Cambridge L-Nav
Old August 17th 07, 09:04 PM posted to rec.aviation.soaring
Brian Laverick-Smith
Default Cambridge L-Nav
I have a fault with my cambridge version 2 which I
wonder if any one else has experienced. I will try
the agent but in between time .....?
On a recent flight the speed to fly indicator played
up showing full pull up advice with settings Mc 0
speed 45 knots and showing 2 down ! Before this it
has been good for the two years I have had it
It is 15 years old so maybe it has had its day ? [
like me ]
Any ideas folks
Brian K.G.C.
Brian L-Smith Kent England
Brian L-Smith
Old August 19th 07, 04:47 PM posted to rec.aviation.soaring
David Kinsell
like me ]
Any ideas folks
Brian K.G.C.
Brian L-Smith
I had some intermittent problems with an L-NAV recently.
Netto sometimes showed eight knots up sitting on the ground,
winds aloft sometimes showed as extremely high, and of course
the altitude required indication was way off.
There are some connectors between boards that are tin-plated,
and the processor chip was socketed with a socket having
tin-plated pins. Not good design at all for an aircraft
instrument.
Took it apart, reseated everything including the processor,
and also replaced the battery. Not sure which item fixed
it, but works fine now.
-Dave
Old August 19th 07, 06:33 PM posted to rec.aviation.soaring
01-- Zero One
LNav 'goofiness' is almost always a depleted battery. --No, won't
help to use a 14 volt battery on it David :-)
Larry
"01" Zero One
"David Kinsell" wrote in message
like me ]
Any ideas folks
Brian K.G.C.
Brian L-Smith
instrument.
-Dave
Old August 24th 07, 03:07 PM posted to rec.aviation.soaring
David Kinsell
01-- Zero One wrote:
LNav ‘goofiness’ is almost always a depleted battery.
The units have a low-voltage warning built in, so anybody
should be able to tell if that's the problem. You can't really
replace the battery without flexing the boards and renewing
the connections, so it's a bit hard to separate the two.
--No, won’t
help to use a 14 volt battery on it David J
I least I don't tell people that radios work just great
on 8 volts :-)
Dave
Larry
“01” Zero One
like me ]
Any ideas folks
Brian K.G.C.
Brian L-Smith
instrument.
-Dave
Old August 24th 07, 04:31 PM posted to rec.aviation.soaring
01-- Zero One
Actually, I was speaking of the internal battery inside the LNav. It is
a small coin style battery used to retain settings. I have had mine go
south and all sorts of weirdness were the result.
Larry
PS: Dave, maybe you need to run your radios on metric volts or
something. :-)
--No, won't
on 8 volts :-)
Dave
Larry
"01" Zero One
like me ]
Any ideas folks
Brian K.G.C.
Brian L-Smith
instrument.
-Dave
Old August 25th 07, 12:17 PM posted to rec.aviation.soaring
Pete Startup
And the wierd stuff starts LONG before the battery
reaches the low voltage level that gives the warning!
Pete
Pete Startup
Pete
Cambridge 302 & PDA -- Value of adding Cambridge 303? V1 Soaring 5 July 31st 07 03:51 AM
Cambridge Mark Hope Soaring 11 November 25th 04 09:40 PM
Cambridge 302/Cambridge 3UTIQ255 utility/ WinPilot/iPAQ 4155 Nathan Whelchel Soaring 4 July 5th 04 11:22 PM
Cambridge "V" JJ Sinclair Soaring 0 March 11th 04 02:01 PM
FS Cambridge 302/303 H201b Soaring 2 December 21st 03 09:05 PM
