#141
Blueskies wrote:
"Roger (K8RI)" wrote in message ... On Sat, 01 Sep 2007 13:06:04 -0700, Airbus wrote: I was told by the a State Police officer that although in the short term those presentations had a positive effect, the long term effect was negative. People and particularly the young have a tendency to push the envelope. It works out to , "I've been doing that for a long time and nothing happened to me, or I know some one who does that all the time". We had the same kind of problems in industry safety. I think it was Kelly Johnson who said "Make things as simple as possible, but no simpler." Same sort of adage, you really don't know where the line is unless you cross it (or unless you pay attention and do what you are told!) As much as I admire and respect Kelly, I believe that line was said earlier by Albert Einstein. Matt |
#142
karl gruber wrote:
OK, you've posted this same thing twice ... and I never said that Vx was with flaps extended. So, what is your point? Matt Oh.....Reread my post. Evidently your inability to comprehend is affecting your pee brain. I did and it said nothing new. Also, many airplanes do have Vx speeds for clean and dirty configurations. Looks like your knowledge of airplane performance matches your writing and posting ability. Are you going to repost the same message a third time? Matt |
#143
Matt Whiting schrieb:
I prefer the being in the air by the 50% point as it works for almost all airplanes on runways that are on the short side. Just as meaningless as any such rule, and simply not applicable on runways which are "on the short side". As I usually fly off fields with less than 2000 ft runway, I would never get airborne if I followed your rule. |
#144
![]() Morgans wrote: "Newps" wrote For the takeoff in the video no flaps was correct. Could it be considered helpful to get off the ground quicker, so you could suck up the gear and accelerate while still in ground effect? He did get in the air but climbed too fast for the conditions. Once in the air a clean airframe is better than a dirty one. Of course, if you had to call it that close, the decision to take off with all of the weight would be the wrong decision, anyway, so it goes back to no flaps being correct. I have heard of some people doing the takeoff run with no flaps, and slightly before rotation, pop the first notch of flaps down, then milk them up once speed and climb is obtained. That is only beneficial for close in obstacles. |
#145
![]() Matt Whiting wrote: karl gruber wrote: OK, you've posted this same thing twice ... and I never said that Vx was with flaps extended. So, what is your point? Matt Oh.....Reread my post. Evidently your inability to comprehend is affecting your pee brain. I did and it said nothing new. Also, many airplanes do have Vx speeds for clean and dirty configurations. Looks like your knowledge of airplane performance matches your writing and posting ability. Are you going to repost the same message a third time? In the Bonanza the difference between clean and dirty Vx is 23 knots plus or minus a couple knots for different model years. |
#146
If you're manufacturer only gives you a clean wing Vx and Vy. I have
speeds for both flaps up/clean and flaps 20/dirty Yes......they give both speeds. But they label only one as Vx. |
#147
On Sep 1, 10:56 pm, "Morgans" wrote:
"Dudley Henriques" wrote What seems obvious is not always the answer, and it's the wise pilot who realizes the real safety message will be found along the investigative path that follows the video rather than by watching the video itself without this valuable information. Although I agree in principle as to what you said, I wonder if in this case, we can all take away some knowledge, and cautions, just from the speculations to the possible causes. I don't know if I am explaining myself very clearly. What I'm thinking is that everyone may take some cautions to not do EACH of the possible causes that have been offered up, even if only one or a combinations of a few of the offered explanations are really the cause. What do we take away with us, as possible causes? 1) Downwind takeoff - bad, when conditions may be close to performance limitations. 2) Downwind takeoffs even worse when you get above the tree line. 3) Importance of calculating DA, with a conservative slant. Also to add other performance reducing factors into the performance calculations. 4) Overweight takeoffs are a "bad idea." Weight and CG should be closely considered, especially when it is close to maximum. 5) Lean if necessary for an elevated DA. 6) Possible (big emphasis on this, since we don't really have a reliable indication if the engine was running poorly) rough running engines will hurt takeoff and climb, especially when takeoff performance calculations are marginal. 7) Raising the nose further while on the brink of a stall is all it takes to insure a stall will occur. It seems likely to me, that one, or more likely more or all of the above had a part in the crash. Possible, even probable there are others that nobody has mentioned, or thought of. Still, it makes me think about all of the above while preparing for the next takeoff. Would you, and others, think about it in that way? To me, not knowing what the cause was would remind me to consider all of the possible causes, rather than just the one or ones that are really responsible. How about you? Do you have any other pet theories, or think one of the reasons I have written down may be largely responsible? -- Jim in NC Jim I dont know that the data (the video and incomplete WAT data) support any conclusion right now. Should pilots use prudent flying techniques? Yes. The difference between an amateur and professional pilot is not the airplane that they fly, but it is the method and procedures by which they fly the airplane. All pilots should fly their aircraft within the performance parameters of the vehicle. All pilots should use standardized procedures and methods in their flying. All pilots should have "benchmarks" which measure performance of the vehicle and trigger alternate scenarios. But otherwise right now there are no real lessons to be learned from the video tape. This might turn out to be the Kenner crash...for the WAT and the wind performance problems NOTHING the pilot did except not going would have changed the outcome...or it might turn out to be that the accident was Delta at DFW...(the 727) stupid on its face. Robert |
#148
![]() karl gruber wrote: If you're manufacturer only gives you a clean wing Vx and Vy. I have speeds for both flaps up/clean and flaps 20/dirty Yes......they give both speeds. But they label only one as Vx. Negative. Beech gives you the means to compute Vx for your condition. Weight, configuration, etc. |
#149
Applying Mather weather to Cameron Park is like applying Madison weather to
Oshkosh. Jim -- "If you think you can, or think you can't, you're right." --Henry Ford "Blueskies" wrote in message news ![]() There are no guesses about the weather in my post...the data sources are quoted and you cut them out. The closest weather was from Mather and you assumed the rest. |
#150
Or even better (divide by 4, multiply by 3) 75%.
Jim -- "If you think you can, or think you can't, you're right." --Henry Ford "Matt Whiting" wrote in message ... As though you could really measure 71% accurately on most airspeed indicators. Why not just say 70%? Matt |
Oshkosh P-51 crash video | Frank from Deeetroit | Aviation Photos | 0 | July 30th 07 06:06 PM |
S-3 Crash Video | Sanderson | Naval Aviation | 0 | June 13th 05 10:22 PM |
Orlando Crash Video | Jay Honeck | Piloting | 35 | January 21st 05 03:30 AM |
VIDEO: Helicopter crash | Micbloo | Rotorcraft | 0 | November 3rd 04 03:28 AM |
Video of crash 206 | gaylon9 | Rotorcraft | 9 | December 2nd 03 04:53 PM |
