Compass overhaul dream
Old September 29th 07, 03:20 AM posted to rec.aviation.owning
Peter R.
Default Compass overhaul dream
I just had the most realistic dream. In the dream my Bonanza compass had lost
all of its fluid and was looking pretty sad. Concluding that the compass
needed to be replaced, I found a couple of well-respected aviation supply
websites that sold new compasses for a price. However, right there below the
new compasses I spotted what was labeled in my dream a compass repair kit
that sold for less than a tenth of the new compass price. After asking other
pilot/owners in my dream about this, I learned that these safe and
rule-abiding pilots experienced dreams of successfully rebuilding their
compasses.
So in this dream, I decided to buy and try the compass repair kit, knowing
that I could never do this in real life since sometimes the FAA still
operates from rules carved in stone back in the '60s and '70s. When the
package arrived from UPS Brown (yes, I dream in color), I eagerly ran up to
my kitchen table with the kit and compass in hand and proceeded to
disassemble the compass, even though this repair kit was missing a promised
instruction sheet. I was now crossing the rope without a net.
This is where the dream got interesting. In taking the compass apart, I
discovered that the diaphragm in the back of the compass was quite brittle
and torn, which was the source of the leaked fluid. Fortunately the repair
kit came with a shiny new diaphragm for the back and two seals for the glass
on the front of the compass along with a bottle of "official" compass oil
that could fill more than two empty compasses. With only three different
sized flat-head screwdrivers and fifteen minutes of my time, the compass was
back together and filled to the threads with compass fluid. Once again, it
looked happy.
At the conclusion of the dream I awoke smiling, but alas this joy was quickly
grounded upon receiving a real life call from my mechanic telling me that the
alternator clutch needed to be replaced. Such is but one story of the trials
and tribulations of aircraft ownership.
Peter
Old September 29th 07, 03:38 AM posted to rec.aviation.owning
Kyle Boatright
Interesting dream.
Apparently, my dream compass must have a leak that is so small to be
unnoticeable externally, but which requires a top-off every 5 years or so.
In my dreams, I refill it with a syringe.
KB
"Peter R." wrote in message
lost
other
compasses.
to
promised
glass
was
looked happy.
quickly
trials
Peter
Old September 29th 07, 04:35 AM posted to rec.aviation.owning
Montblack
("Peter R." wrote)
lost all of its fluid and was looking pretty sad.
Was this part of your wet (compass), total loss of fluid, dream?
What can Brown do for you?
What can Amber do for you?
http://image22.webshots.com/23/7/34/...0ryzhZZ_fs.jpg
....and Jade, and Scarlet, and Violet?
Montblack
http://www.unitedmaskandparty.com/Costumes/images/rocky_horror_magenta_costume.JPG
....and Magenta!
Ouch, shouldn't have eaten those onions before bed.
Old September 29th 07, 01:03 PM posted to rec.aviation.owning
Peter R.
...and Magenta!
Eesh.
Peter
Old September 29th 07, 02:12 PM posted to rec.aviation.owning
Roy Smith
http://www.unitedmaskandparty.com/Co...r_magenta_cost
...and Magenta!
Eesh.
It's just a step to the left...
Old September 29th 07, 03:32 PM posted to rec.aviation.owning
RST Engineering
'30s and '40s.
Old September 29th 07, 09:17 PM posted to rec.aviation.owning
kontiki
RST Engineering wrote:
'30s and '40s.
Exactly. Thanks for the clarifiaction Jim.
Old September 30th 07, 01:08 PM posted to rec.aviation.owning
Stealth Pilot[_2_]
On Sat, 29 Sep 2007 20:17:30 GMT, kontiki
'30s and '40s.
in the original op's dreaming he should have noticed whether the
compass still turned freely.
if it does dream on.
if it doesnt take out the spindle and chuck it in your nearby lathe
and reshape the pointy bit. (this will all be clear in your dream so
clarification isnt necessary here :-) ) get rid of all flats and it
will be a wet one again.
then just before awakening again place the compass down at the bottom
of the panel away from all the heat and it will swim on for another 5
years before dreaming needs to set in again.
Stealth (just another dreamer) Pilot
australians are aware of a dreamtime heritage :-)
Old September 30th 07, 03:13 PM posted to rec.aviation.owning
Peter R.
Interesting. The compass in the dream was swinging freely after it was
rebuilt but that is good to know nonetheless.
This model of compasses is painted black and, as you know, mounted on top of
the glare shield right in the direct sunlight. At the very least wouldn't it
be healthier for the unit if it were painted white? The removed diaphragm
clearly suffered some serious heat damage.
Peter
Old October 1st 07, 02:34 AM posted to rec.aviation.owning
top of the glare shield right in the direct sunlight. At the very least
wouldn't it be healthier for the unit if it were painted white?
It might be better for the compass but possibly not so good for you.
Eventually you'll hit the right combination of heading and time-of-day
that will make the sun reflect off of that white compass and right into
your eyes. (Another way to experience this is to drive a car whose wiper
arms were originally painted black, but have weathered to expose bright
metal underneath. Eventually you'll blind yourself but good. I found
that having to re-apply a couple of coats of rattle-can black once a
year was a small price to pay.)
Disclaimer: This is based on experience with ground vehicles and
equipment. I don't have an A&P; I don't even have a TG&Y. Your
mileage may vary.
Matt Roberds
To overhaul or not to Overhaul, that is the question- EridanMan Owning 19 May 12th 06 11:58 PM
compass turns with high mounted compass (Cessna 152) Ray Instrument Flight Rules 22 April 7th 05 07:39 AM
A Dream franck jeamourra Piloting 0 March 27th 04 07:43 PM
A dream franck jeamourra Simulators 0 March 25th 04 12:26 PM
a dream franck jeamourra Owning 0 March 25th 04 06:26 AM
