"Chad Irby" wrote in message ... When you break a speed record, one of the requirements is that you do it in *level flight*. But no such requirement existed for the first supersonic flight. Putting a plane into a 40 degree dive kinda takes it out of the running, especially since some American *prop* planes had probably done it before 1945. From reports, P-38 Lightnings had entered compressibility as far back as 1941, and some had actually come out of it (not the safest flight regime, back then). No American prop plane ever exceeded the speed of sound. No German jet or rocket fighter ever exceeded the speed of sound. If Yeager was not the first to exceed the speed of sound, the only other possibility is that George Welch in the XP-86 was the first. |
In article , Chad Irby
writes When you break a speed record, one of the requirements is that you do it in *level flight*. One could also argue another requirement, is that the 'aircraft' achieving it, is self-sufficient and is capable of taking off under its own power. Note the X-1 never held an official air speed record. Putting a plane into a 40 degree dive kinda takes it out of the running, especially since some American *prop* planes had probably done it before 1945. From reports, P-38 Lightnings had entered compressibility as far back as 1941, and some had actually come out of it (not the safest flight regime, back then). Spitfires were dived to M.93 after WWII, and were better suited to speeds in this range than most jets before the Sabre turned up. -- John |
In article . net,
"Steven P. McNicoll" wrote: "Chad Irby" wrote in message ... When you break a speed record, one of the requirements is that you do it in *level flight*. But no such requirement existed for the first supersonic flight. All of the other speed records set up until that time were in horizontal flight. No American prop plane ever exceeded the speed of sound. No German jet or rocket fighter ever exceeded the speed of sound. If Yeager was not the first to exceed the speed of sound, the only other possibility is that George Welch in the XP-86 was the first. We lost more than one fighter from compressibility, and it's quite possible that one or more made it "through" Mach 1 and back. But since none of these were subjected to any sort of external measurement (the Me-262 in the original post certainly wasn't), it's not possible to tell for sure. Which is why the X-1 was the first. -- cirby at cfl.rr.com Remember: Objects in rearview mirror may be hallucinations. Slam on brakes accordingly. |
robert arndt wrote in message . .. http://mach1.luftarchiv.de/weisse_9.htm "White 9" deserves the credit, not "Glamorous Glennis"! Rob In how many pieces did it break the SB? ![]() Nele NULLA ROSA SINE SPINA |
John Halliwell wrote:
In article , Chad Irby writes When you break a speed record, one of the requirements is that you do it in *level flight*. One could also argue another requirement, is that the 'aircraft' achieving it, is self-sufficient and is capable of taking off under its own power. Note the X-1 never held an official air speed record. I could go with that. But the "achieveing Mach 1 in level flight" part is still pretty solid. If we include diving to gain speed, though, the Me-262 isn't even in the running. Spitfires were dived to M.93 after WWII, and were better suited to speeds in this range than most jets before the Sabre turned up. Which goes to show: make something slick enough and drop it from high enough, and you can go fast as hell. -- cirby at cfl.rr.com Remember: Objects in rearview mirror may be hallucinations. Slam on brakes accordingly. |
"Chad Irby" wrote in message m... We lost more than one fighter from compressibility, and it's quite possible that one or more made it "through" Mach 1 and back. Sorry. This is wrong. It is physically impossible for a prop driven aircraft to exceed mach one. Trust me on this. I've had a Mustang out all the way to ..75. The circumstances that day were such that had the airplane been capable, it would have made it through. It didn't!! The prop drag curve on the props of the era becomes insurmountable. In my case, a Hamilton Standard 24D50 on the 51. The RAF tried every which way but backwards to put a Spit through at Boscombe Down after the war. They failed...and they had some real heavyweights flying these airplanes too. Herb Fisher did extensive high mach dive tests in a modified Jug that used several highly experimental semitar shaped propellers. Even Herb couldn't make it through. Trust me again...I knew him well!! The simple truth about props is that the drag rise in compressibility can't be overcome by thrust and velocity. It's a no win situation. It can't be done. Furthermore, the 262 didn't make it through either. It's aerodynamic shape coupled with it's ability to create the thrust required didn't equate. There was no way the 262 would have been able to get high enough and accelerate fast enough in real time within the altitude restraints it could create. In other words, for the specific design of the 262, there simply wasn't enough sky up there to get it done. This is common knowledge in the flight test community. Even if it had the air available, the 262's drag index curve would never have allowed a total mach one airflow. George Welch was probably the first through mach one. I realize this damn argument will go on forever, but Welch again is the general consensus of the flight test community......and Yeager is very much a member of this community :-))) Dudley Henriques International Fighter Pilots Fellowship Commercial Pilot/CFI Retired For personal e-mail, use dhenriquesATzarthlinkDOTnzt (replacezwithe) |
"Emmanuel Gustin" writes: "robert arndt" wrote in message om... http://mach1.luftarchiv.de/weisse_9.htm "White 9" deserves the credit, not "Glamorous Glennis"! This seems complete nonsense to me. The Germans did fly high-speed tests with the Me 262, of course. The senior Me 262 test pilot, Zeigler, has described how they climbed to 10.000 to 12.000 m, and then put the aircraft into a steep full-throttle dive. At 7000 meter they would reach 950 km/h, close enough to Mach 1 at that altitude to produce a deep rumble as the airflow detached, followed by a strong tendency for the nose to drop and the aircraft to roll. The Me 262 then entered an out-of-control dive until it had descended into the denser air at low altitude. The dive achieved only Mach 0.86 at 5700 m. It ought to be pointed out that on a Standard Day, 950 km/hr at 7,000m is Mach 0.84. At that point the Me 262 is just entering into the mach number range where the Drag Coefficient is increasing extremely rapidly. It is also claimed that in July 1944 a modified Me 262 with a low-drag canopy reached slightly over 1000 km/h at 10.000 m in level flight, or Mach 0.92. But the type was firmly subsonic. In service Me 262 were 'red-lined' to stay out of compressibility problems, as they tended to become (quite unlike the XS-1 or F-86) completely uncontrollable at high Mach numbers. Just so. As, it should be pointed out, were the P-80, the P-84, and the Meteor. In the case of the P-80 and P-84, the difference in dive speed available due to the higher Limiting Mach of the Me 262 worked out to a whopping 15 mph (15 kph), and the P-84 was dead even. Both American types had more power adn less drag in level flight. But the Me 262 actually had quite good decent aerodynamic characteristics for transsonic flight compared to the Meteor, which initially suffered from control problems already at Mach 0.71 to 0.74, because the engine nacelles of the early Meteors were too fat and disturbed the airflow. Which was fixed by the longer nacelles of the Meteor IV. The Vampire, though, with its faily thick wing, was stuck at about Mach 0.75 or so. Of the propeller fighters the Spitfire got closest to Mach 1 because its thin wing had less drag at such high speeds even than the laminar flow wing of the Mustang. Tony Martindale reached 0.92, not without blowing up the gearing of the overspinning propeller, and bringing back the aircraft without propeller. There also is a claim that a weather reconnaissance PR.IX reached 0.96 in an uncontrolled dive from high altitude over Hong Kong. The Spit actually had the best high Mach number drag characteristics, and handling behavior of all of the WW 2 era fighters. (The Spitfire also ended up with better high-speed bahavior that its laminar-winged successor, the Spiteful.) During WWII there were claims to have achieved Mach 1 in various fighters in dives, but most of these would have been transsonic dives, with airflow over the aircraft only being locally supersonic -- and airspeed indication probably becoming very unreliable as a result. It is characteristic of the true performance of these aircraft that when designers decided to install Mach meters, these had scales ranging only up to 0.8. -- Pete Stickney A strong conviction that something must be done is the parent of many bad measures. -- Daniel Webster |
"John Halliwell" wrote in message ... One could also argue another requirement, is that the 'aircraft' achieving it, is self-sufficient and is capable of taking off under its own power. Not if one wished to be taken seriously. |
| bell xp-77-info? | J. Paaso | Home Built | 0 | March 25th 04 01:19 PM |
| It broke! Need help please! | Gerrie | Home Built | 0 | August 11th 03 11:24 PM |
