#31
Owain Walters wrote:
Because while the electric is flailing around the mechnical gives indications that match what is happening with a timed average. If your electric is "flailing around", that suggests a problem in the pneumatic connections or the vario settings. For example, I set my Cambridge 302 for a relatively fast audio response (~ 1.3 second response), but a slower needle response (1.7 second response - similar to a good mechanical vario). The averager (~ 20-30 second response) gives a climb rate in excellent agreement to the actual climb rate, though this can be checked easily only in very smooth thermals. These three different responses give me a feel for detecting, centering, and ultimately deciding when to leave a thermal. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * "Transponders in Sailplanes" http://tinyurl.com/y739x4 * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
#32
I agree with Kirk as far as the 'useful' info is concerened.
I have a Sage mechanical (thanks kirk) as the mechanical backup to my SN10. I find that the Mechanical gives me a good indication of whats happening outside with air as it is compensated and gust filtered very well, and the SN10 gives me a very fast response and allows me to center quicker and stay there. In other words when I hear an audio response to lift while cruising I slow down and glance at the sage and determine whether or not it is worth making a turn or moving on. The Sage gives me a better avgerage of what I just flew into than the SN10. The SN10 gives me a instant responce that is to short of a time frame to tell if it is a gust or continued lift. I would like to have a 9volt audio back up connected to the sage in case of power failure, but not enough room in the panel ![]() there? At 14:54 25 September 2007, Kirk.Stant wrote: Which leads to an interesting point - it isn't so much the actual reading on the vario that is important, as the ease of using the datapresented to climb more efficiently. So the hole 'accuracy' argument is a bit ridiculous. If it is really sensitive, it overreacts to gusts. If it is highly damped, it's an averager. That's why I want the audio, to let my brain (and butt) figure out the gusts from the surges and center accordingly. Tough while staring at a needle on a mechanical that hasn't been looked at much before, after the needle on the ubervario MK 69 falls off... |
#33
Once upon a time, there was such a thing----an electric audio attachment for
a pneumatic/mechanical vario. Or perhaps it was just plumbed in the pneumatic lines. Adjustable for volume and threshold. It was a little black box that didn't need to be in the panel at all. Perhaps you can find a used one somewhere. -- Hartley Falbaum "Cliff Hilty" wrote in message ... I agree with Kirk as far as the 'useful' info is concerened. I have a Sage mechanical (thanks kirk) as the mechanical backup to my SN10. I find that the Mechanical gives me a good indication of whats happening outside with air as it is compensated and gust filtered very well, and the SN10 gives me a very fast response and allows me to center quicker and stay there. In other words when I hear an audio response to lift while cruising I slow down and glance at the sage and determine whether or not it is worth making a turn or moving on. The Sage gives me a better avgerage of what I just flew into than the SN10. The SN10 gives me a instant responce that is to short of a time frame to tell if it is a gust or continued lift. I would like to have a 9volt audio back up connected to the sage in case of power failure, but not enough room in the panel ![]() there? At 14:54 25 September 2007, Kirk.Stant wrote: Which leads to an interesting point - it isn't so much the actual reading on the vario that is important, as the ease of using the datapresented to climb more efficiently. So the hole 'accuracy' argument is a bit ridiculous. If it is really sensitive, it overreacts to gusts. If it is highly damped, it's an averager. That's why I want the audio, to let my brain (and butt) figure out the gusts from the surges and center accordingly. Tough while staring at a needle on a mechanical that hasn't been looked at much before, after the needle on the ubervario MK 69 falls off... |
#34
![]() The Crossfell did work OK but the scaling was off, like it never ever showed more than 1 m/s The Crossfell in my RS-15 (glider now sold) gave 32 years of reliable service. The Crossfell was retired in perfect working condition. There was a rotary switch that changed the scale to 3x or 5x, I forget exactly which. Yours may have been set or stuck in expanded scale. Btw, mine read in feet per second. My mechanical backup was in meters per second. Meanwhile, over the radio everyone was talking about how many knots of lift they were in. ;-) and it would show down when I was going up. Yeah, that's an indication that something was amiss. -- Regards, Doug -- Posted via a free Usenet account from http://www.teranews.com |
#35
![]() One thing that bugs me about my mechanical (a winter) is that it always over states the lift, which is important when deciding to take a thermal or not. The damn thing generally tells me 6 knots, when it is only 3-4 steady on the averager ! I need the re-paint the face plate :-) Perhaps you have too large of a capacity bottle on it. Putting a smaller capacity on it will lower the readings on you Winter. Brian CFIIG/ASEL |
#36
On Sep 25, 1:12 pm, "HL Falbaum" wrote:
Once upon a time, there was such a thing----an electric audio attachment for a pneumatic/mechanical vario. Or perhaps it was just plumbed in the pneumatic lines. Adjustable for volume and threshold. It was a little black box that didn't need to be in the panel at all. Perhaps you can find a used one somewhere. thats what i would really like. |
#37
On Sep 25, 4:51 pm, wrote:
thats what i would really like. I think what you're looking for is a Piep audio. There were a lot of them about in the 1960s and 1970s. Very simple and reliable. Two knobs (volume and threshold), two hose connectors (static and capacity), and a plug for +12DCV and ground. They have fairly low restriction, so you can plub it in series with a mechanical vario without problem. They seem to like a one-pint flask, but they're not particularly picky. I had one for ten years and really liked it. I bet if you ask around among the old-timers in your area you'll find somebody with one in the bottom of a box of junk. It'll probably still have the Graham Thompson sticker on it. Thanks, Bob K. |
#38
![]() wrote in message ps.com... On Sep 25, 1:12 pm, "HL Falbaum" wrote: Once upon a time, there was such a thing----an electric audio attachment for a pneumatic/mechanical vario. Or perhaps it was just plumbed in the pneumatic lines. Adjustable for volume and threshold. It was a little black box that didn't need to be in the panel at all. Perhaps you can find a used one somewhere. thats what i would really like. Surely some one out there has an old Piep 2 Audio Vario that they are willing to part with. (Or, maybe the newer Winter model.) I gave away my last one a couple years ago. Wayne http://www.soaridaho.com/ |
#39
On Sep 25, 8:16 pm, Bob Kuykendall wrote:
On Sep 25, 4:51 pm, wrote: thats what i would really like. I think what you're looking for is a Piep audio. There were a lot of them about in the 1960s and 1970s. Very simple and reliable. Two knobs (volume and threshold), two hose connectors (static and capacity), and a plug for +12DCV and ground. They have fairly low restriction, so you can plub it in series with a mechanical vario without problem. They seem to like a one-pint flask, but they're not particularly picky. I had one for ten years and really liked it. I bet if you ask around among the old-timers in your area you'll find somebody with one in the bottom of a box of junk. It'll probably still have the Graham Thompson sticker on it. Thanks, Bob K. Yes, the Piep was a nice gadget. I also flew with one for many years-- it was my first audio vario--and liked it. When electric varios became ubiquitous in the U.S. (mostly Cambridge in those days), we sold it. If you can find a working one, it's a cheap, simple way to add audio to most mechanical varios. IIRC, the current drain was very low, too. This was back in the days when we all had Bayside BEI-990 radios and a set of batteries (Everready 560?) needed charging only a few times a season. That sounds crazy as I type this. Does anyone else remember if this was true? ![]() Chip Bearden ASW 24 "JB" USA |
#40
Piep audio was made and sold through Winter in Germany but that was some
time ago.....I actually bought the very last ones they had probably 5-6 years ago...maybe longer....and had some repaired by them about the same time ...but they said then no more parts existed for these..Another Winter first instrument that faded from view but was really very interesting at the time was the Stollfarhtgaber, actually the first Speed-to-fly variometer/airspeed indicator all-in one....all done mechanically and pneumatically with no need for volts of any kind...these too and parts for them are no longer available Funny as we seem to advance towards more sophisticated do-everything electronic gadgets how we look back on what worked then and would still work today with a lot less time setting up, reading manuals and sorting things out on RAS..... I never remember having to have all these conversations and technical workshops on how to wind or smoke a barograph and never once had the software or PC link or lack of a serial port miss a turnpoint done on a Kodak..... ![]() All in the way of technology...and to many a giant leap sideways ![]() So while many might claim an electronic vario is a must for a back-up I still personally prefer a mechanical running on a probe...it to me also shows to me what I feel in the flight more naturally than any electronic one. tim Please visit the Wings & Wheels website at www.wingsandwheels.com "Bob Kuykendall" wrote in message ups.com... On Sep 25, 4:51 pm, wrote: thats what i would really like. I think what you're looking for is a Piep audio. There were a lot of them about in the 1960s and 1970s. Very simple and reliable. Two knobs (volume and threshold), two hose connectors (static and capacity), and a plug for +12DCV and ground. They have fairly low restriction, so you can plub it in series with a mechanical vario without problem. They seem to like a one-pint flask, but they're not particularly picky. I had one for ten years and really liked it. I bet if you ask around among the old-timers in your area you'll find somebody with one in the bottom of a box of junk. It'll probably still have the Graham Thompson sticker on it. Thanks, Bob K. |
WTB: CAI L-NAV readout meter and Sage or PZL mechanical vario. | [email protected] | Soaring | 2 | August 28th 07 03:18 AM |
Placement of Mechanical Vario in Panel? | V1 | Soaring | 3 | July 29th 07 08:55 PM |
Mechanical Vario or not? | Fish | Soaring | 15 | July 2nd 06 02:28 PM |
Winter mechanical vario reading high | Alan Meyer | Soaring | 13 | April 13th 06 02:38 AM |
Wanted: Used Mechanical Vario | Tim Hanke | Soaring | 0 | May 16th 05 05:35 PM |
