GTX330 programming
Old August 5th 07, 08:56 AM posted to rec.aviation.owning
Kyprianos Biris[_2_]
Default GTX330 programming
In the Garming GTX330 Transponder how do you disable the FLT ID PWR-UP ENTRY
at start up ?
I have a standard aircraft reg. number and will never need this feature.
Thanks in advance
Old August 5th 07, 10:37 AM posted to rec.aviation.owning
No Spam
at start up ?
Thanks in advance
I don't know what a standard aircraft registration number is, but that's not
surprising - I don't know a lot of things!
Anyway, you can look in Section 5 of the Installation manual and see how to
change whether the flight id is entered automatically or must be entered by
the pilot at power up. I couldn't see a way to disable the whole function.
Here's a link for a previous version of the manual:
http://www2.mstewart.net:8080/Downloads/GTX330_IM.pdf
Good luck,
- Don
Everybody needs a rubber chicken.
Old August 5th 07, 05:27 PM posted to rec.aviation.owning
Mike Adams[_1_]
No Spam wrote in
PWR-UP ENTRY at start up ?
feature.
Thanks in advance
that's not surprising - I don't know a lot of things!
how to change whether the flight id is entered automatically or must
be entered by the pilot at power up. I couldn't see a way to disable
the whole function.
Good luck,
- Don
Thanks for this reference. Looking in section 5.2.12 on page 5-6 it
appears there's a configuration option to enter the flight ID at startup
or only in configuration mode. The Flight ID (registration number) is
needed for the Mode S, but it looks like it can be just a one-time
configuration entry.
Mike
Mike
Old August 6th 07, 02:35 PM posted to rec.aviation.owning
Gig 601XL Builder
feature.
Thanks in advance
I beleive that is your MODE S code. I'm surprised they didn't enter it when
they installed the 330. You so a really easy way to find out what the number
is don't you?
Old August 6th 07, 09:14 PM posted to rec.aviation.owning
No they did enter the Mode S code that was given to us by our CAA.
What it asks for each time is the tail / flight ID code.
Since we do not fly commercial all I need to have there is the aircraft
registration (tail number) and the unit not to ask again for it.
Previous posters covered my question, thank you all.
"Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net wrote in message
feature.
Thanks in advance
when they installed the 330. You so a really easy way to find out what the
number is don't you?
Old August 7th 07, 09:38 AM posted to rec.aviation.owning
Thomas Borchert
Kyprianos,
That set-up mode, once you're in there, has some other interesting
options, too.
Thomas Borchert (EDDH)
Thomas Borchert
Gig,
is don't you?
Nope, very important difference. Your aircraft is assigned a hex code which
should be entered by the installing agency only and shouldn't be changed by the
user. However, the S mode data packet also contains one more data field with
either one of two informations: Either the aircraft registration or the flight
number. Obviously, for us lowly GA pilots, we want the aircraft registration in
there and we don't need to change it. It is entered without any dashes some
countries might have in there (e.g. in Germany all registrations start with
D-), so you enter it just like on a flight plan form.
However, if the GTX330 is installed in an airline aircraft, the crew is
supposed to enter the flight number (e.g. UA078) before each flight. You can
set in the set-up menu whether the GTX330 should ask for a flight number every
time after switching it on or not.
Aerodynamics for flight/space simulator programming Timothy Stark Simulators 0 July 8th 07 03:31 AM
Programming $10 Event Radio Paul Dow (Remove Caps in mail address) Piloting 12 August 24th 06 11:20 PM
KLN94 -> GTX330 (GND/ALT switching) Bill Chernoff Instrument Flight Rules 3 June 30th 05 07:36 AM
Interesting consequence of improperly programming GPS route Icebound Piloting 17 June 18th 05 04:29 AM
CNN's post-Cessna-invasion programming Charles O'Rourke Piloting 29 May 14th 05 08:31 PM
