I'm considering Horton Stack doors (the type that fan-fold to the
side) for a hangar. One question is the expected lifespan of the fiberglass panels. If anyone has direct knowledge of this brand in actual use over an extended time, I'd appreciate your feedback. Thanks. - Frank |
Frank,
I previously had the Horton stack doors on a 60 X 60 at Napa, CA. The were a pain in the hind end in windy conditions, especially when the wind was parallel to the door opening. If you let the doors get away from you it could get ugly. I also have them on a second hangar at Minden. Here they are shielded from the wind more, and so the auto slam closed or open feature isn't such a problem. However, they do not seal well and the hangar is constantly inundated with dirt and dust. If the doors have a south exposure, in the summer the temperature swings inside are brutal. The doors, if left uninsulated, pass light nicely but also radiate heat to make the hangar an oven. My large hangar is an Erect-A-Tube, so the insulated bi-fold door is from them. Much better. However, some of the hangar door specialty companies build a nicer door than Erect-A-Tube does. In any case, I much prefer the bi-fold over the stack-door. The biggest advantage of the stack door is cost. Perhaps that's the only advantage (g). bumper Minden "V1" wrote in message ps.com... I'm considering Horton Stack doors (the type that fan-fold to the side) for a hangar. One question is the expected lifespan of the fiberglass panels. If anyone has direct knowledge of this brand in actual use over an extended time, I'd appreciate your feedback. Thanks. - Frank |
Nope, haven't moved to TX . . . I'm enjoying NV so much I can safely say
it's likely I'll stay in Minden. The stack doors I was referring to were in Napa, CA, when I lived there. Hangar was 60 X 60 so when the wind was parallel to the doors, the wind effect on the doors was considerable. The airport posted warning decals to not operate the doors in high wind conditions. The smaller hangar I have at Minden has a 50' opening that's wind shielded by other structures, so operating the doors is never an issue. If blowing dust and dirt is of concern, that might be a consideration as my stack doors don't seal out the dirt well at all. bumper "Jeremy Zawodny" wrote in message ... wrote: The other advantage for me as an old geezer is to be able to open the doors easily by myself at any time. With Ohio winds I have had to work a little harder to open them sometimes but totally possible. Closing them is much easier. Bumper has a worse problem with wind in West Texas, that's for sure. Bumper is in Minden, NV not Texas (unless he's recently moved). Jeremy |
| Hangars - Horton Stack Doors? | V1 | Piloting | 4 | September 16th 07 12:08 AM |
| What's a radio stack really cost? | Jim Carter | Owning | 10 | June 21st 06 03:00 AM |
| Refinishing radio stack front panels | Roger Halstead | Home Built | 2 | September 15th 04 05:20 PM |
| Horton STOL 172 "V" speeds | R. Wubben | Owning | 6 | December 30th 03 03:04 AM |
| Horton STOL 172 "V" speeds | R. Wubben | Piloting | 4 | December 30th 03 03:04 AM |
