Cheap Airplane
Old August 28th 07, 01:33 AM posted to rec.aviation.piloting
Phil
Default Cheap Airplane
Recent discussions about whether or not general aviation is dying
prompted me to start thinking about why it doesn't seem to be possible
to build a really cheap airplane. I know that you can buy a trike or
an ultralight for around $20,000. But you can't really go cross
country in one of those, and you would probably have a hard time
convincing most wives to even consider going up in one at all.
I assume that the reason an airplane like a trike is so cheap is that
it is structurally simple and easy to manufacture. If that is the
case, then to make a cheap airplane that can cruise fast enough to go
somewhere, and do so in reasonable comfort, you need to simplify the
structure.
Which made me remember the article I read about the Facetmobile. For
those of you unfamiliar with this airplane, here is a link:
http://en.wikipedia.org/wiki/Facetmobile
It seems like someone could manufacture a pretty inexpensive airplane
if they used this type of design. If someone could manufacture a
cross-country-capable airplane for around 30 thousand, I would think
they could sell a lot of them.
Making a cheaper airplane would certainly go a long way toward helping
general aviation to grow.
Old August 28th 07, 03:18 AM posted to rec.aviation.piloting
Peter Dohm
"Phil" wrote in message
structure.
I believe that the designer still posts in rec.aviation.homebuilt and the
Facetmobile does at least appear to mitigate one of the major costs of
traditional aircraft--the excessively large hangar/garage space normally
required. Personally, I am a little too much of a traditionalist to fall in
love with it, but it is certianly an intriguing concept and appears to make
a lot of sense in terms of both manufacturing and storage costs.
Peter
Old August 28th 07, 05:52 AM posted to rec.aviation.piloting
James Sleeman
Depends what you think of an Ultralight as, if you're thinking
traditional US Legal Ultralight, then sure I'll agree that it is
realistically local flying. But if you consider the rest of the
world's comparable ultralight definitions, which is basically what the
US has now with LSA, then it's a different matter.
Take the XAir-H for example, http://www.xairusa.com/XAir%20H.html ,
$20,000 should get you flying one behind a Rotax 582, you'll have to
assemble yourself but I have it from somebody who has built one
recently, that it's a doddle even for an office worker like him,
unpack box, follow the step by step instructions basically. Take a
couple weeks off work and go at it, what better vacation ;-)
For something a little more proven (and much better looking IMHO) a
RANS S6 Coyote (http://www.rans.com/3S6ES.htm) or Kitfox (http://
www.kitfoxaircraft.com/) won't hit that much higher, it might take a
bit more work and skill to build though.
I think that for $20,000 you really can't expect anything other than a
kit aircraft in a box. If you want to spend $30,000, buy a kit
aircraft and pay somebody to build it (or just buy a nice used one
which already has the teething trouble worked right out of it).
Old August 28th 07, 12:47 PM posted to rec.aviation.piloting
B A R R Y[_2_]
Or convince your life insurer to cover you.
My life policy has three exclusions:
Skydiving
Hangliding
Ultralights
Flying as a crew member is no big deal to them.
Old August 28th 07, 06:32 PM posted to rec.aviation.piloting
Ross
structure.
But, wasn't that what light sport aircraft were supposed to do?
Regards, Ross
C-172F 180HP
KSWI
Old August 28th 07, 07:09 PM posted to rec.aviation.piloting
Friedrich Ostertag
structure.
Wow, thats an innovative concept. I don't think to many wifes would agree to
go up in one, though :-)
As far as "cheap aircraft to go places" are concerned, there is quite a
number of planes around in the european "ultralight" class (max MTOW 470 kg)
that could well do this. Most of them even look like planes and cruise
speeds of 100 kts are not uncommon. Most of them could be registered in
the LSA class with a somewhat higher MTOW which means they could even carry
two people AND some fuel...
regards,
Friedrich
Old August 28th 07, 11:05 PM posted to rec.aviation.piloting
Blueskies
"Phil" wrote in message ups.com...
Cheap airplane...now that is an oxymoron if I've ever heard one...
Old August 29th 07, 12:32 AM posted to rec.aviation.piloting
Phil
structure.
Regards, Ross
C-172F 180HP
KSWI- Hide quoted text -
- Show quoted text -
The light sport license is cheaper to acquire than the PPL. But a new
light sport airplane is still too expensive for most people. In
looking at the Facetmobile, I am guessing that if it were made from
composites, the top and bottom of the aircraft could each be formed as
a single piece, including the vertical stabilizers. That seems like
it should be pretty inexpensive to manufacture. And it wouldn't have
to have flat surfaces, so it could be even more efficient than the
original. I would guess that with this design you could make a very
competitive light-sport 2-place aircraft with as little as 65
horsepower pulling it. That would make it inexpensive to operate.
Old August 29th 07, 12:35 AM posted to rec.aviation.piloting
Phil
On Aug 28, 1:09 pm, "Friedrich Ostertag"
You may be be right. But she wouldn't have to wear a helmet, and
there aren't a bunch of wires bracing it. So I would think it would
be an easier sell than most ultralights.
Old August 29th 07, 12:44 AM posted to rec.aviation.piloting
Phil
Take the XAir-H for example,http://www.xairusa.com/XAir%20H.html,
RANS S6 Coyote (http://www.rans.com/3S6ES.htm) or Kitfox (http://www.kitfoxaircraft.com/) won't hit that much higher, it might take a
I don't doubt that you could do that, but I think that most people
wouldn't be interested in arranging to have an airplane built. A used
kitplane would be more of a possibility, but I would bet that there
are a lot people who wouldn't want to buy an amateur-built airplane.
I am talking about a manufacturer producing a ready-to-fly airplane
for way less than the current crop of LSAs. I am guessing that labor
costs are the biggest expense in building an airplane. If you can
make an airplane simple enough to construct, it should cost a lot less.
Flying on the Cheap - VOX [email protected] Home Built 6 February 27th 06 03:01 AM
Cheap IO-540 available Orval Fairbairn Home Built 1 February 20th 05 10:08 PM
cheap avgas Dan Luke Owning 10 December 24th 04 04:15 AM
Screwing on the Cheap Bob Hoover Home Built 1 November 1st 04 01:25 PM
Any cheap bastards here? Paul Tomblin Instrument Flight Rules 11 August 17th 03 03:57 PM
