OK, you just landed at a deserted strip and called for an aero-
retrieve, but there's nobody around to run your wing. Been there, done that, and it wasn't pretty! I put the right wing down and aimed the fuselage 30 degrees left of runway heading, hooked up the rope, climbed in and crossed my fingers! As expected, the drag from the down wing swung the nose to the right, but I almost nailed a runway light before aileron control kicked in and I was able to get the right wing up. There's got to be a better way! For several years, now I have carried a wing tip wheel that I use for wing-runner-less, aero-retrieves. It consists of a padded aluminum glove that slips over the leadind edge and is held in place with duct- tape. The wing tip is raised about 6" off the ground which is high enough to avoid gravel and low weeds. I once used it at strip that was only 40 feet wide. I placed the main gear 7 feet from the runway lights on the right and my tip wheel 7 feet from the lights on the left. She rolled straight as an arrow! Several pilots have asked me to make them one of my tip wheels, so I finally ordered the parts and made a batch of 10 units. Assembled, it measures 8" X 8" X 6". Remove the hinge pins and slip the 5" wheel inside the glove and the height is reduced to only 2" for easy storage. E-mail me for photos, price is set at $125 and I'll pay the shipping (US). JJ Sinclair |
In article . com,
JJ Sinclair wrote: OK, you just landed at a deserted strip and called for an aero- retrieve, but there's nobody around to run your wing. Been there, done that, and it wasn't pretty! I put the right wing down and aimed the fuselage 30 degrees left of runway heading, hooked up the rope, climbed in and crossed my fingers! As expected, the drag from the down wing swung the nose to the right, but I almost nailed a runway light before aileron control kicked in and I was able to get the right wing up. There's got to be a better way! A solution that I've seen used a bit is to carry a large rubber sucker, nearly the size of a plumbing plunger, and a piece of dowel/bambo/PVC pipe of the appropriate length for your glider. When you need it you stick the sucker under the wingtip and poke the support in. As you take off the support either falls out (wood or bamboo are bio degradable) or just dangles there till you get home. This saves scouring the area for a suitable support for the wing. It has its drawbacks though. The retrieve stories are much less interesting than the ones that involve creative use of local resources. We have this in the clubs Duo, but I've never used it. I get the student to run the wing and leave them behind. -- Philip Plane _____ | ---------------( )--------------- Glider pilots have no visible means of support |
On Aug 23, 7:21 am, JJ Sinclair wrote:
OK, you just landed at a deserted strip and called for an aero- retrieve, but there's nobody around to run your wing. Been there, done that, and it wasn't pretty! Me too and decided never again. I built a compact tip wheel from a rectangle of sheet aluminum, 2 short length of aluminum angle section, and a roller blade wheel. It took about an hour to make form scrap I had on hand. It's pre-prepared with double sided carpet tape and wrapped with enought tape to fair it. It can be stuck under either wing tip in a minute or so. It tested ok on a paved runway but may not stand up to a rough strip. The adavantage of the flat plate design over a shaped leading edge cuff if that it fits both wings. Disadvantage more likely to get knocked off. Andy |
On Aug 23, 2:59 pm, Andy wrote:
On Aug 23, 7:21 am, JJ Sinclair wrote: OK, you just landed at a deserted strip and called for an aero- retrieve, but there's nobody around to run your wing. Been there, done that, and it wasn't pretty! Me too and decided never again. I built a compact tip wheel from a rectangle of sheet aluminum, 2 short length of aluminum angle section, and a roller blade wheel. It took about an hour to make form scrap I had on hand. It's pre-prepared with double sided carpet tape and wrapped with enought tape to fair it. It can be stuck under either wing tip in a minute or so. It tested ok on a paved runway but may not stand up to a rough strip. The adavantage of the flat plate design over a shaped leading edge cuff if that it fits both wings. Disadvantage more likely to get knocked off. Andy I use any handy local vegetation (commonly called "a stick") Prop up the wing with that. Get in... Ask Tow plane to hang on the brakes and do a full power run up before releasing brakes. Hold onto your brake as the tension comes on. Release brake and your off.. The "stick" is bio de-gradable too. Regards Al |
Last year a couple of local pilots landed at a very dusty strip
(little more than a road in the middle of a pasture) and called for areo-retrieves. Using the first-to land; first-to-tow rule; No. 1 gets no. 2 to run his wing. No. 1 goes IFR in dust, but is able to keep his wings level by looking sideways (down the wing). No. 2 tried it without a wing runner, went IFR and didn't realize he was into a full blown ground loop, until it was too late. No. 2's ship spent the Winter in the repair shop! Guess who just ordered one of my wing tip wheels? JJ |
JJ Sinclair wrote:
Last year a couple of local pilots landed at a very dusty strip (little more than a road in the middle of a pasture) and called for areo-retrieves. Using the first-to land; first-to-tow rule; No. 1 gets no. 2 to run his wing. No. 1 goes IFR in dust, but is able to keep his wings level by looking sideways (down the wing). No. 2 tried it without a wing runner, went IFR and didn't realize he was into a full blown ground loop, until it was too late. No. 2's ship spent the Winter in the repair shop! Guess who just ordered one of my wing tip wheels? I say No. 1! Next time he lands out with another pilot, he talks No. 2 into running his wing by loaning him the wing tip wheel. Did anyone consider shortening the tow rope, so the dust is kicked up behind the glider? I know, it might be only 60' long, but I'm told the Poles use short ropes for field retrieves. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * "Transponders in Sailplanes" http://tinyurl.com/y739x4 * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
Did anyone consider shortening the tow rope, so the dust is kicked up behind the glider? I know, it might be only 60' long, but I'm told the Poles use short ropes for field retrieves. Maybe the Poles just use long poles? (sorry....couldn't resist) Uri 4X-GGG |
I remember well using the stick technique with my Jantar-1. As the
glider starting moving, the wing fell onto the ground with a thud, pulled me off the runway and I only just managed to avoid a ground- loop by aggressively using full rudder and aileron. A later similar attempt in my ASW-20 wasn't much better. I now refuse to try a field retrieve with my present ship without a wing runner and think the stick-on wheels are a great idea. Mike |
On Aug 24, 9:58 am, "
wrote: I use any handy local vegetation (commonly called "a stick") I have also use the stick method. One time there was a suitable source, the stick stayed in place, and I did a perfect takeoff. The only other time I tried it the wing dropped immediately and I had to abort. Then a farm worker showed up and, even though we had no language in common, I was able to show him how to be more reliable than the stick. It's often hard to find suitable sticks in Arizona, creosote bush is about the only source in many places. I had thought of carrying suitable lengths of dowel in the glider but decided the stick on tip wheel would be better, at least for paved runways. So carry a tip wheel for paved runways and dowels for unprepared surfaces? Andy |
| Soft field landings - low wing vs high wing aircraft | Justin Gombos | Piloting | 19 | May 23rd 07 06:21 AM |
| Books on Military Rotary Wing to Civilian Fixed Wing Transition? | Greg Copeland | Piloting | 5 | May 2nd 07 04:23 AM |
| Anyone building/flying a Ridge Runner? | Russell Duffy | Home Built | 10 | September 16th 05 03:58 PM |
| High wing to low wing converts...or, visa versa? | Jack Allison | Owning | 99 | January 27th 05 12:10 PM |
| Mylar tape wing seals - effect on wing performance | Simon Waddell | Soaring | 8 | January 1st 04 04:46 PM |
