Patch
Old August 9th 07, 09:14 PM posted to alt.binaries.pictures.aviation
Panic
Default Patch
Someone sent me a B-58 Hustler patch with a white background. I'd like to
trim the white background out and just leave the patch. I tried
PaintShopPro but the only method I see is laboriously and carefully delete
the white. Does someone here have a program to delete just the background?
I'll post it here. It's very large but I'd like to edit the background out
before I reduce the size.
Thanks.
Darrell R. Schmidt
B-58 Hustler Web Site
http://members.cox.net/dschmidt1
USAF Pilot Class 55-I Web Site
http://pilotclass55india.org
Click image for larger version
Old August 9th 07, 10:47 PM posted to alt.binaries.pictures.aviation
Just Plane Noise[_2_]
Default Patch (00/10)
Thanks.
Darrell R. Schmidt
I'm not sure of your purpose--are you trying to simply paste it on
another image, as I've done here with a B58 pic somebody else had
posted? Let me know. In any case, I've also attached a PSP file of
the patch with a transparent background. There are several easy ways
of creating it.
I'm also guessing that a more savvy PSP or Photoshop user will know
the easiest way!
Old August 10th 07, 01:05 AM posted to alt.binaries.pictures.aviation
muff528
Default Patch
"Panic" wrote in message
background?
out
Thanks.
Darrell R. Schmidt
Here's a low res tif file if you can use it.
I can send this at about 4mb size if it works out.
TP
Old August 10th 07, 01:16 AM posted to alt.binaries.pictures.aviation
Panic
Default Patch
"muff528" wrote in message
news:dZNui.20530$ug3.19866@trnddc06...
to
delete
background?
out
Thanks.
TP
I tried opening it in PaintShopPro and it wouldn't work. In Windows Picture
and Fax Viewer it came out with light pastel colors and not much detail. If
you would try sending me that 4mb file I'll see how that one works.
Old August 10th 07, 03:10 AM posted to alt.binaries.pictures.aviation
Default Patch
to
delete
background?
out
Thanks.
TP
Mine should have worked for you, especially since it was a PSP image.
Did you try it?
Old August 10th 07, 04:41 AM posted to alt.binaries.pictures.aviation
Joe Friday[_2_]
Default Patch
Try this....it's a TIFF from Photoshop, and it has a transparent background
layer. Sorry for the size! I had to shrink it a little to make it upload!
Old August 10th 07, 12:23 PM posted to alt.binaries.pictures.aviation
muff528
Default Patch
OOPS! tried to upload "too big" file.
check your email -- png file seems to work
ok in paint shop.
TP
Old August 12th 07, 06:56 AM posted to alt.binaries.pictures.aviation
Clairbear
Just Plane Noise wrote in
like to trim the white background out and just leave the patch. I
tried PaintShopPro but the only method I see is laboriously and
carefully delete the white. Does someone here have a program to
delete just the background? I'll post it here. It's very large but
I'd like to edit the background out before I reduce the size.
Thanks.
Darrell R. Schmidt
of creating it.
the easiest way!
use photoshop and save it as a png file
Patch Jim[_10_] Naval Aviation 3 May 24th 07 10:52 AM
USAF(?) unit patch ID Allen Thomson Military Aviation 63 June 18th 05 07:48 PM
MS FS2004 - No CD patch Silent Bob. Simulators 15 December 2nd 04 09:16 PM
FS2004 patch Mike Kirkland Simulators 9 October 19th 04 05:57 AM
No CD Patch Dave Schwartz Simulators 5 April 20th 04 12:10 AM
