Going for my Multiengine rating
Old September 23rd 07, 11:45 PM posted to rec.aviation.ifr,rec.aviation.owning,rec.aviation.piloting,rec.aviation.student
Jim Macklin
Default Going for my Multiengine rating
There are some airplanes that are easy to load outside the
flight envelope. Many multiengine airplanes are designed to
carry passengers and baggage. With only the front seats
occupied, some ballast in the rear can be essential.
You should read some FAR 23 on flight control forces
allowed.
I have a few thousand hours teaching in multiengine aircraft
and just flying charter and delivery, from Piper Aztecs,
Beech Duchess and Barons, Dukes, King Ai r 90, 200 and 300.
Jet time is in the Beechjet 400, trust me, your life can
depend on your being able to push and pull the controls to
the limit with one leg or one hand.
"Michelle P"
wrote in message ...
| Jim Macklin wrote:
| Be careful with using the electric trim to flare.
Assuming
| that the airplane is properly loaded with the CG within
| range, the elevator forces required between an approach
| speed of 1.3 Vso and the flare should be slight. Do a
W&B
| for your landing configuration, be sure to check for an
| items stowed in a forward baggage area and for fuel.
| The problem that WILL happen is at some point you will
gave
| to go-around, that means you will need a hand on the
power
| and you will REALLY need two hands on the elevator
because
| the electric trim isn't fast enough, you will have a
sudden
| need to hold the nose down, will loose A/S, perhaps even
| stall, then the real bad thing can happen, en engine
| failure, Vmc and spin at 100 AGL.
| Do some exercise with weights, it is safer.
| there are some planes that are just nose heavy.
Old September 25th 07, 02:03 AM posted to rec.aviation.ifr,rec.aviation.owning,rec.aviation.piloting,rec.aviation.student
Michelle P
allowed.
I bow to your godliness..almighty one.
Michelle
Old September 25th 07, 06:52 AM posted to rec.aviation.ifr,rec.aviation.owning,rec.aviation.piloting,rec.aviation.student
Jim Macklin
Live long and prosper. There are a number of NTSB reports
that involve female pilots involved in fatal accidents in
various makes and models. Often these involve Vmc
demonstrations and other operations such as engine out
go-around [not required in light twins, but a required
maneuver in transport category/jets.]
"Michelle P"
designed to
| allowed.
aircraft
300.
to
| Michelle
Old September 25th 07, 03:26 PM posted to rec.aviation.ifr,rec.aviation.owning,rec.aviation.piloting,rec.aviation.student
john hawkins
I'm not sure what gender has to do with it. I know that my daugher, who is a
competion horse rider can toss hay bales around a whole lot better than I
can. and i can flare and land a nose heavy A36 just fine.
"Jim Macklin" wrote in message
"Michelle P"
designed to
| allowed.
aircraft
300.
to
| Michelle
Old September 25th 07, 06:47 PM posted to rec.aviation.ifr,rec.aviation.owning,rec.aviation.piloting,rec.aviation.student
Jim Macklin
Gender has nothing that must cause the problem, but a 102
pound female has to work harder to push the 150 pounds on
the rudder pedal that is what is required to match the Vmc
numbers, or to pull or push the elevator when the trim is
run-away or just miss-set. And the typical two place
trainer has a narrow CH envelope and most multiengine
airplanes have a wide CG range, when only the front seats
are occupied, elevator forces will be greater.
Lots of farms girls and city raised girls who get into
horses, learn very quickly that a 70# hay bale can be moved,
with effort. Then they learn that the exercise makes them
stronger and the bales seem easier to move.
I was just telling the young lady, that using the trim for
the flare, below 1.3 Vso may get her killed and it won't
increase her upper body strength.
There are males with low strength and there are females with
high strength. But the aerodynamic facts are gender
neutral, if you trim right down to stall speed and have to
do a go-around, you are asking to die if you don't have the
strength.
There is a maneuver that can be done safely at altitude in
most airplanes, a trim stall.
"john hawkins" wrote in message
et...
daugher, who is a
lot better than I
| "Jim Macklin" wrote
in message
reports
in
| "Michelle P"
| wrote in message
outside
| the
| designed to
seats
| | allowed.
| aircraft
Aztecs,
and
| 300.
can
controls
| to
| | Michelle
Old September 25th 07, 06:48 PM posted to rec.aviation.ifr,rec.aviation.owning,rec.aviation.piloting,rec.aviation.student
The Visitor[_2_]
My Seneca is. So I don't use full flaps unless there is some aft weight.
Without anything in the back, the cg is almost at the front limit. Just
"two notches". To flare nice with full flaps invites a tail stall. Very
common and I was taught, that is why there is the abundance of nose gear
collapses in the type. Because the pounding the nose gear is given.
Rolling in nose up trim makes things easier. It is just done when over
the numbers, entering a flare.
John
Michelle P wrote:
Jim Macklin wrote:
Be careful with using the electric trim to flare. Assuming
that the airplane is properly loaded with the CG within the
speed of 1.3 Vso and the flare should be slight. Do a W&B
The problem that WILL happen is at some point you will gave
to go-around, that means you will need a hand on the power
and you will REALLY need two hands on the elevator because
the electric trim isn't fast enough, you will have a sudden
Old September 27th 07, 02:38 AM posted to rec.aviation.ifr,rec.aviation.owning,rec.aviation.piloting,rec.aviation.student
Margy Natalie
IMHO it's not only the weight but the height, there's a big difference
between pulling the yoke back when you are 20 inches away and 10 inches
away. I know.
Margy
strength.
et...
daugher, who is a
lot better than I
| "Jim Macklin" wrote
in message
reports
in
| "Michelle P"
| wrote in message
outside
| the
| designed to
seats
| | allowed.
| aircraft
Aztecs,
and
| 300.
can
controls
| to
| | Michelle
Old September 27th 07, 04:37 AM posted to rec.aviation.ifr,rec.aviation.owning,rec.aviation.piloting,rec.aviation.student
Morgans[_2_]
away. I know.
I think I am following your thought, but I'm not sure.
Are you saying your height (or lack of it ;-) puts you so close to the yoke
(10 inches) that the closeness makes it much more difficult to pull hard on
the yoke?
I'm assuming that the pedals on the Navion are not adjustable, and that is
what puts you so close to the yoke?
Jim in NC
Old September 27th 07, 05:57 AM posted to rec.aviation.ifr,rec.aviation.owning,rec.aviation.piloting,rec.aviation.student
Jim Macklin
Very true, full travel is required. That can be difficult
with short legs and arms.
"Margy Natalie" wrote in message
m...
big difference
and 10 inches
| away. I know.
| Margy
102
on
Vmc
is
seats
moved,
them
for
with
to
| strength.
in
message
| et...
that my
| daugher, who is a
whole
| lot better than I
fine.
| | "Jim Macklin"
wrote
| in message
| reports
accidents
| in
out
required
| | "Michelle P"
| | wrote in message
| outside
| | the
| | designed to
front
| seats
essential.
forces
| | | allowed.
multiengine
| | aircraft
| Aztecs,
200
| and
| | 300.
life
| can
| controls
| | to
| | | Michelle
Old September 27th 07, 06:57 AM posted to rec.aviation.owning,rec.aviation.piloting,rec.aviation.student
Montblack
("Morgans" wrote)
away. I know.
yoke (10 inches) that the closeness makes it much more difficult to pull
hard on the yoke?
I think she's saying ....she never had any problems getting dates in H.S. or
college, and that Ron is one lucky fella, IYKWIM. g
http://www.youtube.com/watch?v=7uWynkMaVno
"She's an Eagle When She Flies" - Dolly
Montblack
http://www.youtube.com/watch?v=rgOBzs4UP-Y
Ok, this one was for me :-)
Question for Bob Gardner - Multiengine bank angle kevmor Piloting 5 May 14th 07 08:40 PM
Multiengine Rating [email protected] Piloting 79 January 25th 07 06:58 PM
Multi Engine & Time Building? Multiengine.net NW_PILOT Piloting 15 October 15th 05 12:05 AM
IFR rating? Bob Martin Piloting 58 May 7th 04 04:29 PM
rotorcraft commercial rating or better rating advice Rick Cook Rotorcraft 0 October 13th 03 04:49 PM
