#11
On Tue, 02 Oct 2007 05:06:23 -0700, Eunometic wrote:
Essential and Dispensible WW2 aircraft. *********************************************** The C-47 and the Ju-52 were pretty essential. |
![]() Eunometic wrote: Essential and Dispensible WW2 aircraft. *********************************************** USA: P-51; the P-38 had sufficient range to cover untill the P-47M with a wett wing which actually could excede the range of the P-51. You'd have to be nuts to think the P-51 wasn't essential. It was vital in Europe. Why you list it under USA is odd too since it was originally designed for the RAF as the Mustang. The USAAF only adopted it later. The critical improvement to the Mustang was the fitting of the RR Merlin engine which was an RAF idea. Graham |
On Tue, 02 Oct 2007 15:49:11 -0700, Gordon
wrote: P-40 USAAF effective fighter of excellent quality; it was quite effective with appropriate tactics. What a lot of people don't fully realize is that this aircraft was just about all we had for the first two years of the war, and it remained in service long after it was made obsolete by others. Until the unready P-38s and the thirsty P-47Cs came along, P-40s were just about it! Well, there was the P-39..... P-47 Ready far earlier than the P-51. But not long-range capable to the same extent nor with the same performance; and the timing is easy to overstate the first combat-capable P-47C's were operating in April 1943, the first combat-capable P-51B's in November 1943. P-51; the P-38 had sufficient range to cover untill the P-47M with a wett wing which actually could excede the range of the P-51. Cost and battlefield effectiveness - P-38s would have had a very difficult time against airfield defenses and in other roles where the 51 excelled. More importantly, the P-51 was an altitude-capable long range fighter escort in the ETO at a time when the P-38 wasn't, despite its long range. Gavin Bailey -- Solution elegant. Yes. Minor problem, use 25000 CPU cycle for 1 instruction, this why all need overclock Pentium. Dumbass. - Bart Kwan En |
wrote: P-51; the P-38 had sufficient range to cover untill the P-47M with a wett wing which actually could excede the range of the P-51. The P-47N wasn't available until nearly a year and a half after the P-51B; good luck trying to sell a long-range P-47 available in mid-1945 to Arnold when he demanded a long-range escort fighter for the ETO in mid-1943. Gavin Bailey -- Solution elegant. Yes. Minor problem, use 25000 CPU cycle for 1 instruction, this why all need overclock Pentium. Dumbass. - Bart Kwan En |
On Oct 3, 7:41 am, "Keith Willshaw"
wrote: "Eunometic" wrote in message ps.com... Essential and Dispensible WW2 aircraft. *********************************************** I've created a list of aircraft of WW2 that were essential to that side and also others that were dispensible in the sense that their place could easily have been taken by other aircraft or that were so ineffective that they were not needed at all. A great deal of effort was spent on aircraft that did not perform and were 'war loosers' while there was also a great deal of duplication of effort on aircraft that added nothing special and detracted from gains in production. United Kingdom Essential: Hurricane; had to be avialable in numbers for battle of britain Spitfire; had to provide quality fighter throughout the war an amenable to all rolls. Mosquito; night bomber, night fighter, fast day bomber and most importanty reconaisance aircraft par excellance. Lancaster; easy to fly, devastating war load. Wellington: Britains Medium bomber and an important coastal command aircraft. Non Essential: Beaufighter; not a useless aircraft as it could take damage but its roll could have been taken by others. It kept bristol busy. I strongly disagree. It played an essential role both as a nightfighter and in the shipping strike role in the ETO and their long range made them extremely valuable ground attack aircraft in the far east It's contemporary the the Mosquito could also do that job, and much better at that. What I don't like about it was that if confronted by german airforce day fighters it was in deep trouble. It needed an escort; whereas the mosquito coastal command aircraft actualy took on Fw 190. If given a choice of choosing between 1000 extra Mosquito vs 1000 less beaufighter? Hampden; Halifax; a good aircraft but Lancaster was better. Stirling; a waste of time although a saluatory lesson. Tempest and Typhoon: These aicraft had very poor high altitude performance and the typhoon had handling difficulties, was not particularly fast due to its thick wing and its airframe tended to snap of at the tail It could and did however make an excellent ground attack aircraft and played a vital role in the western campaign attacking the Wehrmacht I don't deny it. It was kind of successful, napier and tail breakages aside but as far as I can see the Mk XII Griffon spit could do a better job and was available at the right time. Immagine putting the engineers who were working on the the Typhoon/ Tempest and the Sabre to work on things more essential such as a B-29 class bomber using the centaurus or a fast medium bomber. Generally the British (air ministry, raf etc) had the knack of abandoning loosing designs and making pragmatic choices. By 1942 Supermarine was producing the Spitifre Mk XII which had a single stage Griffon engine and could outrun the Tempest. Although the mk XII also had poor altitude performance its handling was better. It would be early 1944 before the Mk XIX entered service which had a two stage Griffon. Germany: Since Germany lost the war I found it hard to determine what to put in non essential so I've added the column 'might have' Essential: Me 109: Hurricane vintage aircraft but remained competitive untill 1945 when Me 109K-4's were capable of 455mph and 48000ft service ceiling and even then there were versions such as the Me 109K-14 with a two stage supercharged DB603L engine starting production but not delivered as well as the DB603DSCM engine touching on 2000hp at 1.98 atm boost there were test of 2.3 and 2.4 atm going on at DB which suggests a power of 2400hp and speed of 470-480mph. The aircraft should have been replaced far earlier with something that had lighter contol forces and better speed. It would have performed better with superior fuel. Fw 190: this aircraft filled in many of the Me 109's weaknesses. ju 88: night fighter, high speed bomber, dive or slant bomber, maritime patrol etc. Ju 87: Devastating in combined arms breakthrough warfare and deadly accurate. When its days were over it lived on as a night bomber and ground attack aircraft with one of the lowest per mission loss rates of any Luftwaffe aircraft. He 111: early bombing workhorse Do 217 Only 1200 produced but still effective as a night bomber and guided missile carrier. Arado 234: the jet aircraft provided essential reconaisance: it was the first and only aircraft to survey the Normandy beach-head. Two prototypes flew about 36 missions with their engines being reliable during this process. They were both shot down by their own German FLAK. Fi 103 or V1. Extremely cheap to produce consumed massive allied resources. Non essential: Do 17 Me 110: its role as a night fighter could have been taken by the Ju 88, I am aware of its success in the Early Polish and Soviet Campaigns but I don't think these were decisive. Might Have Me 210/410 Quite a good aircraft that was to replace the Ju 88 and The Me-210 suffered from oscillation making it a poor gun platform and had nasty stall characteristics. The pilots HATED them and only a month after entering service production was halted The tragedy of the Me 210 was that the problem were known even before the moment the test pilot stepped out of the aircraft on its maiden flight. He said that the tail needed to be lengthened by 1 meter or so. To do that over 5million reich marks of jigs would need to be scrapped. So instead slats were tried, these didn't work and actually made things worse, a single large as opposed to two fins was tried; that didn't work. When the Me 210C was ordered by the Hungarian air force they bypassed the managerial and political problems and incorporated the lengthened tail and slats which worked brilliantly together. The solution to handling problems; lengthened tail, slats and contra- rotating propellor were well known. It was said that Willy Messerschmitt personally intervened in the design process to shorten the tail and remove the slats. Year were wasted in avoiding these simple modifications. Willy Messerschmitt was stripped of the assets or his company, barely avoided jail while I think Ernest Udet probably committed suicide over the issue. Heinkel had been told to stop He 111 production and tool up for Me 210 and when this failed it had to produce Ju 88's instead. There was such a loss in productivity (since tooling wasn't right) that production suffered thousands of aircraft and forced labour ended up being used. The rest of the industry suffered as well. The Me 410 was simply the fixed Me 210 with bigger 44L DD603 engine instead of 33L DB605 engines. Me 110. Fast, advanced armament, bomb bay, efficient etc but simply too late due to programm mismanagment to survive in allied skies. Say What ! I meant to type Me 410. It was a good aircraft with better performance than allied equivalents. Had it been on time or a year late it would have had a significant impact. The Me-110 entered service before the war started in 1939. While inadequate against first line fighters in the West it played a valuable role as a NF and ground attack craft. It survived in service long after the Me-210's were withdrawn. I think a few modified Me 210 opperated succesfully before being renamed Me 410 when they got the new engines to get away from the bad name. Keith |
On Oct 3, 9:49 am, Gordon wrote:
On Oct 2, 7:06 am, Eunometic wrote: Essential: Hurricane; had to be avialable in numbers for battle of britain Spitfire; had to provide quality fighter throughout the war an amenable to all rolls. Series numbers need to be included in your listing, as some marks of each of these aircraft made far more of an impact than others. Eric Brown told us that "by FAR [his emphasis], the Spitfire XIV was the most outstanding British fighter of the war." I believe Galland made the comment that the best thing about the Mk XIV was that there were so few of them. I think about 860 produced for servive and perhaps jut over half that number in use at one time. Most had clipped wings since it was feared that stresses were to great. The Mk XIV was an interim type: till the Mk XVIII introduced a tapered stainless steel spar for extra strenght while the parrallel Mk 20 received a completely new wing of much stiffer structure to reduce aeroeleasticity and thereby increase roll rate. For "best fighter of the war", he left absolutely no doubt, stating that "...with the Me 262, it was apparent after a few flights that we were... years behind in fighter development." He felt it was a superb fighter with good range for the day, a remarkably heavy armament, and few vices. Mosquito; night bomber, night fighter, fast day bomber and most importanty reconaisance aircraft par excellance. I think the amount of damage it did as an Intruder and marking targets for Main Force heavies cannot be underestimated either. Lancaster; easy to fly, devastating war load. Wellington: Britains Medium bomber and an important coastal command aircraft. Strange to see the Wimpy in here but we simply must include something from Mr. Wallis. ![]() He 111: early bombing workhorse Redundant, I think, if you are including the Ju on your list, as it was clearly superior in all regards. Do 217 Only 1200 produced but still effective as a night bomber and guided missile carrier. very few successes in this role. As a night bomber, it was inefficient and could not survive most attacks. I think the Ju 88 was "Essential", and the Do was not. Might Have Me 210/410 Quite a good aircraft that was to replace the Ju 88 and Me 110. Fast, advanced armament, bomb bay, efficient etc but simply too late due to programm mismanagment to survive in allied skies. Strongly disagree. I have known Me 210 / 410 pilots and they thought the 210 was "ghastly" "horrible to fly", and the 410 was "too complex; filled with gadgets" although the Gruppe commander of the Schnellbombers said he really thought the glass panel between the feet was an excellent idea. I don't know what role the 210/410s filled that other aircraft could not have done better. Complexity was the way to go; the remote control guns needed even more complexity; computers to calculate lead I think. However I note that LeMay insisted that his escorts fly ahead of the B-29 to prevent head on an side attacks. The computers dealt well with tail attacks only. He 219; succombed to political problems; an excellent night fighter and unlike the Me 110 and early Ju 88 it had the speed to chase down British bombers once diversionary raids and feints had been ascertained. I think it was essential, just stupidly ignored. He 177: engine problems were not tackled agressively. The B series with 4 seperate engines could have made up the bulk of production and provided the Luftwaffe with a reliable long range bomber of exceptional performance had courage preceded arse covering. By the time it matured into an effective bomber, its bases were under Allied-controlled skies, making good use impossible. Germany needed a heavy bomber in 1940-41; by 1944, they were just targets for roving Allied fighters. Perhaps some use against convoys where the Fw 200 was inadquete and against the Soviet unions ural factories. USA: Essential: P-40 USAAF effective fighter of excellent quality; it was quite effective with appropriate tactics. What a lot of people don't fully realize is that this aircraft was just about all we had for the first two years of the war, and it remained in service long after it was made obsolete by others. Until the unready P-38s and the thirsty P-47Cs came along, P-40s were just about it! Clive Caldwell showed it could be deadly against the Me 109. P-38 Had the range and performance to protect US bombers. It prevented the German Airforce from fielding heavy aircraft firing rockets, or impunely attacking bombers under the protection of heavy armour. Hmmmmm... It seems in my memory that the rocket-firing German fighters were mostly treated roughly by P-47s and the gunners aboard the heavy bombers. B-17 Hightly survivable high altitude bomber. B-24 Longer ranged then the B-17; its only virtue. Greater warload as well. I think these were both essential. B-25 Versatile and easy to fly in all theatres of war. Wildcat, Hellcat, dauntless, avenger Not sure if we actually "needed" the Avenger. The IJN was primarily bombed out of existance, not torpedoed out of existance (not counting the tremendous job done by the Silent Service, of course). P-47 Ready far earlier than the P-51. Non Essential B-26 not as versatile as the B-25 and for a medium bomber too demanding of runway conditions. But faster, which is important if you are in amongst enemy fighters. I think the versions with the extended span, the b-26G was no faster. What if a PW2800 was placed aboard the B-25 instead of the CW2600. Helldiver: too many handling problems. Blew. Only "replacement aircraft" that I know of that was taken out of service and "replaced" by the aircraft it was supposed to replace. Crews called it "the Beast", and I have to date never met anyone that liked it in any way. Yet it eventually sank the Yamato using vertical 90 degree dives P-51; the P-38 had sufficient range to cover untill the P-47M with a wett wing which actually could excede the range of the P-51. Cost and battlefield effectiveness - P-38s would have had a very difficult time against airfield defenses and in other roles where the 51 excelled. Primarily, the P-51 beat everyone else in its fielded numbers; what is better, five squadrons of P-38s or 25 squadrons of Mustangs, with a much higher sortie rate and far lower price tag? Vought corsair: took to long to perfect for carrier opperations; A Navy Captain told me, "That _____-___ ____ of ____ wasn't worth the trouble - we were forced to take it by politicians." He was a loyal Grumman customer and saw no need whatever for the F4U. Hellcat did a good enough job. You have a talent for understatement. Had the Ki 84 been available in numbers and supplied with 100/130 octane fuel the corsair would have been essential naaaaa. Ki 84 did 430 mph when run on US f100/130 fuel. Japan: Essential: Mitsubishi A6M zero and Betty. Dinah, Ki 84 Non essential All army types apart from the dinah and Ki 84 Soviet Union Essential Illushian Sturmovik, Pekelatov Pe2, Tupolev Tu 4, I-16 The last LaGG and the Yak 9 absolutely should be on your list. v/r Gordon |
On Wed, 03 Oct 2007 04:44:52 -0700, Eunometic
wrote: On Oct 3, 7:41 am, "Keith Willshaw" wrote: "Eunometic" wrote in message ps.com... Essential and Dispensible WW2 aircraft. *********************************************** I've created a list of aircraft of WW2 that were essential to that side and also others that were dispensible in the sense that their place could easily have been taken by other aircraft or that were so ineffective that they were not needed at all. A great deal of effort was spent on aircraft that did not perform and were 'war loosers' while there was also a great deal of duplication of effort on aircraft that added nothing special and detracted from gains in production. United Kingdom Essential: Hurricane; had to be avialable in numbers for battle of britain Spitfire; had to provide quality fighter throughout the war an amenable to all rolls. Mosquito; night bomber, night fighter, fast day bomber and most importanty reconaisance aircraft par excellance. Lancaster; easy to fly, devastating war load. Wellington: Britains Medium bomber and an important coastal command aircraft. Non Essential: Beaufighter; not a useless aircraft as it could take damage but its roll could have been taken by others. It kept bristol busy. I strongly disagree. It played an essential role both as a nightfighter and in the shipping strike role in the ETO and their long range made them extremely valuable ground attack aircraft in the far east It's contemporary the the Mosquito could also do that job, and much better at that. What I don't like about it was that if confronted by german airforce day fighters it was in deep trouble. It needed an escort; whereas the mosquito coastal command aircraft actualy took on Fw 190. If given a choice of choosing between 1000 extra Mosquito vs 1000 less beaufighter? Beaufighter in service date Oct. '40, Mosquito in-service date almost exactly a year later. The Mosquito used merlin engines, a crucial supply item until some time in '43 Peter Skelton |
On Oct 3, 1:34 pm, wrote:
There are some real whoppers in your list, and critical omissions too. I'll concentrate on the USA, which I know best: USA On 2-Oct-2007, Eunometic wrote: P-38 Had the range and performance to protect US bombers. It prevented the German Airforce from fielding heavy aircraft firing rockets, or impunely attacking bombers under the protection of heavy armour. TOTALLY WRONG. The P-38 was a FAILURE in the ETO, due to poor high altitude performance from defective engines and unreliable turbosuperchargers. Its unheated cockpits were another significant liability because of their effect on pilot performance. It was a long-range wonder in the Pacific, where it fought at lower altitudes, but was a failure in the ETO. This problem got down to california being warmer in winter than germany at 25,000ft. The coolant oil congealed due to excess cold. There was predetonation at altitude due to excess cooling in the intercoolers forcing to much air into the engines. Both problems were sovled. One one think that improving cockpit heating should have been easier than converting the P-51 to take a merlin or to add a bubble canopy and a rear fueselage tank. P-47 water ethanol injection system blew up due to ice formation for similar reasons and was unusable. The real reason the P-38 was transfered to the Pacific theater is because it was in high demand over the not becuase it was a failure. In the end the the P-38L-1-LO, could claim a combat radius of nearly 1,500 miles under ideal conditions which was far further than any P-51 could conceivably achieve. In parallel with this is your assertion that the P-51 was "not essential." Only the P-51 had the necessary escort range. Without it the daylight bombing campaign would have failed in late 1943. Moreover, the 51 outperformed virtually all-prop driven Axis fighters. This aircraft won the air war for the Allies in the ETO. One statistic says it all. In 1945 the only 8th AF fighter group still flying the P-47 was the 56th FG. All others flew the 51. This wasn't an accident. BTW, the "wet wing" P-47Ms you tout had huge engine reliability problems, which kept them grounded most of the time. I actually meant the P-47N as this was the model with the wing tankage. It could fly 2000 miles with 300 miles and 20 minutes combate at full power and 5 minutes a WEP. Further than any P-51. The P-38 and P-47 were available earlier. The P-51C carried its fuel in its wings; the P-51D added a big tank in the tail that made it unstable and uncombatworthy to fly. The P-47 carried its tankage in its fueselage. This was increased progressively in the latter P-47D models and when the P-47N arrived it to carried fuel in wings that must have been as thick as the P-51s and had a better range to boot. As far as I can tell Happy Arnolds directive to Spaatz to develop long range escorts didn't specify Mustangs. The Mustang was a fine plane but I think the P-38 and P-47 could have done the job if pressed a little more than they were. A truly essential aircraft you overlook was the C-47 transport. "General Dwight Eisenhower described the C-47 as one of the four machines that won World War II, along with the bulldozer, 6x6 truck, and the landing craft."http://www.faqs.org/docs/air/avc47.html The Germans built 3000 transports while the Allies about 50,000. Logistics wins. In the Pacific the early "essentials" were the Wildcat and the Dauntless. JAPAN In addition to the A6M Zero, I think you also need to include the two other carrier aircraft Japan possessed at the outset: the "Val" dive bomber and the "Kate" torpedo/level bomber. All three were essential to Japanese naval air power, even after defeat at Midway. I'm not sure any Japanese twin engine bomber was "essential." They all had fatal design flaws (lack of armor and flammability) that made them little more than flying targets. The Japanese air war was first won, then lost, by their single engine aircraft. Speaking of which, I don't see the Army Ki-84 as essential. IMHO that plaudit goes the the Nakajima Hayabusa Ki-43, which like the Zero served throughout the entire war. USSR I don't think you can exclude the Yak fighters, especially the Yak-9. I will also include a surprising choice for an "essential" Soviet A/C: the Bell P-39. It is remarkable how many Soviet aces not only flew that aircraft, but greatly favored it. If you placed a russian or german aircraft next to a US one the build quality of the US one would show in beautifull detail such as the clarity of the plastic and glass. My comments, FWIW. Brian |
On Oct 3, 8:09 pm, The Amaurotean Capitalist
wrote: On Tue, 02 Oct 2007 05:06:23 -0700, Eunometic wrote: P-51; the P-38 had sufficient range to cover untill the P-47M with a wett wing which actually could excede the range of the P-51. The P-47N wasn't available until nearly a year and a half after the P-51B; good luck trying to sell a long-range P-47 available in mid-1945 to Arnold when he demanded a long-range escort fighter for the ETO in mid-1943. Gavin Bailey Yes but the P-47B or P-47C didn't have the tail tank and therefor range yet. If pressed to find a solution to extra tankage it would have been possible to introduce a tanked wing earlier i feel. |
On Oct 3, 8:00 am, "rob" wrote:
"Eunometic" wrote Essential Wellington: Britains Medium bomber and an important coastal command aircraft. For a short while, they probably wouldn't have missed it had it not been designed. I was suprised to learn that the Whitley had actually lower attrition since it had been designed for night opperations from the start and also did the u-boat patrol business. Non Essential: Beaufighter; Invaluable in the anti-shipping role. Made a large if not desicive contribution to the campaign in N Africa by interdicting Rommels supplies. I'm slowly getting convinced that it was essential but retain doubts. Had the Luftwaffe been on the ball it should have failed. Tempest and Typhoon Wasn't the Tempest the quickest thing the RAF had for a while? Clostermann talks of it doing something like 460mph TAS at 3000ft I think. Not that I believe that. The 1942 Mk XII spit could chase down V1's. Not inc Meteor These two types were very fine aircraft in the CAS and strike roles not to mention all the V-1s the Tempest claimed. They probably wouldn't have been missed much in the Air to Air role but unless you're putting iron on the ground Air superiority is just for show thus I would say they were essential |
Two essential items... | john smith | Piloting | 19 | December 26th 06 02:48 AM |
Delaware LLC Owned Aircraft California Based Aircraft | ChrisEllis | Piloting | 6 | January 17th 06 03:47 AM |
Commercial rating: complex aircraft required aircraft for practical test? | Marc J. Zeitlin | Piloting | 22 | November 24th 05 04:11 AM |
Exclusive Custom Home Plans, and Essential information about building your New Home | orange tree | Home Built | 4 | November 20th 05 04:37 PM |
Experience transitioning from C-172 to complex aircraft as potential first owned aircraft? | Jack Allison | Owning | 12 | June 14th 04 08:01 PM |
