Departure Procedure jStumper Question
Old September 18th 07, 07:14 PM posted to rec.aviation.ifr
Default Departure Procedure jStumper Question
Take a look at Salmon Idaho KSMN, Ahehu 1 RNAV Dept (Obstacle). I
realize few aircraft are equipped to fly this, however;
1. Notice the "at 200 kt" requirement for some waypoints. Is this
TAS, GS, or IAS? And a reference please if you know of one.
2. Why is the stipulation "at" instead of "at or below"?
Stan
Old September 18th 07, 07:23 PM posted to rec.aviation.ifr
Newps
Looking at the chart on the AOPA website nowhere is there a speed
listed. If a speed were listed it would be IAS.
Stan
Old September 18th 07, 08:18 PM posted to rec.aviation.ifr
B[_2_]
You have to check the NOTAMs, too:
08/014 - AHEHU ONE DEPARTURE (RNAV) (OBSTACLE) NOTE: DO NOT EXCEED
200 KIAS UNTIL FIPFE AND FANID WIE UNTIL UFN
Old September 18th 07, 08:19 PM posted to rec.aviation.ifr
B[_2_]
Jeppesen didn't do quite a bad job of charting it as NACO.
It's at or below 200 knots and the authority is the departure criteria
the FAA uses.
Stan
Old September 20th 07, 12:27 PM posted to rec.aviation.ifr
the FAA uses.
Stan
Thanks b. For lurkers, the Jepp chart does indeed say "at 200 kt".
The reference that I was looking for is the FAR or AIM that tells the
pilots whether the charted speed is supposed to be TAS, GS, or IAS. I
realize the notam clarifies that it is IAS, but without it, how does a
pilot know? Stan
Old September 20th 07, 01:52 PM posted to rec.aviation.ifr
B[_2_]
The AIM tells you that ATC assigns speeds in terms of IAS.
It also tells you that the speed for procedure turns is in terms of IAS.
Although Part 97 and the AIM are silent on whether Approach Categories
are IAS, TAS, or ground speed, how could they possibly be anything other
than IAS?
What about the speed limits on STAR charts?
pilot know? Stan
Old September 20th 07, 03:26 PM posted to rec.aviation.ifr
Mark Hansen
than IAS?
I'm not sure sure Part 97 is silent on the issue. It says that the categories
are based on the "speed of VREF, if specified, or if VREF is not specified,
1.3 Vso at the maximum certificated landing weight".
VREF and Vso are IAS references, aren't they?
Mark Hansen, PP-ASEL, Instrument Airplane, USUA Ultralight Pilot
Cal Aggie Flying Farmers
Sacramento, CA
Old September 20th 07, 04:24 PM posted to rec.aviation.ifr
B[_2_]
than IAS?
So it would seem. ;-)
Old September 21st 07, 07:28 PM posted to rec.aviation.ifr
All good points, and from others too. However I wasn't asking about
atc speeds. and the speed for procedure turns is not on the chart,
although I'm not arguing about that aim specified limit.
My query was about speeds listed on jeppessen charts. And I see
approach categories are referenced to IAS as a poster has noted. But
on the same chart where approach category minimums are stated, there
is also often a descent from faf chart that is noted as in GS. Now
sure, it's easy for "experts" say of course it's GS, (as noted on the
chart) since distance and time cannot equal IAS, so that's obvious.
But look at the case of the departure in the initial thread. The same
argument "that's obvious" can be made for GS, since the obstacle
clearance is based on a specified turn radius plus safety factor, and
clearly GS determines radius assuming a constant bank angle and not
IAS. Remember there is no annotation on the dept (jepp chart) on
whether it's ias tas or GS. And for the sake of this argument let's
not consider the notam (which specifies ias) in this hypothetical
case.
Are there other speeds on charts where it is not specified whether it
is IAS TAS or GS?
Old September 21st 07, 07:38 PM posted to rec.aviation.ifr
Mark Hansen
case.
Well, I didn't see the Jepp chart in question, so I may be off here,
but from the discussion, I was under the impression that the annotation
on the chart was a speed restriction, which is different than a climb
gradient minimum.
When the ODPs need you to climb at a certain gradient, they don't give
you a speed at all - they give you the climb gradient. The pilot is
supposed to convert that into a climb rate based on actual GS.
So ... if the chart is telling you that you must be doing at or at/below
a speed at a certain point, I would interpret that as IAS.
is IAS TAS or GS?
Sacramento, CA
departure or arrival? George Aviation Photos 6 April 15th 07 07:58 PM
Fedex Departure (MCO) Glen in Orlando Aviation Photos 0 November 29th 06 11:13 PM
How to adhere to this obstacle departure procedure? Peter R. Instrument Flight Rules 38 April 25th 05 09:00 PM
KCNH departure procedure. Roy Smith Instrument Flight Rules 5 August 24th 04 10:52 PM
Interesting Departure Procedu MRB Trixy Two Richard Kaplan Instrument Flight Rules 26 February 18th 04 11:42 PM
