Howard Hughes' Little Airplane Accident in Hollywood
Old September 23rd 07, 06:22 PM posted to rec.aviation.piloting
Neil Gould
Default Howard Hughes' Little Airplane Accident in Hollywood
Recently, Morgans posted:
"C J Campbell" wrote
Hmm. I thought it was just scraping tiles off a roof. I'll have to
look at it again.
It was. They were terra-cotta roof tiles, which have the color and
somewhat the consistency of bricks, so it would be easy to confuse
the two.
Interesting, I'll have to look at it again sometime. But to the pilot, I
suspect that it would be a distinction without a meaningful difference.
Neil
Old September 27th 07, 07:49 PM posted to rec.aviation.piloting
Kingfish
On Sep 20, 2:36 pm, "Kloudy via AviationKB.com" u33403@uwe wrote:
here's more.
Indeed not plywood.http://www.check-six.com/Crash_Sites...crash_site.htm
Interesting the four-engine RB-50 (formerly B-29) was "much more
economical" for the photo recon mission than the XF-11 twin? I'm also
curious about the contra-rotating props on Hughes' plane - what was
the benefit? The article says he did have conventional props put on
the second prototype.
Old September 27th 07, 08:25 PM posted to rec.aviation.piloting
Steven P. McNicoll
"Kingfish" wrote in message
It was more economical to modify aircraft already in the inventory for the
reconnaissance mission than to procure dedicated reconnaissance aircraft.
Old September 27th 07, 09:29 PM posted to rec.aviation.piloting
Orval Fairbairn
In article . com,
here's more.
The contra-rotating props helped absorb the power of the R-4360s. Look
at the Russian Bear Bomber as another example. They also helped to
negate P-factor, as each prop had blades coming down on each side.
Old September 28th 07, 01:52 AM posted to rec.aviation.piloting
Morgans[_2_]
The contra rotating props are said to be more efficient, and it has to do
with the swirling motion props impart to the air.
When one prop hits the air, it sends it flying back at a much higher speed
which gives you thrust. It also starts the air spinning around. The energy
it takes to spin it is basically wasted, because it does not contribute to
forward thrust.
If you put another prop right behind the first prop rotating the opposite
way, the spin whacks the second prop, and takes the spin out, which converts
that spin into rearward velocity, and recovers some of the wasted energy of
the spinning prop wash.
So it is said. g
Jim in NC
Old September 28th 07, 06:47 PM posted to rec.aviation.piloting
Kingfish
On Sep 27, 4:29 pm, Orval Fairbairn wrote:
In article . com,
here's more.
I wonder how the Russians handle prop governor failures in the Tu-95?
I guess feathering props on one engine is not a huge deal when you
have three more?
Gear Up, pt 7 - pilot Howard Hughes in a ploughed field.jpg (1/1) Mitchell Holman Aviation Photos 0 April 20th 07 02:21 PM
Thrusting or Sucking (where's Howard Stern when we need him.) 01-- Zero One Soaring 0 January 17th 06 01:40 PM
Thrusting or Sucking (where's Howard Stern when we need him.) Ken Kochanski (KK) Soaring 37 January 14th 06 09:51 AM
Howard Ebersole TomnKeyLargo Soaring 0 January 8th 05 11:32 PM
Hughes replica accident? Steve Dold Piloting 5 August 6th 03 12:05 AM
