Needed: Good (cheap) source for SS cable & sweges
Old August 8th 07, 05:33 PM posted to rec.aviation.homebuilt
wright1902glider
Default Needed: Good (cheap) source for SS cable & sweges
Anyone have a good (ie cheap) source for SS cable, thimbles, and
sweges? This is for a non-aviation project so strength specs aren't an
issue, as long as its SS (or looks like SS to my roommate). The
intended useage is in the rails of the deck I've been attempting to
finish for months. Yes, its suffering from "scope-creep".
The cable itself will need to be SS, 3/32" or 1/8", strand type is
unimportant. I'd also like to use SS thimbles. Zinc or nickel plating
is ok for the sweges. I've already got pricing from AS&S and Wick's as
well as the BLUE store and the ORANGE store. Just hoping someone has a
better source.
Thanks fellas,
Harry Frey
Old August 9th 07, 12:06 AM posted to rec.aviation.homebuilt
Capt. Geoffrey Thorpe
"wright1902glider" wrote in message
better source.
I would think that marine outlets would be less expensive than aircraft. But
look in the yellow pages under "wire rope"
Geoff
Old August 9th 07, 12:09 AM posted to rec.aviation.homebuilt
Ken Moffett
wright1902glider wrote in
oups.com:
thimbles, and sweges? This is for a non-aviation project so
strength specs aren't an issue, as long as its SS (or looks
like SS to my roommate). The intended useage is in the
rails of the deck I've been attempting to finish for
type is unimportant. I'd also like to use SS thimbles. Zinc
or nickel plating is ok for the sweges. I've already got
pricing from AS&S and Wick's as well as the BLUE store and
the ORANGE store. Just hoping someone has a better source.
Thanks fellas,
Harry Frey
http://www.mcmaster.com/
Ken
Old August 9th 07, 01:25 AM posted to rec.aviation.homebuilt
On Wed, 08 Aug 2007 09:33:41 -0700, wright1902glider
better source.
Thanks fellas,
Harry Frey
These guys seem to have good prices and helpful staff.
http://www.jakescrane.com/wirerope.html
Old August 9th 07, 03:17 AM posted to rec.aviation.homebuilt
Ernest Christley
better source.
Thanks fellas,
Harry Frey
Northern Tool, if you have one local.
Old August 9th 07, 12:12 PM posted to rec.aviation.homebuilt
Lou
I don't know your definition of cheap, but ebay has a couple listed.
item 330154481261
Lou
Old August 9th 07, 10:12 PM posted to rec.aviation.homebuilt
tom laudato
here is one pretty cheap
http://www.webriggingsupply.com/page...irerope-galvan
ized.html#A
better source.
Thanks fellas,
Harry Frey
Old August 10th 07, 12:16 AM posted to rec.aviation.homebuilt
Maxwell
better source.
I'd recommend checking with your local "wire rope" suppliers in the yellow
pages on the cable, and local "electric equip. & supls." for nico sweges. I
never found SS thimbles locally, but got my best deal (several years ago)
from LEAF. Leading Edge Airfoils. That's where I found my best deals the
last time I stocked up.
Old August 10th 07, 02:49 AM posted to rec.aviation.homebuilt
JohnO
On Aug 9, 11:06 am, "Capt. Geoffrey Thorpe" The Sea Hawk at wow way
better source.
Geoff
I think the general rule is to multiply the cost of any common item by
two when purchasing from a chandlery and multiply by 10 from an
aircraft supplies store.
Multiply by 100 for military and government supply.
Old August 10th 07, 03:06 AM posted to rec.aviation.homebuilt
Morgans[_2_]
Close. Multiply times three from a chandlery. Multiply times two if it is
for a Cadillac.
Jim in NC
Prop Cable Needed zatatime General Aviation 2 May 10th 04 10:30 PM
Prop Cable - Replacement Needed zatatime Owning 0 May 7th 04 04:37 PM
Where Can I Find Good P-Lead Cable Larry Smith Home Built 3 November 7th 03 11:43 PM
Cable parts needed in Dallas dave Home Built 4 October 23rd 03 04:12 AM
Cable parts needed in Dallas dave General Aviation 4 October 23rd 03 04:12 AM
