Fatal accident in Scotland
Old September 4th 07, 02:56 PM posted to rec.aviation.soaring
Ian
Default Fatal accident in Scotland
On 4 Sep, 10:37, Andreas Maurer wrote:
Why not simply keep the left hand *very* close to the release handle
as suggested by standard operating procedure?
We used to have a system in the UK which ensured this: the pilot waved
one finger for "take up slack" and two for "all out". Thus the launch
didn't start until the signaller was assured that the pilot had a hand
free. Now the launch starts when the signaller feels like it, and s/he
just has to hope that the pilot has a hand near the release, and not
scratching himself, adjusting the altimeter, twiddling with the GPS -
or actually on the release, ready for an unwanted pull off when the
wheel hits a bump.
I'm sure it will change back in due course.
Ian
Old September 4th 07, 03:40 PM posted to rec.aviation.soaring
Markus Gayda
Hi Ian,
wheel hits a bump.
I am sure that i would NOT want to signal a final "go" in a Discus or Mini-Nimbus.
The release handle is down at the bottom of the stick. With long trousers you
can have trouble grabbing it fast.
I made it a habit to put two fingers over it before launching (both winch and
aero-tow). That way i wont pull it inadvertendly (fingers are stretched out,
not really gripping the handle) but i am still able to release fast without
searching for the damn knob.
CU and happy landings,
Markus
Old September 4th 07, 03:59 PM posted to rec.aviation.soaring
Andrew Warbrick
Default Winch launch procedure and accidents
This is mostly an attempt to rename a thread which
now has NO connection whatsoever with 925's crash on
Sunday.
As I understand it, the British system was changed
after accidents where pilots accepted a cable without
being ready to go and were winched off as a result
of, for example, scratching their noses. We can now
drill into pupils that you don't accept a cable until
you are ready to launch and your hand stays near the
release until the end of the launch, which will proceed
without any further pilot to launch marshal communication
being required.
It's a system which works well. If the pilot, for any
reason, wants to abort the launch they can pull the
release and shout 'stop'. The worst that can happen
in that case is the launch marshal fails to notice
and the cable has to be pulled back out.
At 14:42 04 September 2007, Markus Gayda wrote:
Hi Ian,
the pilot waved
one finger for 'take up slack' and two for 'all out'.
Thus the launch
like it, and s/he
release, and not
with the GPS -
pull off when the
wheel hits a bump.
I am sure that i would NOT want to signal a final 'go'
are stretched out,
Markus
Old September 4th 07, 04:02 PM posted to rec.aviation.soaring
Mark Dickson
The system of winch launch signalling, in the UK, was
changed so that pilots had their fingers close to the
release on take-off; not sticking two fingers up in
the air. You are not meant to accept the cable until
you are ready to launch, all fiddling complete; you
accept the cable you are ready to go.
the pilot waved
Thus the launch
pilot had a hand
like it, and s/he
release, and not
with the GPS -
off when the
wheel hits a bump.
Ian
Old September 4th 07, 04:20 PM posted to rec.aviation.soaring
Ian
On 4 Sep, 15:59, Andrew Warbrick
Sunday.
That was the claim. In reality, I think it was changed because Lasham
had a new CFI who wanted to make an impact on the gliding scene.
I'm all in favour of changing systems from time to time. When people
have to think about what they are doing they are less likely to make
accidents from unwarranted assumptions. I still don't like losing that
degree of control of the launch, though.
Ian
Old September 4th 07, 04:22 PM posted to rec.aviation.soaring
Ian
On 4 Sep, 16:02, Mark Dickson
Not meant to, no. However, I think there is another side: the cable
should not be offered to the glider unless the launch can proceed
immediately. All too often the cable is attached, then there is a
short delay, then the deay gets longer, then the pilot gets
distracted, then ...
The old system ensured that when the launch started, the pilot had a
had free. It may not have been in the right place, but at least it was
guaranteed not to be reprogramming a GPS ...
Ian
Old September 4th 07, 04:28 PM posted to rec.aviation.soaring
Cats
wheel hits a bump.
We now have a system in which the pilot decides when to hand control
over to the launch point, by asking for the cable to be attached. He/
she shouldn't do that until the are absolutely ready to launch. When
launching I don't have a free hand, as one is on the stick and the
other is holding or touching the yellow knob. I wouldn't want to take
my hand off that yellow knob (especially in the Discus) as if I need
it in a hurry I can be sure I'll have trouble finding it. The one
time I've had to pull off I was glad all I had to do was do it, rather
than struggle to find the knob in a new type of glider.
So, personally, I hope we stick with the current system.
Old September 4th 07, 05:31 PM posted to rec.aviation.soaring
Rory O'Conor[_2_]
I learnt to glide after the new system was introduced.
I have two hands and at the start of a winch launch I want one hand on the =
release and the other on the joystick, so I have no free hand for signallin=
g (at the all out stage)
=20
I am happy either for someone external to signal, or as at happened when I =
winched recently in France, to use the radio. I can also understand the use=
of a wings level signal (for up slack), but this does not work when you ha=
ve a glider full of water, which needs level wings prior to the start.
Rory
Newsgroup: rec.aviation.soaringSubject: Winch launch procedure and acci=
dentsAuthor: Ian Date/Time: 15:20 04 September 2=
007
As I understand it, the British system was changed after accidents wher=
e pilots accepted a cable without being ready to go and were winched off a=
s a result of, for example, scratching their noses.
__________________________________________________ _______________
The next generation of MSN Hotmail has arrived - Windows Live Hotmail
http://www.newhotmail.co.uk=
Old September 4th 07, 07:59 PM posted to rec.aviation.soaring
Ian
On 4 Sep, 17:31, Rory O'Conor
"On" the release? Eeek. People have had nasty accidents that way!
Ian
Old September 4th 07, 08:07 PM posted to rec.aviation.soaring
Andrew Warbrick
Depends on your definition of 'on'. I have my fingers
'on' the release at the start of a winch lauch. By
that I mean that I rest two straight fingers on the
top of the release knob, either side of the cable.
What I don't do is curl my fingers round it unless
I need to pull it.
'On' the release? Eeek. People have had nasty accidents
that way!
Ian
Another fatal accident Mike the Strike Soaring 0 September 20th 06 11:50 PM
Fatal accident in Italy 2cernauta2 Soaring 1 April 4th 06 05:50 PM
Fatal accident near Wenatchee, WA [email protected] Soaring 2 June 27th 05 01:54 AM
Pilot's 2nd Fatal Accident Aardvark Piloting 44 May 21st 04 02:34 PM
Hawaii Fatal Accident Rocky Rotorcraft 0 July 25th 03 03:01 PM
