#161
Martin writes:
How was the average mental age of the US population computed? The average IQ is computed by administering a test to a large and representative sample of the population on which the test will ultimately be used, and then assigning 100 (an average IQ score, by definition) to the average raw score obtained by the sample cohort on the test. The scoring is then further normalized to ensure that a constant deviation in IQ score represents a constant percentile. Usually 15 is the width of an SD in IQ points, such that 130 represents two standard deviations above the mean in scoring, or the 98th percentile. |
#162
Martin wrote in
: On Fri, 17 Aug 2007 14:37:03 +0000 (UTC), Bertie the Bunyip wrote: Martin wrote in m: On Fri, 17 Aug 2007 12:26:41 +0000 (UTC), Bertie the Bunyip wrote: Martin wrote in m: On Fri, 17 Aug 2007 10:58:02 +0000 (UTC), Bertie the Bunyip wrote: Mxsmanic wrote in news:f7kac3df8h83sjkq7647f43k4dm71nba82@4ax. com: Doug Semler writes: How the **** would you demonstrate that you have the "valuable predictor" of intelligence without a group, such as Mensa, that filters applicants based on intelligence, dip****? An IQ test would suffice. However, intelligence is usually fairly obvious. And yet, even people of moderate intelligence can understand bernoulli The average IQ of US enlisted men tested during WW1 was that of a12 year old. IQ isn't really age related. though it is true that capacity increases with age, the measurement is usually like/like otherwise it's kind of pointless. So it would be fairer to say that they had a sub-normal IQ of say ,less than 85 than to say they had the IQ of a 12 year old. It'd be a bit like comparing the horsepower of a modern airplane to the horsepower of a airplane from 75 years ago. In general, airplanes of 75 years ago had smaller engines, but you could b talking about a mustang. IOW, you're not neccesarily comparing like with like. OK I dug around and Alfred Binet’s intelligence, or IQ, test used on enlisted men also included an assessment of mental age. I guess it should have been "The average mental age of US enlisted men tested during WW1 was that of a 12 year old". That doesn't make a lot of sense either but ... Well, it makes sense to me. Pretty much what I was trying to say earlier. How was the average mental age of the US population computed? The biggest sample ever measured at that time was of US enlisted men. Was the mental age that of a 12 year old French child? All pretty much the same, actually. Leaving aside minor abberations in race and culture (and we don't want to start one of those arguments here, believe me) The difference in 12 year olds who have had similar levels of stimulation is negligable. No doubt they had some sort of idea of what a 12 year old was capable of at the time and used that as a yardstick. Most likely the way the mental age was measured back then was some sort of simple literacy/numeracy test. Even today's SATs aren't a lot different from that kind of measurement. SATs aren't an IQ measurement, though they would reflect an IQ, they'd be heavily influenced by the education of the person taking the test, wheras an IQ test should pretty much eliminate hat factor. IOW IQ is a measuement of potential. An analogy might be that IQ is like the cubic inches To this day, most newspapers use an eight grade reading level as a standard in order to make their papers accessible to as many as possible. Most tabloids use a fourth grade reading level as a standard for obvious reasons. Bertie |
#163
Mxsmanic wrote in
: Martin writes: OK I dug around and Alfred Binet’s intelligence, or IQ, test used on enlisted men also included an assessment of mental age. I guess it should have been "The average mental age of US enlisted men tested during WW1 was that of a 12 year old". That doesn't make a lot of sense either but ... It doesn't, and modern tests are usually normed differently, although the concept of "mental age" is still used sometimes for scoring. In reality, a 25-year-old is no more intelligent than a 12-year-old. The only differences are in experience and acquired knowledge, although both obviously have quite an influence on overall competency in life. Which goes a long way towards explaining your bankruptcy and genral failur at, well, everything Bertie |
#164
Mxsmanic wrote in
: Bertie the Bunyip writes: IQ isn't really age related. though it is true that capacity increases with age, the measurement is usually like/like otherwise it's kind of pointless. Capacity does not increase or decrease significantly with age. IOW you were as big an idiot then as now. Bertie |
#165
Mxsmanic wrote in
: Martin writes: The average IQ of US enlisted men tested during WW1 was that of a12 year old. IQ does not vary with age, Actually it does, nitwit Bertie |
#166
Mxsmanic wrote in
: Bertie the Bunyip writes: That I an believe. But it would be pitched towards a 12 year old education/maturity level, not IQ, I would imagine. Actually, there are good reasons for developing materials for lower IQs. The average IQ is 100. Half the population is above that ... and half of it is below. If you develop material that requires an average IQ to understand, half of the population will not understand it. For this reason, it makes more sense to develop material for a lower target IQ, so that a much larger percentage of the population can handle it. If you target an IQ of 70, for example, about 98% of the population will be able to understand it. This is the reason for "dumbing down" materials to the lowest common denominator (within reason). In commercial endeavors, you dumb down your advertising and other materials until everyone with the money to buy your product or service can understand it. In politics, you dumb down your rhetoric and policy until everyone with the ability to vote can understand it. Wow, you really are a geniius. I have a six month old puppy who could figure that out. And he's house broken! More than we could say for you. Bertie |
#167
Mxsmanic wrote in
: Martin writes: I quoted a recent book by an expert ( MX/Mixi incognito?) on IQ tests. It didn't make much sense to me either. It went on to say that ever since WW1 US advertising has been aimed at 12 year olds. IQ tests are widely misunderstood, and many "experts" misrepresent them in order to further their own personal agendas. Like you do her, you mean. Bertie |
#168
Mxsmanic wrote:
Martin writes: The average IQ of US enlisted men tested during WW1 was that of a12 year old. IQ does not vary with age, so "the IQ of a twelve-year-old" has no meaning. Sure it has meaning. It just isn't very persice terminology. IQs take age into account. If I say, "MX has the IQ of a rat's ass" what I am really saying is, "MX has the IQ of an average rat's ass." The same goes for saying someone has the IQ of a 12 year old. |
#169
On Aug 17, 6:59 am, Bertie the Bunyip wrote:
Mxsmanic wrote : Doug Semler writes: Explain, to me, why I am 6'3, 190 lbs? Perhaps you don't eat much. Wow, maybe you are a genius after all. Nope, he's wrong. My average daily caloric intake is 4500. He snipped out the part that gave him quite a hint... (p.s. my girlfriend HATES me for not gaining weight g) |
#170
Doug Semler wrote in
ups.com: On Aug 17, 6:59 am, Bertie the Bunyip wrote: Mxsmanic wrote : Doug Semler writes: Explain, to me, why I am 6'3, 190 lbs? Perhaps you don't eat much. Wow, maybe you are a genius after all. Nope, he's wrong. My average daily caloric intake is 4500. He snipped out the part that gave him quite a hint... (p.s. my girlfriend HATES me for not gaining weight g) So do I Bertie |
Those *dangerous* Korean War relics | Kingfish | Piloting | 192 | June 19th 06 07:06 PM |
reporting dangerous aircraft | [email protected] | General Aviation | 4 | October 20th 05 09:15 AM |
Okay, so maybe flying *is* dangerous... | Jay Honeck | Piloting | 51 | August 31st 05 03:02 AM |
Dangerous Stuff | [email protected] | Rotorcraft | 21 | July 16th 05 05:55 PM |
Flying - third most dangerous occupation | David CL Francis | Piloting | 16 | October 22nd 03 02:38 AM |
