New iPAQ 210
Old September 6th 07, 08:17 PM posted to rec.aviation.soaring
Paul Remde
Default New iPAQ 210
Hi,
A few customers just clued me in about the upcoming new iPAQ 200 Series. It
looks like an excellent replacement for the iPAQ hx4700. The only question
is whether or not the "24 pin connector" is the same as used on previous
iPAQs and whether or not it has an RS-232 serial port. I hope it does.
You can see details he
http://www.hp.com/hpinfo/newsroom/pr...2007/mobility/
http://www.hp.com/hpinfo/newsroom/pr...ds_ipaq200.pdf
http://www.shopping.hp.com/product/s...JqT!-973312366
http://h18000.www1.hp.com/products/q.../12781_na.HTML
Let me know if you find out anything about RS-232 serial communications.
Good Soaring,
Paul Remde
Cumulus Soaring, Inc.
http://www.cumulus-soaring.com
Old September 6th 07, 08:45 PM posted to rec.aviation.soaring
Tuno
The datasheet says it has USB -- not "USB Client", as it says for the
100 series -- so it may be a candidate for a USB-serial adapter. The
SDIO should also offer possibilities for a -232 interface.
Old September 7th 07, 06:05 PM posted to rec.aviation.soaring
Checking the HP data, the legacy PDA's (such as my 3970 and 5150)
appear to use a "22 pin connector". So it's possible that the 210
uses a new ("24-pin") connector.
Sure would be cool to use the mini-USB.
Kirk
FS iPaq Ed Hollestelle Soaring 6 April 28th 05 01:28 AM
New iPAQ Jacek Kobiesa Soaring 7 September 26th 04 07:44 PM
IPAQ 6300 Shaber CJ Soaring 2 August 31st 04 01:32 AM
MLR+IPAQ->OLC? jaro Soaring 0 June 23rd 04 04:06 PM
looking for iPAQ 3950 S Schwartz Soaring 2 June 13th 04 04:11 PM
