My wife getting scared
Old October 6th 07, 06:47 PM posted to rec.aviation.piloting
Matt Whiting
Default My wife getting scared
Larry Dighera wrote:
On Sat, 06 Oct 2007 11:40:55 GMT, Matt Whiting
wrote in :
I'm not aware of any real data on the subject
http://www.lycoming.textron.com/supp...ces/SSP400.pdf
Descent
Plan ahead to make a smooth temperature transition between cruise
and descent. Start descent early and allow airspeed to increase
within aircraft limits. Maintain power as required and mixture
setting. Cylinder head temperature change rate should not exceed
50 degree F per minute to avoid rapid shock cooling.
Like I said, there is no data on the subject. Lots of opinions, but no
data. The GAMI folks are some of the more data oriented out there and
they have refuted several OWTs, even some that come from the engine
manufacturers.
Maybe you can point how to me the test data in an of the references you
posted that shows multiple identical engines, some that were run only at
steady RPM and some that were used for touch and goes all day, and the
component measurements at tear-down. I didn't see this in anything you
posted.
Matt
  #172
Old October 6th 07, 06:54 PM posted to rec.aviation.piloting
Matt Whiting
On Sat, 06 Oct 2007 11:22:14 +0200, Thomas Borchert
wrote in
Turns out, as Jay revealed so nicely, he himself is the problem.
What saddens me is that this "community" does nothing about it if it's our
oh-so-esteemed Brother Jay, but screams bloody murder when someone like MX does
it. Usenet, indeed...
Such a bias toward comrades is not unique to Usenet.
I see the bias you mention as the result of at least two factors: a
result of Mr. Honeck's "contribution" to GA, contrasted against Mr.
Atkielski's maligning of GA (and indeed most other aspects of
non-artificial aviation). Couple that with the social bonding that
occurs among drinking buddies and EAA members, and it's easy to see
how Mr. Honeck's frequent lack of insight and subjective opinion in
lieu of empirical fact are overlooked and tolerated by a certain
segment of the readership of the rec.aviation.piloting newsgroup.
Really? Must be my ISP is missing posts as what I've seen is running
almost unanimously contrary to Jay's opinion.
Matt
  #173
Old October 6th 07, 07:12 PM posted to rec.aviation.piloting
Mxsmanic
Matt Whiting writes:
In other words, you disagree. The tyranny of viewpoints.
  #174
Old October 6th 07, 07:15 PM posted to rec.aviation.piloting
Bertie the Bunyip[_19_]
Mxsmanic wrote in
Thomas Borchert writes:
Thanks. I was beginning to ask myself what my problem might be in
communicating about this. Turns out, as Jay revealed so nicely, he
himself is the problem. What saddens me is that this "community" does
nothing about it if it's our oh-so-esteemed Brother Jay, but screams
bloody murder when someone like MX does it. Usenet, indeed...
Facts and reality rise above personal squabbles,
You've never posted a fact in your life you didn't cut and paste.
Betie
  #175
Old October 6th 07, 07:16 PM posted to rec.aviation.piloting
Matt Whiting
Jay Honeck wrote:
I do believe this thread proves the old Usenet adage that "anyone will
argue anything". For you to be questioning the rather obvious fact
that high-power/low-power engine operations are harder on an aircraft
than steady-state engine operations illustrates a remarkable, um,
quality.
Jay, this simply isn't an "obvious fact" and I'm not convinced it is a
fact at all. You have provided one mechanic who thinks your way and
several of us have provided mechanics who disagree. This is hardly the
scenario that would surround an "obvious" fact.
I am apparently speaking a foreign language here, because I'm having a
hard time comprehending how normally intelligent people can argue this
point. Let's see if I can 'splain myself.
1. High power operation of an engine puts increased strain on
EVERYTHING. Seals, rods, gears, accessories. You name it, high power
operation is harder on your engine than low power operation.
Stress (and the strain it induces) isn't a problem in a well-designed
engine or any other structure. As long as the strain remains well below
the elastic limit, virtually no harm is done. I say virtually, as
depending on the material fatigue issues may arise if the stress is high
enough and the cycles large enough. As long as the oil film isn't
compromised, the higher stress does NOT cause any additional wear. Why
can't you understand this?
And the seals and accessories are not much aware of how much power the
engine is producing. They are much more concerned with RPM and the RPM
isn't a direct measure of power output.
2. Going from low to high power abruptly (and that, remember, is the
crux of this issue; I don't think anyone is arguing that gradual/
gentle application is terrible for your engine -- although it WILL
wear it out faster) puts sudden, abrupt pressue on those
aforementioned seals, rods, gears, pistons, cylinders, accessories.
This is what is known as "BAD", in my world.
Again, unless you are exceeding the limits of the materials, the metal
doesn't much care how fast you apply the load. Jay, you need to
understand that not all things yield to intuition. Many material
properties and engineering principles are not intuitive.
3. Your engine has a certain number of revolutions in it before it
reaches TBO. Might be a million, might be a billion -- I don't know.
Whatever that number, if you run at higher RPMs, you will reach that
finite limit sooner. Stuff run at high RPM wears out quicker.
Do you have even one shred of data to back up this claim? I believe
that NOT running an engine is THE fastest way to kill it. Starting it
often is the next fastest way. And running it is the way to make it
last longest. I doubt that the average number of revolutions per hour
is much higher for T&G practice in the pattern as it is for cruise.
Many folks fun at lower than cruise RPM in the pattern and the higher
RPM during climb-out is offset to a large degree by the lower RPM during
descent.
RPM alone does not wear out an engine.
And, most importantly to this thread, engines rammed from 900 RPM to
full power, and back, over and over, are going to wear out sooner.
Same with props, automobiles, lawn mowers, motorcycles, blenders,
chain saws, snow blowers, and virtually any other mechanical device
you can name.
I don't believe that to be true and you have shown absolutely no data to
substantiate that. I worked as a logger for 5 years and we used Stihl
brand saws almost exclusively. They ran at 6 - 8,000 at full tilt and
were started and stopped dozens of times each day and went from idle to
full throttle to idle hundreds to thousands of times each day (several
times limbing just one tree). The engines were simply bullet-proof. We
literally never wore out a single Stihl engine. Something else always
happened to the saw before the engine wore out. We ran these probably
1,500 to 2,000 hours per year as we worked 6 day weeks and often 10 hour
days.
Jay, I appreciate that you are saying what you believe to be correct
based on your intuition, but I don't believe your intuition is correct
in this case. The skidders, saws, and trucks that we ran the hardest
always lasted the longest. We had one skidder that the operator ran
more sedately as he thought it would make it last longer (he felt as you
do about engines). It didn't make 3,000 hours (not much for a Detroit
Diesel). When we tore down the engine, the transfer ports were half
closed with carbon. When the engine shop saw it the reason they said
the engine had to be rebuilt prematurely was that it wasn't operated at
FULL THROTTLE as Detroit Diesel intended it to be operated. This caused
it to run too cool and build up carbon.
Matt
  #176
Mxsmanic wrote in
Jay Honeck writes:
Ah, this is truly a rare alignment of the stars, to have all three of
these guys present in one thread...
My work here is done. I can achieve no higher goal.
A useful suggestion from a very experienced user of USENET: Never take
anything on USENET personally.
Or, if you posted, it, as fact.
Bertie
  #177
Old October 6th 07, 07:27 PM posted to rec.aviation.piloting
Mxsmanic wrote in
God I love usenet.
Bertie
  #178
Old October 6th 07, 07:43 PM posted to rec.aviation.piloting
Dan Luke[_2_]
[snip assertions totally devoid of supporting evidence]
Jay, old sport, I fear the problem is that you are *hearing* a foreign
language.
Dan
T-182T at BFM
  #179
Old October 6th 07, 09:47 PM posted to rec.aviation.piloting
Jay Honeck
I never do. Been here a long time, and I ain't goin' anywhere...
Larry, Thomas, and, yes, even you, Anthony, would receive nothing but
hospitality (and a cold one or three) at my dinner table, should you
ever find your way to Iowa.
Under all the bluster and hard blowing here, I have yet to meet anyone
who hasn't been a perfect gentleman, no matter how crazy they may seem
here.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
  #180
Old October 6th 07, 09:53 PM posted to rec.aviation.piloting
Jay Honeck
language.
Whatever. If you guys don't believe that beating an engine won't kill
it quicker than babying it, because I lack "evidence", there's not
much else I can say but "To each, his own."
I will continue to fly my engine carefully and gently, nonetheless.
Jay Honeck
Iowa City, IA
Pathfinder N56993
Scared of mid-airs Frode Berg Piloting 355 August 20th 06 05:27 PM
UBL wants a truce - he's scared of the CIA UAV John Doe Aviation Marketplace 1 January 19th 06 08:58 PM
The kids are scared, was Saddam evacuated D. Strang Military Aviation 0 April 7th 04 10:36 PM
Scared and trigger-happy John Galt Military Aviation 5 January 31st 04 12:11 AM
