#31
Cub Driver wrote:
Gregg Germain wrote: Do I understand correctly that the original Wright Flyer as well as the replicas, CANNOT fly unless there's sufficient wind? Sure they can fly. An airplane in the air does not know whether the wind is blowing or not. Despite what you probably learned in your private pilot ground school, this statement is not entirely true. For all practical purposes, Ed's 55,000 lb. Thud (for example) probably didn't know whether the wind is blowing or not. But your 700 lb. Cub certainly does. If you still have your AC-61 23 (FAA Pilot's Handbook of Aeronautical Knowledge) see page 114. If you don't have it handy, here is the pertinent excerpt: "It has been thought that wind cannot affect an aircraft once it is flying except for drift and groundspeed. This is true with steady winds or winds that change gradually. It isn't true, however, if the wind changes faster than the aircraft mass can be accelerated or decelerated." It boils down to this: those of us who fly extremely lightweight A/C are much more intimately acquainted with the subtle nuances of how wind effects our planes in flight than are our he-man counterparts who drive their heavyweights around the sky at .9 mach for the most totally oblivious to what the wind is doing. But then, coming from a GA background, I also didn't much care about the wind after takeoff and my 6,000 lb. AeroCommander loaded with 1,500 lbs. of cargo didn't care either. Simply turn the required amount of degrees into the wind to compensate for drift and be done with it. But since taking up flexwing aviation and having flown several dozen different make & models of delightfully lightweight birds, I've changed my tune a bit here. The steady wind at Kill Devil Hill was also essential for the kite trials that preceded powered flight in the Wright Flyer. Unlike an airplane, a kite is tethered to the ground and the airstream is provided not by a propeller but by the differential between the speed of the air and that of the ground. This is all true, but it doesn't support your contention that, "an airplane in the air does not know whether the wind is blowing or not." If you don't understand this, try dragging a banner behind your Cub someday. For maximum effect, try this little experiment by flying from a steady state wind towards the shoreline so as to experience a sudden change in wind direction from a tailwind to an onshore seabreeze. You're happily cruising along in your Cub headed straight for the beach with the banner flapping lazily behind and slightly below your Cub's tailfeathers. You then fly into the onshore seabreeze airmass and suddenly all the slack in the banner towline tightens up and the banner streaming behind straightens out. You exclaim, "This shouldn't be, I'm part of the airmass!" Another good example is drifting along in a balloon. You're moving over the ground, but not a breath of air in the balloon. You are changing altitudes to catch a wind going another direction, and suddenly the little flags on the balloon flutter and you feel a little breeze. Once again, you protest, "This shouldn't be, I'm part of the airmass!" The balloon replies, "Yes, grazihopper, but I have inertia and once I have adjusted to the new wind, we will be floating in silence once more." -Mike Marron |
#32
Mike Marron wrote:
:Gregg Germain wrote: : Do I understand correctly that the original Wright Flyer as well as : the replicas, CANNOT fly unless there's sufficient wind? : It could fly w/o sufficient wind, but just didn't have the oomph to : take off by itself due to it's puny 12-hp engine tasked with getting : 600 lbs. of airplane into the air. : -Mike Marron Hi Mike, Well that's what I meant by "fly" though I didn't use precise language. In other words, on a calm day, the Wright Flyer would not take off. --- Gregg "Improvise, adapt, overcome." Smithsonian Center for Astrophysics Phone: (617) 496-1558 |
#33
Mike Marron wrote: It could fly w/o sufficient wind, but just didn't have the oomph to take off by itself due to it's puny 12-hp engine tasked with getting 600 lbs. of airplane into the air. Hi Mike, Well that's what I meant by "fly" though I didn't use precise language. In other words, on a calm day, the Wright Flyer would not take off. With a long enough runway it could take off in calm air. But since Kitty Hawk is only about 500 miles from their bicycle shop in Ohio whereas the Bonneville Salt Flats is more than 1500 miles away, the 100 ft. dunes and onshore seabreezes at Kitty Hawk worked out just fine for their purposes. -Mike Marron |
#34
![]() In other words, on a calm day, the Wright Flyer would not take off. Just so. Note that much the same was true of most carrier aircraft in WWII, at least as the planes were arranged on deck. (Parked aircraft took up much of the available space.) The carrier steamed into the wind at high speed, giving 25 knots or more over the bow. The most famous example was the launch of the Dootlittle raiders in April 1942, when you can see a B-25 actually dipping below deck level as it took off for Japan. Today, there is seldom any effort to take off from carriers. Jets are routinely catapulted. all the best -- Dan Ford email: www.danford.net/letters.htm#9 see the Warbird's Forum at www.warbirdforum.com and the Piper Cub Forum at www.pipercubforum.com |
#35
![]() With a long enough runway it could take off in calm air. But since Kitty Hawk is only about 500 miles from their bicycle shop in Ohio whereas the Bonneville Salt Flats is more than 1500 miles away, Given that the first flight was shorter than the wingspan of a modern jetliner, are you sure about this? Perhaps it would have run out of gas or fallen apart or the pilot jolted off before becoming airborne? The temps on the salt flats would have been a hindering factor as well, both aerodynamically and mechanically. all the best -- Dan Ford email: www.danford.net/letters.htm#9 see the Warbird's Forum at www.warbirdforum.com and the Piper Cub Forum at www.pipercubforum.com |
#36
![]() The wind doesn't affect the Cub when its airborne. *Changes* in windspeed affect the Cub. But they don't help it fly. all the best -- Dan Ford email: www.danford.net/letters.htm#9 see the Warbird's Forum at www.warbirdforum.com and the Piper Cub Forum at www.pipercubforum.com |
#37
Cub Driver wrote:
The wind doesn't affect the Cub when its airborne. *Changes* in windspeed affect the Cub. But they don't help it fly. Typical "heavy iron" mindset of a pilot who simply drives around burning holes in the sky and never discovers the joys of surfing the wind. In any event, no offense but I couldn't disagree more and it sounds to me that you just don't like the wind. Happiness is a limp windsock and all that jazz. -Mike (perhaps a few soarplane lessons might help?) Marron |
#38
Cub Driver wrote:
Mike Marron wrote: With a long enough runway it could take off in calm air. But since Kitty Hawk is only about 500 miles from their bicycle shop in Ohio whereas the Bonneville Salt Flats is more than 1500 miles away, Given that the first flight was shorter than the wingspan of a modern jetliner, are you sure about this? Perhaps it would have run out of gas or fallen apart or the pilot jolted off before becoming airborne? Perhaps. But then, neither of us can definitively state one way or another that it would NOT have been possible to takeoff under its own power in calm air given a long enough runway. The temps on the salt flats would have been a hindering factor as well, both aerodynamically and mechanically. I just checked the mean temperatures of the Wendover UT area (closest I could find to the salt flats) and didn't see any reason why temps would have been a hindrance (esp. in the wintertime). -Mike Marron |
#39
om: Cub Driver lo
The most famous example was the launch of the Dootlittle raiders in April 1942, when you can see a B-25 actually dipping below deck level as it took off for Japan. That was Travis Hoover's plane. He was the second off after Doolittle. Apparently the pitch up of the deck as he launched put the nose up too high and he dropped down to pick up air speed. Whether that was done with conscious intent or whether that's just the way the inert mass behaved when trundled off the front end of a flight deck depends on whose telling the tale. Apparently timing the launch to coincide with the correct angle of the pitching deck was critical and it took a near miss for the navy guy waving the flag (whatever you call him) to get the timing exactly right, the progress of a B-25 down the flight deck not being exactly the same as that of the single-engine jobs the navy was used to launching. Chris Mark |
#40
"patrick mitchel" writes: Sorry for taking so long for the reply, but there's only so many hours in the week, and I've had a lot to do at my Day Job. Peter Stickney wrote in message They also took the most systematic and scientific approach to solving the problem of heavier than air flight than anybody who'd gone before. When they realized that Lilienthal's data was incorrect, they derived everything from scratch, using various test rigs adn their own wind tunnels. By 1903, they knew more about air propeller efficienfy adn stability and control than anyone. They also took the same systematic approach to flying. They began flying gliders at Kitty Hawk in 1900, and spent 1900, 1901, and 1902 perfecting the control of their aircraft, and learning to fly. (As an aside, that's one of the things that amazes me about nearly all of the early experimenters, (Adler, Langley, Maxim), or would-be experimenters (Whitheead, ahd that bloke in New Zealand whose name escapes me at the moment) All of them seemed to be of the idea that all they had to do was build their machine, jump into it, and fly it. It doesn't work that way, especially with the poor understanding of stability, and lack of 3-axis control that they had. Manley's (Langley's Test Pilot) swimming improved quite a bit, though) After tje extensive experiments of 1900-1903, I'd say that by Dec 1903, the Wrights had more flight time than anyone else. Why did they choose a canard....seems to me that all the natural analogs have a "tail" in the trailing position. All the soaring birds and the like. Was there something about "seeing" the pitch attitude that gave them confidence in that approach? Regards Pat Well, birds with canards, (With the possible exception of the semi-mythical Woose Grock (Wrongwayus invertibuttacus) or Inverted Grouse of the North Woods, whose backward flight causes hunters to pull lead in the wrong direction, and is mostly known by its taunting call of EEOOOMISSSSDMEE, EEOOOMISSSSEDMEE) have a hard time eating. ![]() Seriously, though, I think they did it for reasons of efficiency. A fixed wing all by itseld, wants to pivot in a "nose down" direction. The conventional tail of an airplane or bird balances this by generatnig lift in the direction opposite that of the wing. So, although it balances the pitching moment of the wing, it increases the amount of work that the wing must do. A canard (Forward Stabilizer) can achieve the same goal while generating lift in the same direction as the wing. therehy helping out with the lift. The drawbacks are that the canard can disturb the airflow over the wing in some configurations, (Or help teh airflow in others), and it adds to the length of the airplane, since it has to be stuck out far enough ahead of the wing to get a proper amount of leverage. After 1909, the Wrights wnet to a more conventional layout, with the stabilizer in back, with the rudder. -- Pete Stickney A strong conviction that something must be done is the parent of many bad measures. -- Daniel Webster |
