CNN article on problems in Air Travel, as seen by FAA
Old September 15th 07, 12:53 PM posted to rec.aviation.piloting,rec.travel.air
Mxsmanic
Default CNN article on problems in Air Travel, as seen by FAA
John Kulp writes:
That stupid. The whole system being built is a GPS tracking system to
space and direct flight paths.
As I've already explained, GPS does not provide tracking. What is being built
is a system that uses GPS to determine position, but that is all. The rest is
independent of GPS.
  #103
Old September 15th 07, 12:55 PM posted to rec.aviation.piloting,rec.travel.air
Mxsmanic
Martin writes:
Why don't you read what he wrote? "A GPS tracking unit is a device that uses
the Global Positioning System ..."
I did, but he apparently did not, since he seems to think that the GPS itself
provides a tracking function, which is a common and rather serious
misconception. Nothing in GPS allows a user to be tracked.
  #104
Old September 15th 07, 12:58 PM posted to rec.aviation.piloting,rec.travel.air
Mxsmanic
John Kulp writes:
You're completely dense. You change the flight paths. They're in the
AIR not on the GROUND like the runways. Got that?
During take-off and especially approach, the flight paths are necessarily
aligned with the runways, since aircraft cannot instantly turn after leaving
the runway or instantly turn just before touching down. Thus, there are
flight paths that are inextricably linked to runway positions. The only way
to change them is to reposition the runways.
The pilots don't know how the planes work.
Apart from the most general principles, yes.
They just sit there like robots staring out the window while
some ghost flies them.
No, but during automated phases of a flight (which means most phases, today),
they don't have a lot to do. Still, that's better than requiring them to keep
their hands on the controls for eight hours at a stretch, in a number of ways.
They use GPS overseas all the time but they don't know how to use them.
They use GPS everywhere, but they don't have to know how it works to use it.
  #105
Old September 15th 07, 01:00 PM posted to rec.aviation.piloting
Mxsmanic
writes:
Such as?
Such as the need for local transmitters at every airport. LAAS requires this,
and since WAAS cannot match ILS precision, LAAS is required if ILS is to be
fully replaced.
  #107
Old September 15th 07, 02:39 PM posted to rec.aviation.piloting
Mxsmanic
john writes:
Perhaps you should use some of your vaunted research skills to see what
the accuracy of WAAS is. It's better then a ILS and the WAaS approachs
have the same minimums as the ILS approachs.
I have indeed done the research. The whole reason for LAAS is that WAAS isn't
good enough to replace ILS entirely. WAAS can match some Category I
performance. LAAS will be needed to get to Category III, and since you need
Cat IIIc to replace ILS, WAAS certainly isn't going to do it, and LAAS
probably won't do it for a while yet.
If you think that WAAS is better than ILS, you need to tell the government
about it right away, so they can save billions of dollars of development costs
on LAAS.
  #108
Old September 15th 07, 05:15 PM posted to rec.aviation.piloting,rec.travel.air
In rec.aviation.piloting Mxsmanic wrote:
Morgans writes:
As I understand it, this is one type of issue that could be greatly improved
when true "free fly" routing is in place. Take off in any direction that
will meet the needs, and not worry about the airways.
It depends on how much of the congestion is en-route, and how much is in
approach and departure. Free flight would help in the former case, but it
wouldn't make much different in the latter case.
Additionally, although truly random free flight would eliminate en-route
congestion, it would also raise costs, since most random, free-flight routes
are going to be longer than the optimal route. There would be a tendency for
everyone to try to fly the shortest route, and then the congestion would
return.
Babbling nonsense.
Jim Pennino
Remove .spam.sux to reply.
Travel aid [email protected] Soaring 0 February 7th 06 12:25 PM
Travel aid [email protected] Restoration 0 February 7th 06 12:25 PM
Travel aid [email protected] General Aviation 0 February 7th 06 12:25 PM
Travel aid [email protected] Aviation Marketplace 0 February 7th 06 12:25 PM
Travel Supplements Jetnw Aviation Marketplace 0 September 15th 04 07:50 AM
