How to search on the Internet for Steve Fossett's Citabria taildragger
Old September 14th 07, 10:10 PM posted to alt.comp.freeware,sci.geo.satellite-nav,rec.aviation.piloting
Rudy P
Default How to search on the Internet for Steve Fossett's Citabria taildragger
I still did not figure out how.How do you report a hit?
"John Tyson" wrote in message
"Rudy P" wrote in message
I have a plane,not sure if on the ground. Please if others could check.
LAT.38.698404 LON.-119.037355 Rudy.
Whether it's on the ground or in the air, it's the type of thing they want
you to report.
John
  #42
Old September 14th 07, 10:21 PM posted to alt.comp.freeware,sci.geo.satellite-nav,rec.aviation.piloting
John Tyson
I thought you found the plane while participating in the "mechanical turk"
search, in which case reporting it would have been a part of the process.
If you found it just by looking, probably the best bet would be to go to the
Steve Fossett website http://www.stevefossett.com/ and just report it on
their contact link.
John
  #43
Old September 14th 07, 10:38 PM posted to alt.comp.freeware,sci.geo.satellite-nav,rec.aviation.piloting
Capt. Geoffrey Thorpe
"A hotline has been established for tips in the search for Steve.
The number, (910) 396-0704 and when the tone comes, dial 4719.
Officials say tipsters should be prepared to leave their name, contact
number, latitude and longitude coordinates and a description of the
area."
Geoff
  #44
Old September 14th 07, 10:50 PM posted to alt.comp.freeware,sci.geo.satellite-nav,rec.aviation.piloting
Rudy P
No I did not participate, it was just a 3 hrs of search around the airport.
It is most likely a search plane. I tried a 910 396-0704 number and it does
not work from Montreal. There is just no way of giving the info.I am
surprised that there is no site to report findings outside the system.
the Steve Fossett website http://www.stevefossett.com/ and just report it
on their contact link.
John
  #45
Old September 15th 07, 12:37 AM posted to alt.comp.freeware,sci.geo.satellite-nav,rec.aviation.piloting
Larry Dighera
On Fri, 14 Sep 2007 17:50:48 -0400, "Rudy P"
wrote in
I tried a 910 396-0704 number and it does not work from Montreal.
Consider prepending a Country Code of 'one'
to the telephone number: 1 910 396-0704
  #46
Old September 15th 07, 02:12 AM posted to alt.comp.freeware,sci.geo.satellite-nav,rec.aviation.piloting
"Larry Dighera" wrote in message
wrote in
If you dial the 910 396 0704 number you get another dial tone - then you
dial 4719 - it's kinda confusing - it took me a couple tries before I
thought to keep dialing.
Geoff
  #47
Old September 15th 07, 04:00 AM posted to alt.comp.freeware,sci.geo.satellite-nav,rec.aviation.piloting
In sci.geo.satellite-nav Nomen Nescio wrote:
They seem to have a new set of pictures that extent further East.
http://s3.amazonaws.com/Fossett-DG/DG/index.kml
A different color. Much easier to view, for me.
It looks like the planes on the airstrip and some nearby ground equipment
are the same though. I wonder what the date is.
I think I'll revisit some of the hits I took.
Clarence A Dold - Hidden Valley Lake, CA, USA GPS: 38.8,-122.5
  #48
Old September 15th 07, 04:50 AM posted to alt.comp.freeware,sci.geo.satellite-nav,rec.aviation.piloting
Billiam Davis
One way to report a hit is to telephone the Steve Fossett
search-tips hotline at +1-910-396-0704. When you hear
the tone, press 4719.
Be prepared to leave your name, contact number, latitude, &
longitude, and a description of the area of interest.
  #49
Old September 15th 07, 05:04 AM posted to alt.comp.freeware,sci.geo.satellite-nav,rec.aviation.piloting
Billiam Davis
I don't see the plane in the new set.
Nomen,
Can you confirm the second set of kml files is ADDITIVE?
That is, should we load BOTH the kml files mentioned
in this thread - or should we only load this latest KML
file?
  #50
Old September 15th 07, 06:38 AM posted to alt.comp.freeware,sci.geo.satellite-nav,rec.aviation.piloting
John Tyson
"Billiam Davis" wrote in message
. net...
Nomen,
file?
I finally saw the new files tonight! Last night they were giving me HITs in
the eastern area, and all I could see was the original maps, so I knew I
wasn't doing anything meaningful. Then this morning they were giving me
HITs in the area covered by the first kml file, but I noticed the Google
Earth coordinates weren't centered on the HIT image; even sent them a
comment on that! Tonight I am finally seeing the new kml file data (thanks
to the above link; I tried several times before to load it from the
mechanical turk site link, but either that wasn't working or I didn't know
what I was doing - probably the latter ).
The files aren't additive, but they overlap; I think the best bet is to have
both loaded, but make sure the new one is being used if the HIT is located
within it (uncheck the box for the first file).
John
Help search for Steve Fossett Dan G Soaring 45 September 21st 07 08:13 PM
Steve Fossett search Don Pyeatt Aviation Photos 9 September 11th 07 06:16 PM
Fossett's reported fuel shortage Gary Evans Soaring 7 March 3rd 05 08:03 PM
FWD: Look at this internet patch for Microsoft Internet Explorer Charles S Home Built 15 October 2nd 03 08:08 PM
