Learning to spray paint
Old August 20th 07, 02:08 PM posted to rec.aviation.homebuilt
mhorowit
Default Learning to spray paint
I've assembled my compressor, mounted a regulator/filter, have done
some sandblasting, and done some grinding with my die grinder. Now
it's time to learn how to use the paint sprayer.
I've been spraying water on a cardboard surface, but the viscosity/
volitility of water is such that I fear I'm not getting much out of
the exercise.
My end objective is to spray 2-part epoxy primer, but that's expensive
to learn on.
Any suggestions on an inexpensive medium to practice with? Enamel
diluted IAW directions? Interior housepaint? - Mike
Old August 20th 07, 03:34 PM posted to rec.aviation.homebuilt
Stealth Pilot[_2_]
the exercise.
to learn on.
be sure to put a water trap in the air line. mine is a sintered jobbie
which combines a step down pressure regulator in one.
I had a friend who painted an Aeronca fuselage with a commercial spray
gun. at the end of the job he guessed that the overspray on the floor
was worth over $200.
I took the hint and sprayed my entire Auster fuselage with enough
overspray to leave just the faintest green dust on the floor. cost of
the overspray was probably $2.
what I used was a miniature Revel type airbrush. it gave a spray just
as wide as the tube and actually sprayed just as fast as a full size
gun. The revel type is the really simple airbrush with the plastic
handle, on off air button control and the little glass bottle. It
blows air past a paint nozzle just like a flit gun.
I found that the airbrush would eventually gum up with dry epoxy paint
even when washed out in solvents.
They cost me $14 each in various shops and over the course of the
fuselage spray task I used 4 of them.
The other benefit is that they spray so little solvent into the air
that you have a far healthier environment to work in.
dont be fooled by the diminutive size of the airbrush. they actually
work beautifully on tube fuselages.
One thing I found is that it is easy to miss the face of a tube. have
someone else look over the fuselage for missed areas. You'll find them
guaranteed.
I practised on the first tubes with the actual thinned epoxy paint.
Stealth Pilot
Old August 20th 07, 05:46 PM posted to rec.aviation.homebuilt
mhorowit
On Aug 20, 10:34 am, Stealth Pilot
the exercise.
to learn on.
guaranteed.
Stealth Pilot
A winner! I was worried about overspraying the neighborhood. I'll
GOOGLE for Revel+airbrush - Mike
Old August 20th 07, 09:14 PM posted to rec.aviation.homebuilt
Morgans[_2_]
The water trap suggestions should be taken as a "must."
I am not sure how it carries to using an airbrush, but I would imagine that
it does.
I use a HVLP conversion sprayer, which is High Volume Low Pressure and the
conversion means it takes relatively high compressor pressure, and regulates
it downward, to as low as 15 pounds per square inch. The higher pressures
atomize the paint better, but at the cost of more over spray. A decent 100
buck HVLP can also spray a very narrow pattern, and when used with low
pressure, almost no overspray.
For water control, I made a primary water trap myself, then used a
filter/desiccant to get the air really dry. You can get them at NAPA, and
they go inline right before the gun.
For my water trap, (follow along carefully, here g) I took the air from
the compressor, and went into a 1 1/4" T, with the air coming in the side.
On the bottom side of the T, there is a petcock (valve) to drain out water
once it accumulates. You can also leave it open a very small amount, and
water will dribble out. In the top of the T, there is a 6' tall 1 1/4"
steel pipe, and at the top a reducing coupler, which goes to a regulator,
and then to a quick connector to hook your air line into, going to your
sprayer.
The trap works better than commercial units for two reasons. One, is that
the small air line going into a large pipe will allow the air to cool, and
will cause the water vapor to condense out. Two, since the air is moving so
slowly, the water will run down the sides of the pipe, and can drain out the
bottom.
Jim in NC
Old August 20th 07, 10:51 PM posted to rec.aviation.homebuilt
cavelamb himself[_4_]
it does.
sprayer.
bottom.
I second the HVLP approach.
Mine is a $90 Harbor Freight cheapie that I've used for the last 8 years.
It makes very little overspray, and works fine.
Richard
Old August 20th 07, 11:39 PM posted to rec.aviation.homebuilt
Morgans[_2_]
I should add that there is not enough tea in China to make me spray a
fuselage with an airbrush, when I could fill the quart HVLP gun one time, or
perhaps two, and do it all. The waste factor difference would be very
small, indeed.
Jim in NC
Old August 21st 07, 01:10 AM posted to rec.aviation.homebuilt
Kyle Boatright
"Morgans" wrote in message
or perhaps two, and do it all. The waste factor difference would be very
small, indeed.
Jim in NC
Agreed. Time has a value. Personally, I'd use one of the little HF touch
up guns. Handy, inexpensive, and can be adjusted to provide a fairly fine
spray pattern.
Another thought is using a brush (Horrors, I know ;-)). No overspray and
you get very good control of where the stuff goes.
An earlier suggestion about having someone else look it over when you're
done is a winner. There are probably 1001 nooks and crannies in a fuselage.
You will miss some.
KB
Old August 21st 07, 02:04 AM posted to rec.aviation.homebuilt
small, indeed.
Jim in NC
spray pattern.
You will miss some.
KB
Tommy taught me to set up bright lights all around the subject
and to watch the paint in the glare.
Worked for me...
Old August 21st 07, 03:50 AM posted to rec.aviation.homebuilt
Ernest Christley
small, indeed.
I second the cheapy HF HVLP sprayer. The suck at spraying regular
paint, but the watery aircraft paints are a perfect match for it. It
puts down PolyTone in a perfect layer.
I used a $6 airbrush from Northern Tool to spray a lot of the tube on my
project. It clogged up beyond repair about halfway through the
fuselage. It was actually beneficial that it was so small, because I
couldn't have gotten a touchup gun into all that small spaces between
tubes. I ended up doing a large section with a 3" roller. That worked
really well for everything except the tight corners. If I had to do it
over again, I'd roll as much as I could and hit the corners with the
modeler's airbrush.
"Life is not a journey to the grave with the intention of arriving
safely in
a pretty and well preserved body, but rather to skid in broadside,
thoroughly used up, totally worn out, with chocolate in one hand and
wine in
the other, loudly proclaiming 'WOO HOO What a Ride!'"
--Unknown
Old August 21st 07, 11:13 AM posted to rec.aviation.homebuilt
Morgans[_2_]
spray pattern.
Yep, I have atouch up gun too, but I don't know of a HVLP touch up gun, so I
have found they have a lot more overspray. That is the biggest drawback, to
me.
fuselage. You will miss some.
Yep. That is why I like a spray instead of a brush. g Along with the
having someone else look for misses, another best suggestion is to get
plenty of light. LOTS of light. So many lights, you get as many as you
think you need, then triple it!
The key here, is to always have a light source so that it will reflect off
of the surface and to the eye. You HAVE to be able to see these reflections
to know if it is going down thick enough, if it is missing a surface, if
there is a run, and if ...... You get the idea. Light, and lots of it is
key.
Jim in NC
Anti-fog window spray? Peter R. Owning 9 October 17th 06 04:19 AM
End Of Spray Season [email protected] Rotorcraft 0 September 24th 05 02:44 AM
FA: New WALCOM Spray Guns FYIS.org Home Built 0 August 11th 05 08:36 PM
The NEW liquid spray Pledge - Pledge® Multi-Surface Clean & Dust Spray No Spam Owning 6 February 15th 05 05:50 PM
Interior Spray Paint Ben Smith Owning 11 June 14th 04 08:33 PM
