Fuel selector question
Old October 5th 07, 06:26 PM posted to rec.aviation.piloting
karl gruber[_1_]
Default Fuel selector question
"Mortimer Schnerd, RN" mschnerdatcarolina.rr.com wrote in message
Frankly, on a C-172 I can't think of any reason either.
http://www.caa.is/datadir/bsdata/img...s/72-07-02.pdf
Karl
Old October 5th 07, 06:40 PM posted to rec.aviation.piloting
Allen[_1_]
On the C-402 for example, you had to burn a good 30 minutes on the
outboards (which were its mains) before you could switch to the inboards.
When you switched to the inboards, the fuel actually went from the
inboards to the outboards to the engine. If you didn't make room first by
burning the outboards first, the fuel pumped from the inboards would just
be pushed through the overflow valves on the outboard tanks and then you
get to sprinkle the landscape with expensive avgas.
You got that partially right. The aux tanks each have their own electric
fuel pump that pushes the fuel throught the selector valve and on to the
engine driven fuel pump. Excess fuel from the engine driven fuel pump is
routed back to the main (tip) tanks. The reason for running on the tip
tanks first for 60 (or 90 for the large aux tanks) minutes is to make room
for this bypass fuel.
*H. Allen Smith*
WACO - We are all here, because we are not all there.
Old October 5th 07, 08:31 PM posted to rec.aviation.piloting
On Oct 6, 12:47 am, es330td wrote:
Sorry if this is dumb (I am only at 8.3 hours toward my PPL)...
In the email I got from AOPA ePilot training tips today there is a
discussion of fuel starvation that makes regular mention of the fuel
selector switch. All my flying is done in a CE172 and the first and
last time I worry about the switch is during pre-flight when I confirm
that it is on both. I fly on both and never fly any other way and to
be honest, outside of gravity flow issues when parked on an incline I
cannot think of why one would want to select one tank at a time vs
both.
If you ever get to a situation where you are worried about fuel, you
switch to one tank and start your watch, when that tank runs dry
(engine splutters) you will have a very good idea of how much flying
time you have left. This knowlege will enable you to decide if your
chosen alternate airfield is in reach or if you neeed to start your
precautionary landing procedures (looking for a paddock etc.)
Cheers
Old October 5th 07, 08:38 PM posted to rec.aviation.piloting
On Oct 6, 4:25 am, "karl gruber" wrote:
On many Cessna 172s you are REQUIRED to run on either left or right (not
both) above 5000'
Karlhttp://www.caa.is/datadir/bsdata/img/adnotes/72-07-02.pdf
Many cessna 172's? How many were not modified -I've not seen the
required placard...
Cheers
Old October 5th 07, 08:50 PM posted to rec.aviation.piloting
BT
Some times after some maneuvers.. or continuous pattern work with not that
great coordination.. you may find one tank (wing) heavier than the other
because the fuel is unbalanced. select the heavier (fuller) tank for a few
minutes and monitor to rebalance, then back to "both".
Of course.. training to select one tank or the other for single tank
operations, prepares one for flying other aircraft.
BT
"es330td" wrote in message
both.
The POH will answer that.
-Kees
I bought one two days ago. I should finish reading it this weekend.
Thanks.
Old October 5th 07, 09:09 PM posted to rec.aviation.piloting
Gene Seibel
both.
If you are running on "BOTH" and there is an obstruction in a fuel
line, fuel could feed only from the other tank and you might find
yourself with fuel starvation long before you expect it. Changing
between left and right on a regular basis may let you discover such a
problem before it's an emergency. A close watch on fuel gauges and
being sensitive to heavy wing helps too.
Gene Seibel
Gene & Sue's Aeroplanes - http://pad39a.com/gene/planes.html
Because we fly, we envy no one.
Old October 5th 07, 09:23 PM posted to rec.aviation.piloting
Al G[_1_]
"Allen" wrote in message
by burning the outboards first, the fuel pumped from the inboards would
just be pushed through the overflow valves on the outboard tanks and then
you get to sprinkle the landscape with expensive avgas.
*H. Allen Smith*
Correct for the AUX tanks. However, the optional locker tanks function
just like Mortimer said.
Al G
Old October 5th 07, 10:52 PM posted to rec.aviation.piloting
Robert M. Gary
My Mooney doesn't have a both. However, its nice to know that if I
ever did run out of gas, I could always switch to the other tank and
having something left. If you run out in a C-172 on "both" you're
done.
-Robert
Old October 5th 07, 11:06 PM posted to rec.aviation.piloting
Mortimer Schnerd, RN[_2_]
Oops... it's been a while.
Fuel line question Lou Home Built 12 October 9th 06 03:46 PM
Fuel selector or two check valves? Rob Turk Home Built 13 July 1st 05 01:21 AM
Fuel Question Peterpan Piloting 5 March 24th 05 04:49 AM
Fuel Selector Valve Tom Cummings Owning 1 March 7th 04 03:44 PM
Fuel Selector Valve Jay Home Built 5 November 16th 03 12:16 AM
