Dual Trim Switches?
Old October 4th 07, 08:14 PM posted to rec.aviation.piloting
JGalban via AviationKB.com
Default Dual Trim Switches?
Maxwell wrote:
For what it's worth.
When I first checked out in an SP, the CFI told me Cessna had been
sucessfully sued when a pilot argued the tanks could not be sumped correctly
unless the aircraft was parked perfectly level.
Now you can drain the lowest point in the tank, no mater how or where you
park your SP.
I would tend to doubt that version of events. The 13 drain points were
introduced when Cessna restarted production on the redesigned 172R back in
'96. The drains were in the new version from the start, so I doubt Cessna
could have been sued. Also, we probably would have heard about it here.
Previous versions of the 172 ('84/'85) had wing tanks with no obstructions
in the bottoms. The new version had wet wings, which is what prompted the
installation of drains outboard of each rib in the tank area.
Message posted via AviationKB.com
http://www.aviationkb.com/Uwe/Forums...ation/200710/1
  #42
Old October 5th 07, 02:38 AM posted to rec.aviation.piloting
Morgans[_2_]
obstructions
And all of those extra drains could have easily been eliminated if the
engineers would have done a hours worth of work redesigning the ribs to
enlarge or add crossover points in the ribs, so all of the water could get
to the lowest point in the tank.
This has to be an example of why things are screwed up in the industry,
don't you think?
Jim in NC
  #43
Old October 5th 07, 01:10 PM posted to rec.aviation.piloting
Peter Clark
On Thu, 4 Oct 2007 21:38:15 -0400, "Morgans"
obstructions
don't you think?
The newer (post-restart) aircraft are sealed bladders, not wet wing,
therefore you can't just let the water seep through the ribs.
  #44
Old October 6th 07, 09:04 PM posted to rec.aviation.piloting
Scott Skylane
Peter, your information is incorrect. I'm looking at the Cessna Parts
Catalog for the new 172R, and 182S models. They most definitely employ
wet wing fuel bays, not bladders.
Happy Flying!
Scott Skylane
  #45
Old October 7th 07, 01:23 AM posted to rec.aviation.piloting
Peter Clark
On Sat, 06 Oct 2007 12:04:50 -0800, Scott Skylane
Interesting. I don't have my maintenance manual handy, but a quick
Google pulled this up from Cessna's website:
"The 182E also featured electrically-operated “Para-Lift” flaps,
neoprene rubber fuel bladders holding 65 gallons total, new stronger
main landing gear/fuselage attachment and improved nose wheel
steering."
http://www.cessna.com/news/article.c...XLJEsBa4kfBxm4
I wonder why they would have gone back to sealed wet-wing when they
had bladders in there years ago. I wonder where I got that the new
ones still had bladders.
  #46
Old October 7th 07, 02:48 AM posted to rec.aviation.piloting
Morgans[_2_]
"Peter Clark" wrote
"The 182E also featured electrically-operated "Para-Lift" flaps,
steering."
Looking at the 172R specs on the Cessna web pages, the wing tanks are listed
as Integral fuel tanks, 53 gallons useable, 5 quick drains per wing. No
fuel bladders in this model, it would appear.
Jim in NC
  #47
Old October 7th 07, 08:24 PM posted to rec.aviation.piloting
Scott Skylane
Default Dual Trim Switches?(i.e. Fuel Tanks)
Peter Clark wrote:
/snip/
Peter,
They didn't "go back" to a wet wing, it was an engineering development
first used in the Cessna singles in the early eighties. Originally,
172's had removable aluminum tanks in the wing bays, and 182's used
bladders.
Integral tanks ("wet wings") are lighter, easier to build/assemble, have
greater fuel capacity, and if done properly, require less mainenance in
the long run.
Happy Flying!
Scott Skylane
"Bad pressure switches discovered in Ospreys" Mike[_1_] Naval Aviation 0 June 22nd 07 07:14 PM
How much do you trim? Mxsmanic Piloting 89 October 13th 06 05:14 AM
Gear Warning Switches on a Mosquito scooter Soaring 6 March 9th 05 01:15 PM
Fading Rocker Switches O. Sami Saydjari Owning 2 February 16th 04 03:54 PM
FS on EBAY, circuit breaker switches flyer Home Built 0 December 3rd 03 06:59 PM
