?) foot wing (some
sources claim that early Halifax IIIs had the original wing; I don't have
enough info to say). The Halifax II is still better but not much, and I
expect the difference is largely due to the lower weight, and maybe the
drag of the Stirling's nose turret.
[quick driveby]
I sure hope not. I had enough experience with those living in East Oakland in
the early '80s (per capita murder capital of the U.S. for several years).
OTOH, they had generally execrable aim, which made the intended targets
relatively safe but put the innocent bystanders at risk. The closest one I
was exposed to was at a distance of about 50 feet, but fortunately the shooter
was facing away from me and firing into a non-moving car with two guys sitting
in it, so there was little chance of me getting hit by the odd round. He and
his homeys pulled up in a stolen van, he jumped out the side door and opened
fire, but only managed to crease one guy in the arm and IIRR the other got hit
by some flying glass from one of the windows. I later counted only nine
rounds that hit the car (semi-auto machine pistol of unknown type, fired from
the hip), distributed all over it (two just creased the roof), from a distance
of about 5 ft. Pathetic aim, especially considering that these guys were
likely to return the favor. And all because the shooter's sister had taken
offense at something one of the guys in the car had said to her an hour or two
earlier.
The early Halifax II's (i.e. those produced throughout 1941-42) had
the Mk I nose turret, and clocked in at 34,980 lbs with an auw of
60,000lbs with a 98 ft 8in wingspan. The Stirling III seemed to come
in at something like 42,000lbs with auw's somewhere over 60,000lbs
(figures I have vary between 61,000 and up to 70,000lbs), so there's a
couple of tons of weight difference before the operational load gets
included.
I've often wondered at that 42,000 lb. figure, but I think Geoffrey provided
some numbers earlier in the thread.
The Stirling Mk III couldn't get above 17,000 feet (a couple of
thousand feet below routine operational heights for the Halifax), and
had a lower rate of climb than the Halifax. Early Halifax Mk IIIs did
have the shorter-span wings before they got the extended 103 ft 8in
wingspan.
So I'd like to know how high the Halifax IIIs could operate with the short
wings.
Guy
Long-range Spitfires and daylight Bomber Command raids (was: #1 Jet of World War II) The Revolution Will Not Be Televised Military Aviation 20 August 27th 03 09:14 AM
