"Frederick Wilson" wrote:
I saw a thing on Travel Channel tonight that was showing off the EZRocket. This raised a couple of questions. It looked like he has that thing going straight up. How can this be, with that canard wing. Other than just brute force I thought for sure it would stall? Second, what is the landing speed of one of them things? It seemed like he was hauling @$$ when he landed. Thanks, Fred The best angle of climb is about 42 degrees at 80 kt, where the rate of climb is about 5,500 fpm. The best rate of climb is about 10,000 fpm at the airplane's Vne (never exceed speed) of 195 kt, where the angle of climb is about 30 degrees. The two rocket engines produce 400 pounds of thrust each. Touchdown speed is 55 to 60 kt just like any other long EZ. You'll find some close-up pictures and info in my Oshkosh Scrapbook from last year, www.AirplaneZone.com/Oshkosh/Scrapbook2002 Select "Index" and scroll down to "Xcor EZ Rocket". David O |
"Rick Pellicciotti" wrote:
Lot's of good information about it he http://www.xcor.com/ez.html Paraphrasing from the web site, "The airplane performs about the same as a O-320 powered Long-EZ". My O-320 powered Long EZ doesn't climb at 10,000 fpm at Vne. ![]() Actually, Rick, the web site says, "Single engine performance is similar to a Lycoming O-320 with constant speed prop." So in that statement they are talking about performance with only one of the two rockets firing. Even so, the statement is not entirely accurate. David O -- http://www.AirplaneZone.com |
This raised a couple of questions. It looked like he has that thing going straight up. How can this be, with that canard wing. Other than just brute force I thought for sure it would stall? Second, what is the landing speed of one of them things? It seemed like he was hauling @$$ when he landed. Thanks, Fred |
"Frederick Wilson" wrote in message et... I saw a thing on Travel Channel tonight that was showing off the EZRocket. This raised a couple of questions. It looked like he has that thing going straight up. How can this be, with that canard wing. Other than just brute force I thought for sure it would stall? Second, what is the landing speed of one of them things? It seemed like he was hauling @$$ when he landed. Thanks, Fred Lot's of good information about it he http://www.xcor.com/ez.html Paraphrasing from the web site, "The airplane performs about the same as a O-320 powered Long-EZ". |
My O-320 powered Long EZ doesn't climb at 10,000 fpm at Vne. ![]() Actually, Rick, the web site says, "Single engine performance is similar to a Lycoming O-320 with constant speed prop." So in that statement they are talking about performance with only one of the two rockets firing. Even so, the statement is not entirely accurate. David O -- http://www.AirplaneZone.com As Dave Barry would say, "an alert reader....".... You are correct in your observation. The more complex and more correct statement is that the single engine ground roll and takeoff are similar to an O-320 with constant speed prop at a low MSL airport. After takeoff, the piston engine/prop thrust drops with indicated speed whereas the rocket engines have constant thrust. Also, the piston engine power drops with altitude. And the reason for the short airshow routine was because the events coordinator asked us to keep it short. Otherwise, Dick would have done a second go-around (which he practiced at Mojave the week before). We landed with about half of the propellants remaining, which was why we did the LOX vent after landing and before rolling into the crowd. Too bad; that second go-around is more impressive at lighter weight. Glide and landing are similar to a standard Long, except that the rocket has less drag (the added fuel tank has less drag than the prop and cooling drag did), and the belly board is less effective ahead of the fuel tank. Dan DeLong XCOR Aerospace |
David O wrote in message . ..
(Dan DeLong) wrote: Even so, the statement is not entirely accurate. David O -- http://www.AirplaneZone.com As for the LOX vent at Oshkosh 2002, that was something to see. I think it was you I questioned afterward and you said it really was not dangerous without some sort of fuel to burn. You (or whomever) said you had once purposely put a lit cigarette into the O2 cloud -- the cigarette burned quite rapidly and that was the extent of the effect. Putting a lighted cigarette into a LOX tank vent plume would have been a serious safety violation and we would not have done that. We *have* done some flammability tests by holding small samples in a GOX plume with tongs, gloves, and a fire extinguisher standing by. None of the tests included a cigarette, but I expect the results would have been as you described. You may be recalling something that a crusty old engineer demonstrated for me back in 1974 in the Life Support Lab at Westinghouse. He started the lesson with "Don't you try this..." and proceeded to light a cigarette. He then drew a lungful of oxygen from a mask on an emergency medical bottle by the swimming pool, put the cigarette in his mouth and slowly exhaled through it. The end of the cigarette got really bright and it burned its full length in the one exhalation. I would guess the gas he exhaled was about 60% oxygen because of mixing with the residual gas in his lungs. Saw your photos. Nice. I miss living in the homebuilt world, but my job just takes too much time, and working on my Defiant is too much like my day job now; it's not relaxing. And my tools are on loan to XCOR. Dan DeLong David O -- http://www.AirplaneZone.com |
| Thread Tools | |
| Display Modes | |
| Tailwheel question | Steve B | Aerobatics | 4 | January 30th 04 04:35 AM |
| Air compressor question | Frederick Wilson | Home Built | 40 | October 6th 03 03:50 AM |
| Question on Pulsejets/Ramjets??? | DarylG1532 | Home Built | 3 | August 16th 03 04:20 AM |
| AVID FLYER question | OB1 Kanobe | Home Built | 0 | August 14th 03 03:46 PM |
| question on intercoms for my new homebuilt | w b evans | Home Built | 1 | July 23rd 03 01:57 AM |
