Enlarging a bushing hole?
Old August 28th 07, 01:42 AM posted to rec.aviation.homebuilt
Michael Horowitz
Default Enlarging a bushing hole?
I find myself having to enlarge a bushing's ID by 1/16ths to 3/8ths.
My concern is I don't know how to insure the 3/8" bit is aligned with
the axis of the hole. Centered is good, but I'm more concerned with
the alignment.
Suggestions? - Mike
Old August 28th 07, 01:51 AM posted to rec.aviation.homebuilt
Rich S.[_1_]
"Michael Horowitz" wrote in message
the alignment.
Suggestions? - Mike
Chuck a rod in the drillpress the same size as the existing hole. Slip the
bushing on the rod and clamp it to the table. Replace the rod with your new
drill or reamer. Make shavings.
Rich S.
Old August 28th 07, 03:59 AM posted to rec.aviation.homebuilt
John Ammeter
If you have a lathe or access to one it's simple. Just chuck the
bushing in the lathe with the drill bit mounted on the right side...
can't think of the name of that part..
John
the alignment.
Suggestions? - Mike
Old August 28th 07, 04:42 AM posted to rec.aviation.homebuilt
On Aug 27, 7:59 pm, John Ammeter
That'd be the Wifferdoodle. (Although some folks call it the Tail
Stock.)
-Bob
Old August 28th 07, 11:29 AM posted to rec.aviation.homebuilt
mhorowit
On Aug 27, 8:51 pm, "Rich S."
Rich S.
Thank you Rich - Mike
Old August 28th 07, 05:30 PM posted to rec.aviation.homebuilt
Fred the Red Shirt
On Aug 28, 12:51 am, "Rich S."
the alignment.
Suggestions? - Mike
If it is a sintered bronze bushing machining will close off
the pores and prevent lubrication from reaching the shaft.
The people who make sintered busings say there is a
way to re-open them, but I never asked how.
If it is a solid metal bushing then no problem.
FF
Old August 28th 07, 10:53 PM posted to rec.aviation.homebuilt
Blueskies
wrote in message oups.com...
Stock.)
-Bob
Hmmmm, and I thought it was a tale stock
Old August 31st 07, 03:43 PM posted to rec.aviation.homebuilt
Michael Horowitz
Default Method for expanding tube ID?
This is not an aircraft repair.
I've got a piece of 4130 tubing, about 3" long, 3/4" dia and I'm
trying to slip it over a like size tubing.
Just because I'm trying to let friction do the holding, I'd like to
remove as little metal from the external sleeve as possible.
I made a slot in the tube and expanded it slightly with a wedge.
I though maybe heating the insides would cause it to open like a clam.
I could wedge it open and apply heat, thus deforming the tube.
Other suggestions? - Mike
Old August 31st 07, 03:54 PM posted to rec.aviation.homebuilt
RST Engineering
Go see if your local muffler shop has a tube expander this small.
"If you think you can, or think you can't, you're right."
--Henry Ford
Worm Hole no Need for Black Hole Michael Baldwin, Bruce Products 2 May 8th 07 11:04 AM
Jackson Hole TFR [email protected] Piloting 24 August 23rd 06 04:35 PM
Even during sentencing, this guy is an a*hole H.P. Piloting 45 March 14th 06 11:36 PM
Hole Finder [email protected] Home Built 2 March 6th 06 02:32 PM
Rubber Bushing Replacement Boelkowj Home Built 8 December 12th 03 12:45 AM
