#31
![]() "Larry Dighera" wrote in message ... CESSNA TO OFFER DIESEL SKYHAWK (http://www.avweb.com/eletter/archive...ll.html#196294) Cessna will offer the 172S Skyhawk with a Thielert turbo diesel engine with deliveries to start in mid-2008. In an announcement at AOPA Expo in Hartford, Conn., Cessna officials said the decision to offer the diesel came after extensive market surveys and flight testing. "The Skyhawk is already the best-selling, most-flown airplane ever with more than 43,000 delivered and this option further expands the market due to the worldwide availability of Jet A fuel," said John Doman, Cessna vice president of propeller aircraft sales. Cessna will install the engines at its Independence, Kan., factory under the supplementary type certificate already held by Thielert. Yup, gotta pay for the new improved NAS. JetA power GA aircraft are going to pay more taxes per gallon than the 100LL drivers, so UnkaSam wants more JetA sales... |
#32
![]() "Larry Dighera" wrote in message news ![]() On Sat, 06 Oct 2007 14:49:21 -0000, wrote in .com: Higher compression buns more of the fuel and captures more of the thermal expansion in the form of mechanical piston energy. Basic physics. Diesel engines have a longer TBO than gasoline engines also, don't they? Given the higher temperatures and pressures, that seems to fly in the face of basic physics, but I suppose it's a result of lower RPM operation. I think those Theilberts are throw away at 1800 hours or something... |
#33
The Thielert also has maintenance drawbacks. We checked
into getting some for our 172s, and to maintain them you need either to take them to an approved repair facility, or go to Texas and take a two-week (IIRC) course in their maintenance. A new engine needs a new skill set, simple as that. You wouldn't give your car to a mechanic who has only repaired Ford T engines so far and have him check the electronics, either! There's no TBO. They call it a TBR, where the whole engine is And where's the disadvantage? You know exactly what it will cost, and Thielert even refunds you pro rata, should the the engine not make it to TBR. A fair deal, I would say. |
#34
M wrote:
If you have seen the BSFC numbers of the latest and greatest automobile gasoline engines, they're really not better than a IO-520. Why? because it's a lot easier to optimize a gasoline engine for fuel efficiency when it's operated at a narrow RPM range with little power variation. Automobile engines achieve good fuel efficiency through electronic engine control only because it's much harder to gain good efficiency across a much wider RPM range and throttle setting. From a thermo efficiency point of view, the gasoline aircraft engines designed in the 50s are very good, if they're leaned properly (which can be easily done with good fuel injection and EGT instrumentation), I doubt they can get much better in fuel efficiency regardless of what electronic you put on them. Yes, well aircraft engines have a similar problem in terms of altitude (I know, you have a mixture control) but was also thinking beyond just the electronics and the methods of injection to thinhs like pistons, combustion chambers and cams. Those things have been addressed on most other engines. But it really doesn't matter because everyone is moving toward kerosene regardless. Its just one of the several products (as is gasoline) of the refining process of crude oil. |
#35
Blueskies wrote:
I think those Theilberts are throw away at 1800 hours or something... You think wrongly. It's 2400. |
#36
![]() Dan_Thomas_ wrote The Thielert also has maintenance drawbacks. We checked into getting some for our 172s, and to maintain them you need either to take them to an approved repair facility, or go to Texas and take a two-week (IIRC) course in their maintenance. And buy a bunch of expensive tools. Any major repairs requires a removal of the engine and sending it to the approved repair people. Can't take the head off, for instance, and re-ring a piston or do the valves. There's no TBO. They call it a TBR, where the whole engine is replaced with a new one. I can't put my finger on the time but I think it's around 2400 hours. Everything but the TBR may be nearly a non issue, if the Thielert has the kind of no mess reliability I have grown to expect from most diesels. Re ringing and doing valves are things that an air cooled engine may need often, but a diesel will probably not need until it is replaced. Only time will tell how they hold up, once they get into the field with sufficient numbers. I have a feeling they will be impressive. I also suspect that the TBR thing could change, also. The factory probably is going to get all of those replaced engines into their shop, and do a complete tear-down, and inspection and measurement of every part in the engine, to get a feel for areas that may need improvement, or possibly could be made lighter. I look forward to seeing many Thielerts in the air, and hopefully someone else will get a product into the air, also. The jet fuel burning IC engine is GA's best hope for the little guy, IMHO. -- Jim in NC |
#37
#38
Morgans wrote:
Dan_Thomas_ wrote The Thielert also has maintenance drawbacks. We checked into getting some for our 172s, and to maintain them you need either to take them to an approved repair facility, or go to Texas and take a two-week (IIRC) course in their maintenance. And buy a bunch of expensive tools. Any major repairs requires a removal of the engine and sending it to the approved repair people. Can't take the head off, for instance, and re-ring a piston or do the valves. There's no TBO. They call it a TBR, where the whole engine is replaced with a new one. I can't put my finger on the time but I think it's around 2400 hours. Everything but the TBR may be nearly a non issue, if the Thielert has the kind of no mess reliability I have grown to expect from most diesels. Re ringing and doing valves are things that an air cooled engine may need often, but a diesel will probably not need until it is replaced. Only time will tell how they hold up, once they get into the field with sufficient numbers. I have a feeling they will be impressive. I also suspect that the TBR thing could change, also. The factory probably is going to get all of those replaced engines into their shop, and do a complete tear-down, and inspection and measurement of every part in the engine, to get a feel for areas that may need improvement, or possibly could be made lighter. I look forward to seeing many Thielerts in the air, and hopefully someone else will get a product into the air, also. The jet fuel burning IC engine is GA's best hope for the little guy, IMHO. Yes, this may be the case, however the TBR has to get closer to 4,000 hours than to 2,400. Most auto and truck diesels will last at least twice as long as similar size gas engines, so with Lycs and Contis lasting 2,000 hours fairly routinely, the Thielert needs to at least double that ... unless the replacement cost is equivalent to an overhaul of a Lyc or Conti. Matt |
#39
On Sat, 6 Oct 2007 16:42:47 -0400, "Morgans"
wrote in : Re ringing and doing valves are things that an air cooled engine may need often, but a diesel will probably not need until it is replaced. So the diesel is liquid cooled? |
#40
Larry Dighera wrote:
Re ringing and doing valves are things that an air cooled engine may need often, but a diesel will probably not need until it is replaced. So the diesel is liquid cooled? http://www.centurion-engines.com/ It's liquid cooled, so no discussion about shock cooling anymore. It's fully FADEC controlled, so no overheating possible. It's geared, so a prop strike doesn't affect the engine. It's fully FADEC controlled, so always best prop pitch to the chosen power setting. and and and... in short, everything I would expect from a modern engine. |
100/130 avgas | Roy Smith | General Aviation | 1 | December 24th 06 09:17 AM |
Old AvGas | gwengler | Piloting | 2 | December 16th 06 01:07 PM |
Survival and Demise Kit; Contest Points | Jim Culp | Soaring | 1 | June 21st 04 04:35 AM |
The demise of the Sea Harrier | Henry J Cobb | Naval Aviation | 39 | April 25th 04 07:27 PM |
Here's to Arafat's Speedy Demise | robert arndt | Military Aviation | 0 | September 12th 03 07:45 AM |
