#21
On Sat, 06 Oct 2007 01:41:50 GMT, "Vaughn Simon"
wrote in : "Larry Dighera" wrote in message news ![]() I like the idea that there is more energy per pound in Jet A fuel than AvGas, Whoa! There is more energy in Jet A per GALLON. Depending on which weight and BTU averages you are using, Jet A and Avgas come out pretty close on BTUs per pound. Remember, Jet fuel is heavier than gasoline. Vaughn Okay. The point is, that there should be a commensurate increase in range. |
Roy Smith wrote:
In article , "Vaughn Simon" wrote: "Larry Dighera" wrote in message news ![]() I like the idea that there is more energy per pound in Jet A fuel than AvGas, Whoa! There is more energy in Jet A per GALLON. Depending on which weight and BTU averages you are using, Jet A and Avgas come out pretty close on BTUs per pound. Remember, Jet fuel is heavier than gasoline. Which weighs more, a pound of Jet-A or a pound of Avgas? It depends on how much you pay for it. As you need to subtract the weight lost from your wallet from the fuel to get net weight per pound. :-) Matt |
Larry Dighera wrote:
On Sat, 06 Oct 2007 01:41:50 GMT, "Vaughn Simon" wrote in : "Larry Dighera" wrote in message news ![]() I like the idea that there is more energy per pound in Jet A fuel than AvGas, Whoa! There is more energy in Jet A per GALLON. Depending on which weight and BTU averages you are using, Jet A and Avgas come out pretty close on BTUs per pound. Remember, Jet fuel is heavier than gasoline. Vaughn Okay. The point is, that there should be a commensurate increase in range. That depends. Most diesel engines weigh more than similar power gas engines. So, you may well have less fuel capacity to stay within weight limits. Matt |
#24
M wrote:
Another factor, which only has to do with economy, is that we pay for fuel in volume (gallons), not pounds. If Jet A and 100LL are both $4 per gallon, you get more pounds of jet A with that $4. These two factor combined, diesel powered Cessna would burn about 30% less $ worth of fuel per hour at the same power output, assuming JetA and 100LL cost the same per gallon. That's quite significant. These days it seems that Jet A is consistently less per gallon than 100LL. Its also true that the federal taxes on JETA is significantly higher than AVGAS, thus the price you actually pay is not a lot less than AVGAS. |
#25
#26
On Oct 6, 7:26 am, kontiki wrote:
wrote: The lower fuel burn comes not from the higher energy of Jet-A, but rather from the higher compression ratio which converts a higher percentage of the energy to useful work. Diesel comes closer to an ideal Carnot cycle than gasoline. How much better fuel economy and efficiency would result if modern internal combustion designs were made easily available to the GA fleet (versus diesel engines) ? These new diesel engines employ the latest of modern technology in terms of materials and design, where our old Lycomings and Continentals are basically 75 year old technology. Not a fair (or even logical) comparison IMHO. Turbo diesel auto engines get around 50mpg compared to equivalent gasoline engines that get around 30mpg. That's apples to apples for you. Diesel is more efficient. Higher compression buns more of the fuel and captures more of the thermal expansion in the form of mechanical piston energy. Basic physics. |
#27
#28
On Oct 6, 6:26 am, kontiki wrote:
How much better fuel economy and efficiency would result if modern internal combustion designs were made easily available to the GA fleet (versus diesel engines) ? These new diesel engines employ the latest of modern technology in terms of materials and design, where our old Lycomings and Continentals are basically 75 year old technology. Not a fair (or even logical) comparison IMHO. If you have seen the BSFC numbers of the latest and greatest automobile gasoline engines, they're really not better than a IO-520. Why? because it's a lot easier to optimize a gasoline engine for fuel efficiency when it's operated at a narrow RPM range with little power variation. Automobile engines achieve good fuel efficiency through electronic engine control only because it's much harder to gain good efficiency across a much wider RPM range and throttle setting. From a thermo efficiency point of view, the gasoline aircraft engines designed in the 50s are very good, if they're leaned properly (which can be easily done with good fuel injection and EGT instrumentation), I doubt they can get much better in fuel efficiency regardless of what electronic you put on them. Diesel engine has better BSFC because they have fundamentally better thermo efficiency, not because they have fancy electronics. |
#29
On Sat, 06 Oct 2007 14:49:21 -0000, wrote in .com: Higher compression buns more of the fuel and captures more of the thermal expansion in the form of mechanical piston energy. Basic physics. Diesel engines have a longer TBO than gasoline engines also, don't they? Given the higher temperatures and pressures, that seems to fly in the face of basic physics, but I suppose it's a result of lower RPM operation. Yes, if properly designed, no, if not (think GMs first auto diesels). They tend to last longer for a couple of reasons: 1. Diesel engines have to be made much heavier to handle the higher compression and this tends to contribute to longevity. 2. Diesel fuel is less of a solvent than is gasoline and tends to wash the oil from the cylinders a little less. The penalty you pay with diesels is they also tend to be a fair bit heavier for the same power output. Matt |
#30
On Oct 6, 11:24 am, Matt Whiting wrote:
The penalty you pay with diesels is they also tend to be a fair bit heavier for the same power output. The Thielert also has maintenance drawbacks. We checked into getting some for our 172s, and to maintain them you need either to take them to an approved repair facility, or go to Texas and take a two-week (IIRC) course in their maintenance. And buy a bunch of expensive tools. Any major repairs requires a removal of the engine and sending it to the approved repair people. Can't take the head off, for instance, and re-ring a piston or do the valves. There's no TBO. They call it a TBR, where the whole engine is replaced with a new one. I can't put my finger on the time but I think it's around 2400 hours. Dan |
100/130 avgas | Roy Smith | General Aviation | 1 | December 24th 06 09:17 AM |
Old AvGas | gwengler | Piloting | 2 | December 16th 06 01:07 PM |
Survival and Demise Kit; Contest Points | Jim Culp | Soaring | 1 | June 21st 04 04:35 AM |
The demise of the Sea Harrier | Henry J Cobb | Naval Aviation | 39 | April 25th 04 07:27 PM |
Here's to Arafat's Speedy Demise | robert arndt | Military Aviation | 0 | September 12th 03 07:45 AM |
