The FCC is full speed ahead with its BPL (Broadband over Powerline)
rule-making, and the U.S. Air Force is looking to spend billions now on replacement communications systems, as the use of HF radio will no longer be possible. Some studies have even predicted that interference problems will go all the way into the aircraft VHF navigation and voice bands. "Certainly, the end of LORAN and marine DGPS is at hand" said William C. Brodie, Air Force Director of Communications. FCC Commissioner Abernathy says that BPL will be "Broadband Nirvana." The military is trained to adapt, and they will adapt to consumer needs. http://hraunfoss.fcc.gov/edocs_publi...C-239079A1.pdf |
"Gene Storey" wrote in message ... The FCC is full speed ahead with its BPL (Broadband over Powerline) rule-making, and the U.S. Air Force is looking to spend billions now on replacement communications systems, as the use of HF radio will no longer be possible. Some studies have even predicted that interference problems will go all the way into the aircraft VHF navigation and voice bands. "Certainly, the end of LORAN and marine DGPS is at hand" said William C. Brodie, Air Force Director of Communications. FCC Commissioner Abernathy says that BPL will be "Broadband Nirvana." The military is trained to adapt, and they will adapt to consumer needs. http://hraunfoss.fcc.gov/edocs_publi...C-239079A1.pdf I don't see the people, or the quotes you mention in the URL. What is it you are supposed to be Storey? |
On Mon, 29 Sep 2003 04:27:52 GMT, Gene Storey wrote:
The FCC is full speed ahead with its BPL (Broadband over Powerline) rule-making, and the U.S. Air Force is looking to spend billions now on replacement communications systems, as the use of HF radio will no longer be possible. Why not? Some studies have even predicted that interference problems What's causing the interference? will go all the way into the aircraft VHF navigation and voice bands. Why? "Certainly, the end of LORAN and marine DGPS is at hand" said William C. Brodie, Air Force Director of Communications. And is it? -- "It's easier to find people online who openly support the KKK than people who openly support the RIAA" -- comment on Wikipedia |
"phil hunt" wrote in message . .. On Mon, 29 Sep 2003 04:27:52 GMT, Gene Storey wrote: The FCC is full speed ahead with its BPL (Broadband over Powerline) rule-making, and the U.S. Air Force is looking to spend billions now on replacement communications systems, as the use of HF radio will no longer be possible. Why not? Some studies have even predicted that interference problems What's causing the interference? According to http://www.arrl.org/news/stories/2003/08/08/2/?nc=1 , BRL is using frequecies of 2 - 80 MHz (i.e. HF and sneaking into the bottom end of VHF). I suspect that the power cables are acting as antenna. will go all the way into the aircraft VHF navigation and voice bands. Why? "Certainly, the end of LORAN and marine DGPS is at hand" said William C. Brodie, Air Force Director of Communications. And is it? -- "It's easier to find people online who openly support the KKK than people who openly support the RIAA" -- comment on Wikipedia |
"Nigel Isherwood" wrote in message . .. "phil hunt" wrote in message . .. On Mon, 29 Sep 2003 04:27:52 GMT, Gene Storey wrote: The FCC is full speed ahead with its BPL (Broadband over Powerline) rule-making, and the U.S. Air Force is looking to spend billions now on replacement communications systems, as the use of HF radio will no longer be possible. Why not? Some studies have even predicted that interference problems What's causing the interference? According to http://www.arrl.org/news/stories/2003/08/08/2/?nc=1 , BRL is using frequecies of 2 - 80 MHz (i.e. HF and sneaking into the bottom end of VHF). I suspect that the power cables are acting as antenna. The lines are pretty "long" at those frequencies, to make much of an antenna. |
"phil hunt" wrote
Gene Storey wrote: The FCC is full speed ahead with its BPL (Broadband over Powerline) rule-making, and the U.S. Air Force is looking to spend billions now on replacement communications systems, as the use of HF radio will no longer be possible. Why not? Tune your radio to 60 Hz. After BPL 2 mHz to 80 mHz (and their harmonics) will have trash on the whole spectrum. |
"Gene Storey" wrote:
"phil hunt" wrote Gene Storey wrote: The FCC is full speed ahead with its BPL (Broadband over Powerline) rule-making, and the U.S. Air Force is looking to spend billions now on replacement communications systems, as the use of HF radio will no longer be possible. Why not? Tune your radio to 60 Hz. After BPL 2 mHz to 80 mHz (and their harmonics) will have trash on the whole spectrum. C'mon Gene, try to make some sense here will you?...why should one tune to 60 Hz? (the power line freq btw). Pls do explain what the hell you're talking about. -- -Gord. |
" wrote: "Gene Storey" wrote: "phil hunt" wrote Gene Storey wrote: The FCC is full speed ahead with its BPL (Broadband over Powerline) rule-making, and the U.S. Air Force is looking to spend billions now on replacement communications systems, as the use of HF radio will no longer be possible. Why not? Tune your radio to 60 Hz. After BPL 2 mHz to 80 mHz (and their harmonics) will have trash on the whole spectrum. C'mon Gene, try to make some sense here will you?...why should one tune to 60 Hz? (the power line freq btw). Pls do explain what the hell you're talking about. -- -Gord. I presume he is trying to make the, valid, point that all those power lines radiate a very nice signal at 60Hz, and by implication that they will do the same if BPL is permitted to transmit digital data between 2 and 80MHz over the same lines. It's late, so I'm not going to try and look it up now, but IIRC BPL has been banned in some administrations for precisely that reason - ISTR that Japan is one such administration. BTW John - Long (very long) wires make excellent antennas provided that they are at least several wavelenghts long. Dave |
"Gord Beaman" wrote
C'mon Gene, try to make some sense here will you?...why should one tune to 60 Hz? (the power line freq btw). Pls do explain what the hell you're talking about. The power line frequency (after BPL) will include the frequencies 2 to 80 MHz and the harmonics. I was just using 60 Hz a poor example. WWV time signals will be wiped-out. NDB navigation sites will be wiped out. Etc, etc. The noise floor in the 2-60 MHz band will be significantly higher than it is now, thus requiring higher power, or a change in operating frequency. |
"Gene Storey" wrote in message ... "Gord Beaman" wrote C'mon Gene, try to make some sense here will you?...why should one tune to 60 Hz? (the power line freq btw). Pls do explain what the hell you're talking about. The power line frequency (after BPL) will include the frequencies 2 to 80 MHz and the harmonics. I was just using 60 Hz a poor example. WWV time signals will be wiped-out. NDB navigation sites will be wiped out. Etc, etc. The noise floor in the 2-60 MHz band will be significantly higher than it is now, thus requiring higher power, or a change in operating frequency. Scottish Power are already running broadband over power lines, this doesnt seem to have wiped out HF communication and the authorities in the UK who jealously guard radio frequencies seem not to be over worried. Keith |
| AOPA Sells-Out California Pilots in Military Airspace Grab? | Larry Dighera | Instrument Flight Rules | 12 | April 26th 04 07:12 PM |
| B Nice war - here's the bill | Alan Minyard | Military Aviation | 32 | September 20th 03 07:36 AM |
| Bu$h Jr's Iran-Contra -- The Pentagone's Reign of Terror | PirateJohn | Military Aviation | 1 | September 6th 03 11:05 AM |
| 04 Sep 2003 - Today’s Military, Veteran, War and National Security News | Otis Willie | Military Aviation | 0 | September 5th 03 03:57 AM |
| 07 Aug 2003 - Today’s Military, Veteran, War and National Security News | Otis Willie | Military Aviation | 0 | August 8th 03 03:51 AM |
