Dudley, Bertie, Bob Moore, Capt. Doug...
On my recent viewing of the A380 low and slow passes over some P&W locations, I remarked how quiet the airplane was. During these passes the aircraft was noticeably pitched up (maybe 150 knots?), and slightly "dirty", just as the far simpler craft I usually fly might be in a similar "slow flight" situation. I've been told by P&W employees that the plane was loaded up with ballast, and far from light. The most common remark I get from non-pilots on the lack of noise is "he was at idle", as they compare it to a plane descending. My response is that the 380 was maneuvering and maintaining altitude, which would require more than idle power, maybe a lot more, just like a smaller craft being flown in it's own version of slow flight. Am I thinking along the correct lines, that an airliner at a decent weight would require more than idle power to maneuver and maintain a constant altitude while slow? I have zero jet time, but this would only make sense. The Pratt guys agree with me, but they haven't flown airliners either. Thanks! |
B A R R Y wrote:
Dudley, Bertie, Bob Moore, Capt. Doug... On my recent viewing of the A380 low and slow passes over some P&W locations, I remarked how quiet the airplane was. During these passes the aircraft was noticeably pitched up (maybe 150 knots?), and slightly "dirty", just as the far simpler craft I usually fly might be in a similar "slow flight" situation. I've been told by P&W employees that the plane was loaded up with ballast, and far from light. The most common remark I get from non-pilots on the lack of noise is "he was at idle", as they compare it to a plane descending. My response is that the 380 was maneuvering and maintaining altitude, which would require more than idle power, maybe a lot more, just like a smaller craft being flown in it's own version of slow flight. Am I thinking along the correct lines, that an airliner at a decent weight would require more than idle power to maneuver and maintain a constant altitude while slow? I have zero jet time, but this would only make sense. The Pratt guys agree with me, but they haven't flown airliners either. Thanks! I'm sure Moore is better qualified to answer you on the big stuff and this crate is bigger than anything I've even ridden in as a passenger, but my guess is that you are correct. If the aircraft was maintaining altitude it would most certainly have power applied and probably quite a lot of power. I will assume the engines on this bird are quieted down somewhat as well, and airspeed with something this large can be deceiving. The positive pitch angle on the fuselage would be normal depending on several factors. It's a monster!!! :-) -- Dudley Henriques |
On Thu, 04 Oct 2007 20:35:02 -0400, B A R R Y
wrote: Dudley, Bertie, Bob Moore, Capt. Doug... I'm none of them, but anyway... Here's an excerpt from http://www.airbus.com/en/aircraftfamilies/a380/ about A380's noise levels: " Low-noise characteristics have been a major design driver for the A380. As a result the aircraft is significantly quieter than other large aircraft and offers substantial margins in relation to the latest (ICAO Stage 4) noise limits. producing half the noise energy at take off and cutting the area exposed to equivalent noise levels around the airport runway by half. In addition to meeting international regulations, the A380 also presents a significant practical advantage over existing large aircraft by minimising operating constraints arising from the most stringent local noise regulations, such as the Quota Count (QC) system at London airports. Being virtually free from noise curfew, the A380 offers greater operational flexibility to airlines and their passengers while minimising the noise impact on the airport neighbourhood at the same time. This noise levels reduction has been achieved through the optimisation of the engines, nacelles and airframe. In addition, the A380 is equipped with an innovative function that enables the Flight Management System (FMS) to be programmed with departure tracks that are optimised for noise as well as performance. These allow the aircraft to reduce the take off noise while taking into account actual aircraft parameters and ambient conditions. But the A380 is not only the quietest aircraft on the outside. The A380 cabin is the quietest cabin in the sky. Reducing cabin noise levels increases passenger comfort and well-being, and is an important factor in limiting the fatigue normally associated with long haul travel. Passengers that have flown in the A380 have confirmed initial testing, which indicated the A380 cabin to be significantly quieter than today's largest aircraft, 'like stepping from a busy office into a quiet restaurant.' The A380 flight deck is also the quietest in the skies, improving working conditions for the flight crew. From an environmental perspective the application of new technology and intensive research has enabled the A380 to combine the intrinsic advantages of its larger capacity with much lower noise levels, when compared to existing large aircraft. The A380 sets a new standard in noise levels. " I guess they learned from the bad experience with Concorde. - Tom |
On Oct 4, 6:35 pm, B A R R Y wrote:
Dudley, Bertie, Bob Moore, Capt. Doug... On my recent viewing of the A380 low and slow passes over some P&W locations, I remarked how quiet the airplane was. During these passes the aircraft was noticeably pitched up (maybe 150 knots?), and slightly "dirty", just as the far simpler craft I usually fly might be in a similar "slow flight" situation. I've been told by P&W employees that the plane was loaded up with ballast, and far from light. The most common remark I get from non-pilots on the lack of noise is "he was at idle", as they compare it to a plane descending. My response is that the 380 was maneuvering and maintaining altitude, which would require more than idle power, maybe a lot more, just like a smaller craft being flown in it's own version of slow flight. Am I thinking along the correct lines, that an airliner at a decent weight would require more than idle power to maneuver and maintain a constant altitude while slow? I have zero jet time, but this would only make sense. The Pratt guys agree with me, but they haven't flown airliners either. Thanks! Barry, The latest generation of high-bypass engines produce much lower noise than older engines, mostly due to extensive research on ways to smooth the airflow through the engine and baffle the combustion noise. Hush kits were added to older engines to help them meet the new noise control requirements (up to stage 3 now). The Boeing 777 engines are very quiet as well, especially at lower power settings. Even at high power settings, they make more of a high pitched whine combined with a whooshing sound rather than the roar that accompanies the low bypass engines found on 707's and B52s. Dean |
B A R R Y wrote in
: Dudley, Bertie, Bob Moore, Capt. Doug... On my recent viewing of the A380 low and slow passes over some P&W locations, I remarked how quiet the airplane was. During these passes the aircraft was noticeably pitched up (maybe 150 knots?), and slightly "dirty", just as the far simpler craft I usually fly might be in a similar "slow flight" situation. I've been told by P&W employees that the plane was loaded up with ballast, and far from light. The most common remark I get from non-pilots on the lack of noise is "he was at idle", as they compare it to a plane descending. My response is that the 380 was maneuvering and maintaining altitude, which would require more than idle power, maybe a lot more, just like a smaller craft being flown in it's own version of slow flight. Am I thinking along the correct lines, that an airliner at a decent weight would require more than idle power to maneuver and maintain a constant altitude while slow? I have zero jet time, but this would only make sense. The Pratt guys agree with me, but they haven't flown airliners either. Well, hopefully idle power ould bring you down! If the damned thing flew around at idle all the time you'd never be able to land it. Mind you, there's flight idle and ground idle. I don't know if the 380 has flight idle al the time it's airborne or not, but even that's not usually a lot of power (imagine limiting your idle to say, 1300 revs minimum in your 172 or whateve while ou were airborne and you have an idea) They're getting much quieter nowadays. They're not being given a lot of choice in the matter as restrictions grow. Bertie |
Thanks to all! Barry |
B A R R Y writes:
On my recent viewing of the A380 low and slow passes over some P&W locations, I remarked how quiet the airplane was. During these passes the aircraft was noticeably pitched up (maybe 150 knots?), and slightly "dirty", just as the far simpler craft I usually fly might be in a similar "slow flight" situation. I've been told by P&W employees that the plane was loaded up with ballast, and far from light. The most common remark I get from non-pilots on the lack of noise is "he was at idle", as they compare it to a plane descending. My response is that the 380 was maneuvering and maintaining altitude, which would require more than idle power, maybe a lot more, just like a smaller craft being flown in it's own version of slow flight. Am I thinking along the correct lines, that an airliner at a decent weight would require more than idle power to maneuver and maintain a constant altitude while slow? I have zero jet time, but this would only make sense. The Pratt guys agree with me, but they haven't flown airliners either. More than idle would be required, but not necessarily a lot more. Remember also that the aircraft is further away than it looks, and modern high-bypass turbofans can be remarkably quiet. Have you compared the A380 directly to other aircraft in similar configurations? If they are recent, they are probably pretty quiet, too. |
Tom L. writes:
I guess they learned from the bad experience with Concorde. Or perhaps Airbus isn't the most objective source for information on the noise levels from its own aircraft. I notice the article contains virtually no actual numbers at all. |
Mxsmanic wrote in
: B A R R Y writes: On my recent viewing of the A380 low and slow passes over some P&W locations, I remarked how quiet the airplane was. During these passes the aircraft was noticeably pitched up (maybe 150 knots?), and slightly "dirty", just as the far simpler craft I usually fly might be in a similar "slow flight" situation. I've been told by P&W employees that the plane was loaded up with ballast, and far from light. The most common remark I get from non-pilots on the lack of noise is "he was at idle", as they compare it to a plane descending. My response is that the 380 was maneuvering and maintaining altitude, which would require more than idle power, maybe a lot more, just like a smaller craft being flown in it's own version of slow flight. Am I thinking along the correct lines, that an airliner at a decent weight would require more than idle power to maneuver and maintain a constant altitude while slow? I have zero jet time, but this would only make sense. The Pratt guys agree with me, but they haven't flown airliners either. More than idle would be required, but not necessarily a lot more. You're an idiot and you don't fly. Remember also that the aircraft is further away than it looks, and modern high-bypass turbofans can be remarkably quiet. Have you compared the A380 directly to other aircraft in similar configurations? If they are recent, they are probably pretty quiet, too. Someone here has flown 'Busses with very high bypas engines and knows exactly how much thrust is required to maintain slow, level, flight. And it isn't you. Bertie |
Mxsmanic wrote in
: Tom L. writes: I guess they learned from the bad experience with Concorde. Or perhaps Airbus isn't the most objective source for information on the noise levels from its own aircraft. I notice the article contains virtually no actual numbers at all. Like they would mean anything to you. Bertie |
| Better drivers? | cpw | Piloting | 62 | June 16th 06 01:46 AM |
| Any Apache drivers ? | omk | Owning | 13 | May 22nd 05 04:45 AM |
| Attention Ventus Drivers... | Stewart Kissel | Soaring | 2 | April 11th 05 08:19 PM |
| For all you Cherokee Drivers out there | Jay Honeck | Piloting | 4 | December 5th 03 10:40 PM |
| Hitting airliner with rifle round? [was: PK of Igla vs. airliner] | B2431 | Military Aviation | 7 | August 21st 03 12:29 AM |
