On Sep 23, 5:06 pm, Matt Whiting wrote:
It would depend on what aircraft type you fly. With Cessna's and Piper's, there is no need for rudder authority below 30 knots or even higher. I've never flown an airplane with a free castering nose wheel, but I suspect rudder authority is more important there, however, it still seems like the brakes would work fine for directional control at 10 knots. Matt I've done downwind takeoffs and have scared myself a few times. Even five or ten knots leaves you with less control, and I might wish I had that control. Taking off in a gusting tailwind might drop you in the weeds off the end of the runway, too. Dan |
Depends heavily on the aircraft. I know for a fact that a lightly
loaded DC-10 will not be able to land and stop at McCarran with a 10+knot tailwind. Been onboard when it was tried and remember going off the airport boundries at less than 30 AGL You get a new perspective on things when you see TV antennas go by above you and chimmneys just below you! Lockheed L-10A is virtually impossible to land safely with any tailwind. It has so much tail surface that it either slams the tail down or tries to put it on the nose. deHaviland Super Chipmunk with a Krier tail gets super squirrelly with any kind of tailwind. Of course the tail will come off the ground at about 15 knots forward speed |
![]() The tricky part of downwind landings is the necessity to extend your traffic pattern's Downwind Leg (actually against the wind in the case of a downwind landing) WELL BEYOND (perhaps double or more) what you are accustomed to in a normal into-the-wind landing. If you fail to do this, you will overshoot. You are getting close to one of the answers. Yes with a downwind landing you much more likely to overshoot. Since you may overshoot you are much more likely need to Go Around. On the Go around two more things happen. One, your climb out will climb out at a much lower angle which may make it difficult or impossible to clear obstacles. 2nd you will be close to the ground with a higher than normal ground speed. The illusion of speed when combined with approaching obstacles will make you want to climb a slower than normal airspeed setting you up for a perfect Stall/Spin scenerio. In fact I know of several Stall spins that have occurred exactly this way. One of my favorite demostrations is to simulate a power failure on a windy day (and no one else in the pattern) when the only runway option is the downwind runway. Once the student shown me they have they have the runway made or they overshoot, (as they often do) I request a go around so they can see how poor the climb angle really is when departing downwind. With a 15 to 20kt tailwind in a C-150 or Tomahawk this climbout can be impressively low. Brian CFIIG/ASEL |
On Sun, 23 Sep 2007 19:37:38 -0700, Brian wrote
in . com: The tricky part of downwind landings is the necessity to extend your traffic pattern's Downwind Leg (actually against the wind in the case of a downwind landing) WELL BEYOND (perhaps double or more) what you are accustomed to in a normal into-the-wind landing. If you fail to do this, you will overshoot. You are getting close to one of the answers. The answer to which question? Yes with a downwind landing you [are] much more likely to overshoot. Right. But I can't emphasize too much the necessity to extend the "Downwind Leg" to WELL beyond the point where the runway threshold is at a 45 degree angle to the aircraft's position on the Downwind Leg (as would be normal for an into-the-wind landing approach), so that there is enough time to descend on final approach without the wind blowing the aircraft past the threshold while it is still too high to touch down. What do you teach as a rule-of-thumb to determine the point to turn from Downwind Leg to Base Leg? Since you may overshoot you are much more likely need to Go Around. On the Go around two more things happen. One, your climb out will climb out at a much lower angle which may make it difficult or impossible to clear obstacles. Right. While the approach descent-rate can be increased by employing a forward slip to increase the angle, unfortunately, there is no reciprocal method available to increase the climb angle. 2nd you will be close to the ground with a higher than normal ground speed. The illusion of speed when combined with approaching obstacles will make you want to climb a[t] slower than normal airspeed[,] setting you up for a perfect Stall/Spin scenerio. Good point. Fortunately, I haven't experienced a downwind go-around into rising terrain, but wouldn't the orographic lifting of the wind against the terrain produce some updraft (or vertical component) to assist in increasing the rate of climb? Or is that just wishful thinking? In fact I know of several Stall spins that have occurred exactly this way. The illusion is so strong, it's easy to understand how that might happen if the pilot fails to monitor the airspeed indicator to maintain Vx speed on climb-out. One of my favorite demostrations is to simulate a power failure on a windy day (and no one else in the pattern) when the only runway option is the downwind runway. Once the student [has] shown me they have they have[sic] the runway made or they overshoot, (as they often do) I request a go around so they can see how poor the climb angle really is when departing downwind. With a 15 to 20kt tailwind in a C-150 or Tomahawk this climbout can be impressively low. Brian CFIIG/ASEL I can see how that would be important. |
And I've flown a real Chipmunk...
Hope the ASPCA doesn't hear about this... http://www.aspca.org ;-) -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Jay Honeck wrote in news:1190639592.333060.145150
@d55g2000hsg.googlegroups.com: And I've flown a real Chipmunk... Hope the ASPCA doesn't hear about this... http://www.aspca.org Groan! I think we just heard from one of Anthony's simmer buddies... Bertie |
"Kyle Boatright" wrote in message
There is always the consideration of an engine failure. On takeoff or landing, I'd prefer to be pointed into the wind if the prop stops, rather than having to land downwind or attempt a low altitude turn into the wind... I'd rather be pointed into the wind, too, but if the failure happens away from the field, I think I'd be a lot less concerned with landing into the wind than I would in actually making the field. -- John T http://sage1solutions.com/blogs/TknoFlyer http://sage1solutions.com/products NEW! FlyteBalance v2.0 (W&B); FlyteLog v2.0 (Logbook) ____________________ |
("Bertie the Bunyip" wrote)
And I've flown a real Chipmunk... Hope the ASPCA doesn't hear about this... http://www.aspca.org I think we just heard from one of Anthony's simmer buddies... You decide. http://www.alexisparkinn.com/flight_simulator.htm The "Kiwi" @ The Alexis Park Inn & Suites BTW - BTDT Montblack :-) |
"John T" wrote in
m: "Kyle Boatright" wrote in message There is always the consideration of an engine failure. On takeoff or landing, I'd prefer to be pointed into the wind if the prop stops, rather than having to land downwind or attempt a low altitude turn into the wind... I'd rather be pointed into the wind, too, but if the failure happens away from the field, I think I'd be a lot less concerned with landing into the wind than I would in actually making the field. True, but downwind off field landings can be nasty. If it all goes horribly wrong on you you'll be travelling a lot faster with a lot less control than you would have with an into wind landing in an inferior field. Also, your glide path control will be much more difficult with a tailwind for two reasons. One, the angle will be much more shallow giving you progress judgement difficulties and of course your glide angle will deteriorate as the wind gradient gives you less tailwind as you descend. But as well as this you won't be used to making a glide approach this way and your chancs for success will be reduced because of this. Having said all that, if you've only got one place to land and downwind is the only way you can do it, well.. Bertie |
Why not to land downwind | [email protected] | Piloting | 23 | September 6th 06 03:01 PM |
Arizona Downwind Dash | Mike the Strike | Soaring | 4 | April 26th 05 03:53 AM |
Prop to High RPM on downwind | Mitty | Piloting | 70 | November 29th 04 05:13 PM |
Night landings vs. day landings | Gerald Sylvester | Piloting | 15 | February 12th 04 06:38 AM |
Question: "Overhead Entry to Downwind?" | Harry Shin | Piloting | 122 | January 20th 04 02:39 PM |
