Towing glider trailers with a VW Jetta Wagon?
Old August 22nd 07, 03:31 PM posted to rec.aviation.soaring
Mike[_8_]
Default Towing glider trailers with a VW Jetta Wagon?
I used U-Haul to install hitches on two different Volvo's. Found them
to be the least expensive and their equipment works very well.
On Aug 22, 6:11 am, Allan wrote:
Thanks for all the advice guys.
Now I just have to find a place to install a hitch at a decent price!
-Allan
Old August 22nd 07, 04:18 PM posted to rec.aviation.soaring
Dylan Smith
On 2007-08-21, Allan wrote:
Which engine? I have the 1.9 TDI, which I think has plenty of power
for it...
Turbodiesels are EXCELLENT for towing. My Dad races F2 motorcycle
sidecar outfits. He used to have a 1.9l Peugeot turbodiesel, and would
tow a large caravan with the sidecar, tools, spare engines, full
sleeping accomodation (although a little ratty!) with no problems - that
caravan was a lot less aerodynamic and quite a bit heavier than a glider
trailer.
That engine did something like 300,000 miles before the headgasket
finally went, too.
Yes, the Reply-To email address is valid.
Oolite-Linux: an Elite tribute: http://oolite-linux.berlios.de
Old August 22nd 07, 06:05 PM posted to rec.aviation.soaring
Papa3
for it...
trailer.
finally went, too.
Oolite-Linux: an Elite tribute:http://oolite-linux.berlios.de
Alan,
I responded last night, but looks like the post disappeared into the
electron cloud.
Others have pretty much covered it. What I was going to add:
- When I looked at the 2004 Jetta wagon, I researched hitches and
found several. Hidden Hitch had a nice, bolt-on unit IIRC. I ended
up with the much heavier Passat V6 with 4 Motion, which is a fantastic
tow vehicle.
- I towed for years with several VWs ranging from a 1982 Rabbit
Diesel (not so hot) to a couple of Jetta Sedans (okay).
- Make sure your trailer has good surge brakes and DON'T go with the
anti-sway bar which,at least with those I researched, disabled the
surge brake.
- Just be aware that panic stops and/or turning maneuvers are a
little riskier with smaller vehicles, but it is manageable if you are
a little conservative.
Erik Mann
LS8-18 (P3) towed by Passat V6 Wagon with 4 Motion
Old August 23rd 07, 07:46 AM posted to rec.aviation.soaring
Michael Huber
*Have 7% of the trailer's actual mass on the hitch. Measure with some
bathroom scales and a length of wood cut to the correct height to fit
between hitch and the scales. It's important to get this number right
- no more, no less. If the 7% value is more than the car's noseweight
limit, you'll just have to keep within that limit and accept a less
than optimum noseweight.
Keep the trailers inertia about the vertical axis low, this means never put
weight in the back to counterbalance too much weight in the front. Heavy
items should be near the center of gravity of the trailer, a drawer near the
axle is the best place if heavy items have to be in the trailer.
Michael
Old August 23rd 07, 11:23 AM posted to rec.aviation.soaring
Del C
Ye Gods! No wonder we are getting climate change if
all US pilots run gas guzzlers like that! VW Jetta
sized cars routinely tow glider trailers in Europe
without any problems. My 1.6 litre turbo diesel will
tow heavy two-seaters up the steepest hills in the
UK.
Del C
At 23:00 21 August 2007, J A C K wrote:
Allan wrote:
I have one and I'm seriously thinking about putting
a hitch on it to
(among other things) tow glider trailers with.
Anyone out there doing it?
What hitch do you have?
plenty of power
for it...
Well, Canada has some impressive topography, Allan,
so it might depend
on where you are towing. I like my '99 5.0L V8 Ford
Explorer for the
eastern part of the USA. My Cobra trailer has a 2200
Max Gross Weight
which is WELL within the Ex's capabilities, but I prefer
not being
reminded constantly that I am moving something extra
down the highway.
And, don't forget, there certainly are heavier combinations
than my
DG-303/Cobra.
If you like the idea of operating under a significant
power limitation
_and_ you never leave the the table-flat areas of Canada,
then you may
be satisfied. You may find more apropos responses from
people who deal
with European autos and road conditions on an everyday
basis, but then
expectations in North America can be very different.
Not the least of
those is that you will be expected to keep up with
the rest of us who
ARE driving the 5.0 L models and who are relatively
unperturbed by
either stop-and-go traffic or rising terrain.
Jack
Old August 23rd 07, 04:34 PM posted to rec.aviation.soaring
1sl
-Allan
Hi Allan,
Didn't see this thread until. I have a 2003 TDI Wagon and use it to tow
my LS1 very comfortably. There are at least two other TDI Jetta Wagons
around here towing gliders and all of us are very happy with the vehicle
as a commuter and for glider transport. You will only use a little more
fuel with the trailer attached. I think the TDI has the large VR6
radiator. The electric cooling fans in my car never operate unless the
air conditioning is activated. I installed a Hidden Hitch (the name
bugs me because the apparatus is so visible). It's necessary that the
installer put one bolt through the cargo area but the rear tow eye is
used to secure the other side. Ziebart was the installer, if you have
them in your area.
My club-mates recently retrieved me from a nearby field. Three of them
arrived in the car and four of us returned with the glider. Weight was
not an issue but it is flat country around here. I find the main
down-side to the Jetta is the low clearance. You will need to be careful
where you drive it off-road.
Old August 23rd 07, 09:30 PM posted to rec.aviation.soaring
Eric Greenwell
- no more, no less.
I'm curious about where this 7% number comes from. The number I
routinely see is 10%, and it's always stated as a *minimum*, not an optimum.
* "Transponders in Sailplanes" http://tinyurl.com/y739x4
Old August 23rd 07, 09:36 PM posted to rec.aviation.soaring
Dan G
The Caravan Club of Great Britain. They contracted Bath University to
do some thorough research in the 1990s using a heavily instrumented
caravan and towcar. TBH, in all the advice above, I was just quoting
them :-).
Dan
Old August 24th 07, 01:15 AM posted to rec.aviation.soaring
Eric Greenwell
them :-).
A caravan is quite different creature than a glider trailer, so I'd
hesitate to accept their values without knowing more. Did the 7% figure
apply to single axle trailers towed with standard hitches, meaning no
dampeners or load distributing hitches?
Can you give me a link to the document you are quoting from?
Old August 24th 07, 12:59 PM posted to rec.aviation.soaring
Dan G
Did the 7% figure
Yes - single axle, no dampers. You really shouldn't need one.
The original work from Bath University was published in the Caravan
Club's magazine "En Route" in 1994. They still publish the resulting
guidelines though - there's a limited amount he
http://preview.tinyurl.com/y8uqrk
The full details are in the member's handbook.
Dan
Led lights for glider trailers Mal[_4_] Soaring 11 July 12th 07 12:06 AM
Glider Towing Available - Payson AZ (& local) [email protected] Soaring 0 June 5th 07 10:20 PM
Welcom Wagon at Air Venture Tom Wait Home Built 1 May 5th 06 03:00 AM
Pic trailers culverflyer Soaring 1 May 5th 04 01:37 AM
Glider trailer towing Jeff Landfield Soaring 0 July 21st 03 04:25 AM
